View Full Version : Need info on "Servo Savers"
properchopper
03-04-2011, 08:17 PM
I've seen these critters advertised , seems mostly for cars. Thing is that my tunnel will flip & the resultant pull when the lower unit slaps the water takes out my servo. Is it possible to adapt a servo saver to my application with a push/pull servo arm ?
Thanks,
Tony
HOTWATER
03-04-2011, 09:15 PM
Hmmm....not sure about this, but does seem like a good alternative to loosing servos. Are you looking to obtain one as I should have one or two laying around? I know the one's I have are made to fit Futaba servos...LMK...
-Kent
properchopper
03-04-2011, 09:31 PM
-Kent
Kent, I'm using servos that take Futaba arms. Would it be possible to show pictures of how they mount/fit ?
Thanks,
Tony
HOTWATER
03-04-2011, 10:01 PM
Thanks,
Tony
Sure!...here are a couple of bad pics (LOL!) of one mounted on a Futaba servo...
Doug Smock
03-04-2011, 10:30 PM
This may work for you Tony. http://www.servocity.com/html/122ss_double_end.html
I have seen guys use quick links (less the screw), fuel tubing, and lock collars.
The boat is hauling the mail, Herb would be proud!!
Good luck!
Doug
properchopper
03-04-2011, 11:09 PM
-Kent
According to what I see, it seems like I could get one to work. What kind of a transaction do you have in mind ? Edit : OOps, I'll need a double arm like the one Doug suggested, $ 6.95 at servo city; I think I have about that much left after WW VII !
MaxCorvette
03-05-2011, 05:22 AM
Here is a pic of how I did something like this..
http://i247.photobucket.com/albums/gg137/MaxCorvette79/MaxVee1-L/Final10-1.jpg
In this case it is for a throttle servo for a gasser that vibrates pretty bad.
Marcel
Himalaya
03-05-2011, 10:31 AM
Out there are shaft type servo savers for rock crawler trucks. I use to have those in my G1 crawler. You made think they might be suitable for boat rudder links too. Surely they are a bit thick thus may need some mod in the rubber boot.
properchopper
03-05-2011, 10:39 AM
Where can I find them ?
siberianhusky
03-05-2011, 10:57 AM
http://www.tcscrawlers.com/Ofna-Heavy-Duty-Servo-Saver-p-16255.html
how bout this one, for over 200 oz/in servos.
properchopper
03-05-2011, 11:17 AM
Thanks. The one Doug suggested looks more applicable since I use a push/pull config rather than a single arm. I'm giving the "fuel tubing" solution some thought as well.
Anbjorn
03-05-2011, 12:22 PM
If it was me I would consider trying one of these used in large scale rc cars.
http://www.rc-car-online-shop.de/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&wkid=1159&ls=e&nc=1299345403-2300&rubnum=&artnum=fg_4493&file=&gesamt_zeilen=0Tsuche--servo%20saver
Here is also one
http://www.rc-car-online-shop.de/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&wkid=1159&ls=e&nc=1299345782-5480&rubnum=&artnum=clarks_52110000&file=&gesamt_zeilen=0Tsuche--ball%20bearing%20servo%20saver
With ball bearings
http://www.rc-car-online-shop.de/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&wkid=1159&ls=e&nc=1299345782-5480&rubnum=&artnum=y4494_03&file=&gesamt_zeilen=0Tsuche--ball%20bearing%20servo%20saver
I will require some modifications to your steering system but the saver is very durable and accurate.
Anbjørn
