View Full Version : ** SX-4000 2S SAW Set-up **
Philmunsterman
03-25-2011, 10:09 PM
I received the hull last week and have started to gather all the parts to set up the boat to run SAW. I found the recommended Lehner 1920/5 ( Thanks Don ) and today in the mail from OSE came the Swordfish 200amp ESC, Hyperion 2S 45C 5000 mah Lipos and a Hyperion EOSO720i ( I needed a new Charger ) I also got the Big Etti Cap Board but I'm not sure it will fit. I'm still waiting on a few parts and my goal is to get in the water next weekend. So the set-up will be:
SX-4000
Lehner 1920/5 6270 KV
Swordfish 200
2S 45C 5000 mah
V937
Any comments or advice would be appreciated. Phil
http://i982.photobucket.com/albums/ae309/Philmunsterman/sx4000-1.jpg
LarrysDrifter
03-25-2011, 10:29 PM
Very sweet,Phil. I have rigger envy.Good luck with your build. Hope to see it in action.If you ever come south,we have a very smooth lake we run at that would suit your rigger nicely.
RaceMechaniX
03-25-2011, 10:52 PM
Cool build Phil. You might want to try the low voltage cap bank instead. It's shallower.
Tyler
03-25-2011, 10:57 PM
1P or 2P? What speed are you looking for? Current records are in the low 90s IIRC.
Philmunsterman
03-25-2011, 11:34 PM
Larry, I may come check out your pond sometime. You Guys should come over to Frank Holten Park one weekend. I'm on a mission to show the Gas and Nitro guys that Electrics can really run. The best they have seen is a UL-1.
Tyler, I don't think I'll have room for either Bank. How do you think the Swordfish will hold up with out one ?
Fluid, 1P. I'm not going to guess on the speeds, I'll know more when it hits the water next weekend.
RaceMechaniX
03-26-2011, 02:10 PM
Phil,
Give it a shot without the extra cap board and using a small prop for the first runs. If the caps on the swordfish come in hot, it would be a good idea to add additional ones.
Instead of using a prefabed cap board you could just solder on additional caps to the Pos and Neg leads from the esc. See pic.
http://www.icare-rc.com/photos/futuc2i.jpg
Philmunsterman
03-26-2011, 02:33 PM
Tyler, Thanks for the pic. Right now the V937 is the only small prop I have. Most of my props are left over from my Gas Boats.
johnson22456
03-26-2011, 02:36 PM
Looks good Phil. Can't wait to hear that little lehner scream.
Philmunsterman
03-28-2011, 12:41 PM
Spent a few hours on Saturday getting the Rigger all set up. If I can get the Wire Drive this week it should be in the water this weekend ! I will try to have my son shoot some video. No room in the boat for my GPS but I just traded for a Garmin Radar Gun.
Brushless55
03-28-2011, 08:58 PM
Awesome! :rockon2:
Philmunsterman
04-03-2011, 12:08 PM
I had a chance to take the Rigger for a quick test run this am. Not great conditions ( very windy in St Louis ). We went to a small pond and just made a few 1/2 throtle passes to check things out. All went well. Dry and low temps. Now I need a calm day to take it to the big lake and open it up !
TotalPackage
04-03-2011, 01:50 PM
Sweet design what kind of speeds you expect?
Philmunsterman
04-03-2011, 02:01 PM
I try not to guess at top speeds. The original Hull ran in the mid 90's. I will find out what the current set-up will do when we get some calm weather here in St Louis. That little Lehner is a Screamer !
carlcisneros
04-03-2011, 11:21 PM
Phil;
Don't Let Ken or Chucky see it run at full tilt,
they might get FE envy. LOL
Carl
Jeff Wohlt
04-03-2011, 11:36 PM
Will get you at least one wire drive out by Tuesday. 937? Yikes! 6500KV? x 7.4...eeeek....48,000 rpm? I will drill her as deep as I can captain! May even try brazing one and loctite the other...see which one holds! LOL
Philmunsterman
04-09-2011, 06:44 PM
Just got two new Wire Drives from Jeff and they look great. If the weather is ok I'm going to try and get a few runs in tomorrow.
Philmunsterman
04-16-2011, 10:21 PM
I found a video on line of the same boat and setup that I'm running. I still can't get any decent water to open it up. I'm going to the lake tomorrow to give it another shot.
http://www.rcline.tv/video/364/sx-4000-von-graupner
