View Full Version : Ni-MH vs. LiPo setting from the factory
jfraleyjr
03-14-2011, 10:49 AM
Ok, those of you in the know, please help clear this up:
In the instructions included with the boat AND the PDF found on the ProBoat site it clearly states
"Be sure to use a PRB3311 Programming module to adjust the cutoff voltage when
using Li-Po batteries to protect against over discharging the batteries."
HOWEVER, on the Proboat website, in the "Tech and Spec" section, it states:
Tech Notes
The 60-amp electronic speed control is factory set in Li-Po mode.
Which is it, is it set for LiPo OR is it set for Ni-MH
Do I need to get the programming module just to play it safe?
:help:
jfraleyjr
03-14-2011, 01:27 PM
Anyone?
Bueller...Bueller...
gmkelm
03-14-2011, 01:59 PM
I was told by Horizon tech support on the phone that the ESC is programmed from the factory for LiPo's.
Mark
CHIEFY_44
03-14-2011, 02:36 PM
the esc is set for lipo's from factory, but i have the module and used it to make sure it was and to adjust timing, cutoff and throttle settings to linear. But as i stated i already had the programmer from having to set up my MG
