View Full Version : Sordfish 120
longballlumber
03-17-2011, 01:16 PM
Hi Steven,
Do you have an idea when you will be getting more of the Swordfish 120's in stock? I would like to try a couple. Also which programmer do you recommend: the USB or the card?
Thanks,
Mike
03-18-2011, 03:55 PM
My personal choice is the box.
I will have a couple next week and a large batch in about 3 weeks.
longballlumber
03-19-2011, 08:57 AM
Ok, thanks for the reply.
Mike
longballlumber
04-04-2011, 03:28 PM
Hey Steven,
Are those 120's still on schedule to be here this week? When you say "box" do you mean the seaking/hobbywing box or is there a specific Sordfish programming box? The Sordfish listing mentions a USB or a Card. Nothing of a box.
thanks
Mike
04-04-2011, 03:55 PM
I'm hoping so.
Here is a link to all the swordfish stuff.
http://www.offshoreelectrics.com/search.php?pg=1&stext=hef-&sprice=&stype=&scat=&sman=
longballlumber
04-04-2011, 04:05 PM
ahhhhhh.... got it, thanks! sorry for the confusion.
Mike
04-04-2011, 04:07 PM
No its my confusion. In the text i can it an lcd programmer. I should have said the same thing here. The best thing about the usb is that its the only method that you can update the esc's firmware with(if needed). but its also a bit of a pain to install on some pc's.
longballlumber
04-05-2011, 02:39 PM
Thanks Steven,
I just put in an order!
Thanks
Mike
6sHyper
04-06-2011, 12:11 AM
Hey Steven, when do you expect more SF 240hv to come in stock? thanks
04-06-2011, 07:10 AM
Very soon. I hope this week or next week.
Meniscus
04-06-2011, 03:55 PM
Steven, Perhaps I missed it elsewhere, but what are the degrees of timing advance for low/standard/high for the 200A LV?
I guess it would be in the manual if I knew where to find it.
Thanks!
Diesel6401
04-06-2011, 05:41 PM
Thanks!
This may help http://www.astecmodels.co.uk/pdfs/Swordfish%20200A%20ESC.pdf
Option 1: Low advance timing
0°~15°
Recommended for more lower pole count motors. Gives more power and
slightly less efficient.
Option 2: middle advance timing
5 °~ 20 °
Recommended for most motors .Gives a good balance of power and efficiency.
Option 3: High advance timing
15° ~ 30 °
Recommended for most of higher pole count motors
Option4:Auto(default)
Recommended for most of all brushless motors.
Meniscus
04-07-2011, 03:41 PM
Very helpful. Thanks!
longballlumber
04-16-2011, 10:20 AM
Can anyone tell me what threads are on the water fittings for the Swordfish 120's? I would like to replace the straight fitting with a 90 degree on one end. Any thoughts?
longballlumber
05-02-2011, 09:37 AM
Bump...
Does anyone know what threads are on the Swordfish water fittings?
Thanks
Mike
longballlumber
05-16-2011, 11:38 AM
Just in case anyone else was interested... They are 4MM
