View Full Version : Tactic Radio Problems?
I'm thinking about a Tactic 2.4 Radio system for my boat. I currently have a good Futaba 2.4, but too much "stuff" on it I never use. My problem is that my mean machine is wrapped on the inside of the hull with carbon fiber all the way to the top of the hull.... Since the Tactic 2.4 radio receiver has no antenna will this cause a problem? Anyone have problems with that receiver due to the lack of an antenna?
chummer
03-20-2011, 10:26 AM
I have always wondered about that also.
I have never had a single glitch from the Tactic receiver but none of my hulls have a carbon layup. It will be interesting to here from members that have tried this.
SweetZ28
03-20-2011, 11:03 AM
I never had a problem with the tactic other than range my boats would rech a certain distance and then stop .
I switched to the flysky GTB3 and the cheap $20.00 2.4 radio systems they worked great so far and also go much further than the tactic radio i have not gone out of range yet with the 2.4 flysky stuff.
keithbradley
03-20-2011, 12:37 PM
Im running a tactic in this boat with no issues:
http://i624.photobucket.com/albums/tt328/keithbradley/100_4535.jpg
I just saw the flysky stuff and it's advantage seems to be that the receiver has an antenna, I wished the Tactic had an antenna.
Kieth,
Does the carbon fiber go up the sides of your boat, or does is just cover the bottom of the hull?
sailr
03-20-2011, 05:55 PM
All of my boats have carbon floors in them. No issues with the tactic. I like the tactic because it does NOT have an antenna! Haha. Go figure, eh?
keithbradley
03-20-2011, 08:16 PM
Kieth,
All the way to the top. Its 2 layers as well. Im not sure how it would do if I mounted the rx in the sponson but I havent had any problems where its at now.
I switched to Tactic because I like the idea of having no antenna and still outperforming other rxs that have an antenna. (Not saying they outperform all other rxs, just the ones I had).
EDIT:
Just to be clear, I dont have carbon on the bottom of the top side. It DOES go all the way up the sides though.
Flying Scotsman
03-21-2011, 10:41 AM
The Tactic RX is a beauty but I do not like the pistol controller (rotary pot controls) , as I run multiple boats and it can be a pain in the arse to setup for each boat. It is great for a dedicated boat though....just my 2 cents.
Douggie
SweetZ28
03-21-2011, 11:14 AM
:bounce: Here is what i did...
Got my self a old KO PROPO MARS and put the flysky 2.4 modual in it and now i have a awesome radio and can buy 2.4 receivers for $7.00 a pop!
http://www.rctech.net/forum/attachments/radio-electronics/700486d1296244797-flysky-gt3b-transmitter-mars-001.jpg
SweetAccord
03-21-2011, 06:00 PM
You did exactly what I did with the ASSAN line. You get a radio that has multi-model memory and receivers are dirt cheap when you compare to everything even the Tactic, good decision.
LarrysDrifter
03-21-2011, 06:29 PM
Im pretty sure one would only have a problem with not getting a signal is if the hatch itself is re-inforced with carbon fiber.If the hatch is just fiberglass alone,you should be fine even with the hull having CF layed inside it-even all the way up the sides.This is only my opinion of course.See if a friend will lend you his Tactic system for a few minutes and test it out.Then,you ll know for sure.
sailr
03-21-2011, 06:58 PM
I certainly agree with that! I can't believe they haven't come out with an upgraded tactic transmitter with multi model memories, etc. etc.
Douggie
Mel279
03-22-2011, 07:43 PM
My cat has carbon/kevlar floor and carbon fiber hatch, the rx tactic is out of range just for a few meter run, so I just add the antenna wire to the rx (2.4ghz wire) and it works fine but be sure to put the antenna outside of the hull.
sailr
03-22-2011, 07:51 PM
WHERE do you attach an antenna to the tactic receiver? What do you mean by "2.4ghz wire"?
Mel279
03-22-2011, 10:28 PM
I try to get the picture of it as the rx is damage by accident as I forgot that cc bec can handle only 6s max, so I put 8s so you know what happen. 2.4ghz antenna wire should be use, other wire like those am & fm will not work.
Mel279
03-22-2011, 11:13 PM
here is the photo on how the antenna is installed, require the antenna resistor to be removed first.
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/197901_143262705739470_100001672258927_283482_8273 387_n.jpg
sailr
03-23-2011, 02:52 AM
Very interesting. Where do you get that kind of wire? How long should it be?
Mel279
03-23-2011, 03:08 AM
can get from here http://www.himodel.com/radios/150mm_Long_2.4G_Receiver_Antenna_for_Frsky_Series_ Receivers_2pcs.html
or if you have a defective 2.4ghz rx, the antenna can also be use. The length is not important, just as long as the wire protruding outside the hull just like the normal 2.4ghz rx. The most important is the top end of the wire which already being cut. Sorry for my bad english but Ihope you can understand what Im trying to say
SweetZ28
03-23-2011, 08:46 AM
Hi tower hobbies has the 6channel tactic RX's for $19.99 they show a photo and they have a antenna already... you can probably use one of these.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LW6039&P=E
sailr
03-23-2011, 06:19 PM
Tower site says it will only work with their TTX404 Stick type transmitter. Too bad. I wish they would upgrade their surface transmitter with some model choices, etc.
