JPriami
03-18-2011, 03:19 PM
ALL SOLD
This is a package deal on items also being sold separately now.
Traxxas Velineon 540XL Brushless Motor with upgraded aluminim cooling jacket, VXL-6s Marine ESC, cooling lines, strut, flex cable & prop 42x59 CF,
I also have a lightly used Traxxas 7-Cell 8.4V 3000mAh NiMH Stick pack with 4mm bullets on it. I will include the stock traxxas silicon cooling jacket with this sale as well
$140 shipped to you USA lower 48
Here are some specs on the equipment.
Velineon® 540XL Brushless Motor
Ultra high-temperature sintered Neodymium magnets
Optimized for power and efficiency in marine applications
Consistent, high-power output, run after run
Low-maintenance design
Efficient, high-speed ball bearings
Precision-balanced rotor
High-efficiency bullet connectors
1600kV
5mm output shaft
Brilliant blue-anodized finish
Silicon steel laminations
Unique high-flow silicone water cooling jacket
Velineon® VXL-6s Marine ESC
Innovative waterproof design
integrated water cooling
Three programmable drive profiles:
Sport Mode – 100% FWD / 15% REV
Race Mode - 100% FWD / No REV
Training Mode – 50% FWD / 15% REV
High-efficiency MOSFET transistors
Built-in two-stage low-voltage detection for LiPo batteries
Thermal overload protection
Voltage overload protection
Locked rotor protection
Throtle Neutral Setting protection
NiCad and NiMH battery packs: 6-18 cells (7.2 to 21.6 volts)
LiPo battery packs: 2-6 cells (7.4 to 22.2 volts)
12-gauge Maxx Cable wire
There are no connectors on the battery side of the ESC I replaced them with EC5's then took them off when I swapped out the motor and esc.
http://img.photobucket.com/albums/v337/Jpriami/b1272650.jpg
http://img.photobucket.com/albums/v337/Jpriami/2f23d1b2.jpg
http://img.photobucket.com/albums/v337/Jpriami/a0b9ca71.jpg
http://img.photobucket.com/albums/v337/Jpriami/fa4f7b81.jpg
1600kV
5mm output shaft
