View Full Version : prop questions need help
bbosncali
03-22-2011, 05:48 PM
What's the difference in an octura x645 and m645? Also how would either work on a stock mg and would I be able to use still with a 150esc and 2200 lepard motor? Thanks for the help
Diesel6401
03-22-2011, 06:00 PM
m645 is detongued. it's a good bit of pitch. A m445 would be a better choice for either motor IMHO.
bbosncali
03-22-2011, 06:05 PM
Would it be a better prop with the upgrade? My biggest problem is I want to upgrade my prop I ordered a prather 220 but I. Have no clue on how to balance it. I want to buy one already blanced and the only one available from ose is a m645. I was gonna have chuck do one for me but he's atleast 2 weeks out
Diesel6401
03-22-2011, 06:13 PM
Is this for 4s or 5s on the stock motor?
Reason being you can run a m445 stock on 4s and do fine, but a m445 on 5s will blow the stock esc. Not sure how that 150amp esc would do. I assume it's a suppo, may work ok though. A grim 42x55 is a GREAT all around prop for the MG on 4s and 5s on the stock power also a x642 is a choice as well.
Stock motor: (4s)
x442
x642
grim 42x55
m445
Stock motor: (5s)
x440
m640
x442
x642
grim 42x55
x440/3
grim 40x52/3
Leopard 2200:
x440
m640
x442
x642
s215
s220
x445
m445
grim 42x55
The CF series props can work until you get your other props S&B, they have the same pitch as the Octura x4 series props:
Stock 4s:
CF42
CF45
Stock 5s:
CF40
CF42
Leopard:
CF45
bbosncali
03-22-2011, 07:01 PM
Thanks for the help found someone who has one already balanced for a good price
bbosncali
03-22-2011, 07:03 PM
642 that is... from what I read seems to be the best starter prop. Do you notice a big difference over stock with that prop
boaterkid333
03-27-2011, 07:28 PM
A M445 has a bigger radius with less pitch then the X642? Is it faster on stock setup?
Shaun78
03-27-2011, 07:31 PM
Hey Bos, I thought you said u balanced the 220?
bbosncali
03-27-2011, 07:39 PM
I did but I'm still going with the 642
PIGSTI13
03-27-2011, 11:20 PM
Hey Diesel,
Would the props you listed for for the Leopard 2200 work for the CC 1515 2200KV? Thanks.
Diesel6401
03-27-2011, 11:44 PM
Hey Diesel,
they sure would... I would say a grim 42x55 and the m445 would be the top choices... The motor can swing a bigger prop then that, but any bigger I think the hull my not like...
PIGSTI13
03-28-2011, 01:50 PM
I will try both when we lose our ice. Thank you for the suggestions.
