View Full Version : programming a t-180 low voltage cut off
wilsta67
03-17-2011, 03:35 AM
can some one enplane how to set this manually running 6s
thanks!
JPriami
03-17-2011, 11:04 AM
Check your manual. I'm not near mine. But I think you enter programming mode by holding throttle full forward 100% then plug in batteries and listen for a set of tones. I think setting cell count is the 2nd set of tones. But the manual decodes the tones you need to listen for so you know what to do. If I had mine id try to be more help.
wilsta67
03-17-2011, 02:56 PM
the problem is the writing on the instructions is so small i cant read it even with my glasses on lol
pyroM!KE
03-17-2011, 03:26 PM
LOL..You asked a question about manually setting esc and the answer is in the manual..
L
O
L
wilsta67
03-17-2011, 03:42 PM
L
O
L
Der read what I said time waster.
L
O
L
lectriglide
03-17-2011, 07:04 PM
Here is a pdf version Turnigy/Seaking.
dag-nabit
03-17-2011, 08:35 PM
That works. Zoom into 200%, you have to scroll a bit, but the writing is big enough for us old geezers.
Kevin
