View Full Version : Help, x642 bending over??
rchuntlsl
03-19-2011, 12:08 PM
A friend of mine that asks me for help on his rc boats a lot, just hit me with this one. I have never seen this before. His octura x642 prop, the leading edges are getting folded over. he calls it flatting the prop:confused1:. He is running a genesis with a leopard 4082 kv1500 on 6s with a 180 amp esc. He is not over revving it. I am wondering if the shaft is too high or low causing cavitation doing this. Water is a very powerful substance.
rchuntlsl
03-19-2011, 12:34 PM
He will send me a picture tomorrow.
03-19-2011, 09:00 PM
He is either hitting stuff in the water or on the beach - or the blades were thinned too much. It is not "cavitation" since cavitation is what makes these props work. Some guys think that the thinner a prop blade is the better - not so. Here is a shot of a prop which was thinned too much. After thinning the prop can be hardened which helps prevent bending.
http://i55.tinypic.com/24n2z6h.jpg
rchuntlsl
03-20-2011, 10:53 AM
He does not thin the props. I think he got a balanced x642 from steven here. He runs off his dock, so the beach is not the problem. The lake he runs on is very clean, there is no evidence of debris in the lake. Any other ides? maybe a bad prop? What is the proper way to harden a octura prop?
03-20-2011, 01:32 PM
The S&B props Steve sells are thinned. Your friend's was thinned too much on the leading edge, it happens.
