View Full Version : BL Pro Boat Mini-Cat (Now the Mini-C)
Diegoboy
01-02-2008, 12:14 AM
Video @ post #102 (http://forums.offshoreelectrics.com/showpost.php?p=27281&postcount=102)
The following is how I convert a Pro Boat Mini-Cat to Brushless.
I have lost my Pro Boat Mini-Cat to Davey Jones. The kind folks at Pro Boat (Horizon) replaced her with a Mini-V. I questioned the replacement, they stated that the cat, due to the rename, is not available. The Mini-V is the closest replacement. I took the V to my LHS, they exchanged it for me.
Now on to the build progress...
Parts list:
3/16 brass tube.
.098 flex cable w/ 1/8 stub/prop shaft (Octura (http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc098L-24c))
Motor of choice. (I'm using this ammo 28-35-2700 (http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLWY0&P=7))
ESC of choice. (Team Orion Captain-35 (http://www.teamorion-avionics.com/Brushless+ESCs/Captain+35A))
Mini Hydro Hardware (From OSE (http://www.offshoreelectrics.com/proddetail.php?prod=mcr-mhd&cat=69))
Prop of choice. (x427 (http://www.offshoreelectrics.com/proddetail.php?prod=oct-x427))
2 part foam. (This stuff is awesome (http://www.hobbypeople.net/gallery/864206.asp))
I removed everything from the hull except the linkage boot. I inserted a coarse rattail file in the tube from the transom end. Rattail files are thicker in the middle. Once the file bottomed out on to the tube, I gave it a slight right twist, till I heard it pop.
http://www.diegoboy.com/misc/100_2049-sm.jpg (http://www.diegoboy.com/misc/100_2049.jpg)
I used a small pair of vise grips on the front of the stuffing tube. I grabbed the tube and gave it the same slight twist till I heard it pop. Then I removed the Vise grips.
http://www.diegoboy.com/misc/100_2051-sm.jpg (http://www.diegoboy.com/misc/100_2051.jpg)
I used the rattail file still locked down on the tube at the transom, and twisted the tube to the right as I pulled it out.
Drill the hole at the transom with a 3/16 bit as far as it'll go. Then file out the hole at the other end. Mark the 3/16 tube length with the original tube removed. Cut the 3/16 tube to length. Insert the cut 3/16brass tube in the hole at the transom, guide it through the other end, and extending about 1-2mm at the motor side (like the original was).
Make a 3 sided cut in the tub where the rear of the motor would be to make a flap. Fold this flap back. Get the 2 part foam. Hold the boat with the bow pointing down & hold the flap open. Mix 10cc of part A & 10cc of part B. Stir for about 10 seconds, then pour into the hole with the flap. This stuff does NOT push like the spray foam. it remains very soft like the fizz on your Coke or Pepsi. once it stops expanding, then it starts to set. Because of that, it won't separate, or bloat your boat. Once set, trim any foam that may have come out the flap, then close the flap and seal with epoxy mixed with paint for color.
http://www.diegoboy.com/misc/100_2048-sm.jpg (http://www.diegoboy.com/misc/100_2048.jpg)
There is absolutely no flotation foam in this boat from the factory. and it DOES SINK! I know first hand. The pocket of air in the bow didn't do a stinking thing.
Here's what it looks like after the foam is set.
http://www.diegoboy.com/misc/100_2047-sm.jpg (http://www.diegoboy.com/misc/100_2047.jpg)
That's all I have right now...
Diegoboy
01-08-2008, 11:56 AM
Got the motor...
Compare it to the stock motor:
http://www.diegoboy.com/misc/100_2057-sm.jpg (http://www.diegoboy.com/misc/100_2057.jpg)
Diegoboy
01-08-2008, 12:31 PM
Buying the mini hydro HW today from OSE.
I can't cut the .098 flex to length till I get the HW installed.
Diegoboy
01-08-2008, 08:13 PM
Mini Hydro HW ordered. Let's hope that Steven's fast shipping works the same for me too!
Diegoboy
01-11-2008, 07:51 PM
Got the HW today. (Thank you Steven)
Here's a shot of the installation. That prop is only for the picture...
http://www.diegoboy.com/misc/100_2074-sm.jpg (http://www.diegoboy.com/misc/100_2074.jpg)
Wow what a clean install. Nicely done Sir!!!!!!!
Diegoboy
01-11-2008, 08:23 PM
Wow, someone else posted in here besides me?? http://cornsnakes.com/forums/images/smilies/raspberry01.gif
Thank you SJFE!
Diegoboy
01-12-2008, 08:09 PM
I went to the LHS today to get the flex coupler. .098 to 1/8. They are out. the last one sold was to me and it's at the bottom of the lake. It'll be in stock next week!
I picked up the drive dog, and an X427 prop. It's not sharpened or balanced as yet.
I also picked up the ESC it's going to run. I couldn't pass it up, because it was in my price range! (Cheap).
Specs are on the link in the OP
I installed the motor, and finally got to cut the flex cable to length.
http://www.diegoboy.com/misc/100_2081-sm.jpg (http://www.diegoboy.com/misc/100_2081.jpg)
http://www.diegoboy.com/misc/100_2083-sm.jpg (http://www.diegoboy.com/misc/100_2083.jpg)
http://www.diegoboy.com/misc/100_2084-sm.jpg (http://www.diegoboy.com/misc/100_2084.jpg)
frostyan
01-12-2008, 08:51 PM
nice kitten very clean setup . were did you get the bailer
Diegoboy
01-12-2008, 08:53 PM
Thank you!.
That is the stock drain plug.
Nice score on the esc!! So when are you building the sub to recover the first one????
Diegoboy
01-12-2008, 09:23 PM
When I can score the parts for the sub at a whopping $33.99! :laugh:
That LHS has about 20 of those ESC's at that price. The bay sells them for over $50
The 45A version is $39.99
Diegoboy
01-13-2008, 08:23 PM
1st Video. Don't get excited, it's just the rudder throw for now.:olleyes:
Video (http://www.diegoboy.com/media/100_2089.wmv) <--
eric-paul
01-13-2008, 10:51 PM
Diegoboy,
this build really looks cool. i am sorry you lost your first one. i am surprised there is no float foam in that hull. even worse that there is no bow access. that two part foam looks great, it's better than the spray stuff then? if i were to do the same thing, would you help me out?
Diegoboy
01-13-2008, 10:55 PM
Welcome Eric.
I'd be happy to help/guide you. The 2 part foam I got is awesome. it pushes outward as much as the foam on top of your glass of cola. When it's done expanding, it will then harden. It simply doesn't push like the spray foam will.
eric-paul
01-13-2008, 11:03 PM
Thanks. i feel better trying to do this now.
Diegoboy
01-13-2008, 11:09 PM
You're welcome.
I apologize for the lack of details in this build, I just get 1 part done, then want to get the next done, then I realize "Oh man I forgot to take a pic for the build"
Diegoboy
01-22-2008, 11:59 PM
Updates:
Flex Hex Coupler installed, ESC installed & RX installed.
http://www.diegoboy.com/misc/100_2099-sm.jpg (http://www.diegoboy.com/misc/100_2099.jpg)
http://www.diegoboy.com/misc/100_2100-sm.jpg (http://www.diegoboy.com/misc/100_2100.jpg)
http://www.diegoboy.com/misc/100_2101-sm.jpg (http://www.diegoboy.com/misc/100_2101.jpg)
dirtysouth31
01-23-2008, 07:04 AM
that will look nice sittin on my shelf:laugh:
Diegoboy
01-23-2008, 08:59 AM
She'd look nice on any shelf! as long as it's not the shelf on the lake bottom!
Diegoboy
01-27-2008, 10:42 AM
All Done! waitin' for a good day to run.
http://www.diegoboy.com/misc/100_2107-sm.jpg (http://www.diegoboy.com/misc/100_2107.jpg)
http://www.diegoboy.com/misc/100_2108-sm.jpg (http://www.diegoboy.com/misc/100_2108.jpg)
http://www.diegoboy.com/misc/100_2109-sm.jpg (http://www.diegoboy.com/misc/100_2109.jpg)
Video (http://www.diegoboy.com/media/100_2110.mpg ) (Dry Run) <--
Really kewl littel mod you did there man. I bet is a mini missile:buttrock:. I can't play the video though:(.
Diegoboy
01-27-2008, 11:42 AM
Thank you Tom! I hope so.
Me either. I'm working on it
Diegoboy
01-27-2008, 11:57 AM
Fixed it! :tongue_smilie:
Dhuuuuuuude that things gone be sick!!!!!!
Diegoboy
01-27-2008, 02:40 PM
I hope so! :w00t:
crazzy maxx
01-27-2008, 05:53 PM
you have to get a video of this thing in water.
is it me ro is the boat moving in the video????
Diegoboy
01-27-2008, 07:43 PM
:lol: I didn't notice that, but it is moving! :laugh:
crazzy maxx
01-27-2008, 07:52 PM
that got powa
domwilson
01-27-2008, 08:16 PM
Hey Diego,
Boat is looking good. You know the best place to run it, huh? How is the ABS hull on that? Is it thick or thin?
Diegoboy
01-27-2008, 08:17 PM
It's average. but with that 2 part foam in the bow, the bow is as hard as a rock, but still light!
domwilson
01-27-2008, 08:20 PM
How long are you keeping this one?
Diegoboy
01-27-2008, 08:29 PM
I dunno... Till I need the space?
domwilson
01-27-2008, 08:34 PM
Hmmm...So the theory is, if you see something else cool to build, then you will have to make room for it. So let's see...resist this!:laugh:
http://www.microhydros.com/stephan_lindenau/stephan.htm
Diegoboy
01-27-2008, 08:44 PM
Low blow! That thing is SWEET!
Foam is a great thing:D , I use it on all my builds. The strength it adds is unreal !
domwilson
01-27-2008, 08:56 PM
Yes it is and your name is all over it. Resistance is Futile...:tongue_smilie:
Diegoboy
01-27-2008, 09:00 PM
trying to find where to buy one (in english) :laugh:
domwilson
01-27-2008, 09:03 PM
Check out the video..
http://www.rcgroups.com/gallery/showphoto.php?photo=25388
domwilson
01-27-2008, 09:07 PM
I don't speak german, but I do see pics.
This will having ya thinking...Click on the left side where it says "boote"
http://www.team-lindenau.de/
domwilson
01-27-2008, 09:14 PM
Ok now that I got you going...back to my question; How long are you going to keep this one?:laugh: :laugh: :laugh:
rcmaster1029
01-27-2008, 10:04 PM
It looks good, man. Does it affect it having the rudder on the side?
Diegoboy
01-27-2008, 11:53 PM
Thank you!
I'll find out.
Offset rudders are supposed to be more efficient because it's not in the path of the prop wash. I must say that it being offset, helped in the balance of the boat since the RX & ESC are on the opposite side.
Diegoboy
01-27-2008, 11:55 PM
It is hard to say. It may be harder to get rid of, because it is overpowered!
bentprop
01-28-2008, 12:39 AM
What about esc and motor cooling. Especially when using vacuumed formed hulls
Diegoboy
01-28-2008, 08:13 AM
The motor is rated at a nominal voltage input from 11.1V - 18.5V. I'm on 11.1V
The ESC is rated for lipos from 2-6 cells. I'm in 3 cells
Max surge current of the motor is 30A while the ESC is 35A with a max of 45A.
I'm not anywhere near the limit on any component. I don't expect too much in the way of heat. If I'm wrong, the rudder has a pickup! :tongue_smilie:
dirtysouth31
01-28-2008, 02:45 PM
back off dom:nono: the cats mine:moon:
Diegoboy
01-28-2008, 08:50 PM
http://cornsnakes.com/forums/images/smilies/AR15firing.gif____________________________________ ___________http://cornsnakes.com/forums/images/smilies/bigun2.gif
domwilson
01-28-2008, 09:06 PM
I'll arm wrestle you for it...:bash: :bash:
crazzy maxx
01-28-2008, 10:05 PM
hmmmm who will win?!?!?!!?
lol
Diegoboy
01-28-2008, 10:10 PM
Dirty has a bum elbow!
domwilson
01-28-2008, 11:01 PM
He's alot younger than me. I might have to double up on the Geritol!
Diegoboy
01-29-2008, 06:42 AM
You both have 1 advantage each. Dirty lives here, so it's no expense to ship to him. Dom lives exactly where I want to be, so if I can't be there, at least one of my boats can!
:laugh:
dirtysouth31
01-29-2008, 09:36 AM
One advantage you forgot to mention diego....I know where u live!
crazzy maxx
01-29-2008, 05:52 PM
o god
diegoboy
better hide the boat b4 u have a mysterios robbery...
domwilson
01-29-2008, 06:23 PM
Send it to me for safe keeping..:thumbup1:
rcmaster1029
01-29-2008, 10:19 PM
He already said I could have it. Yeah, go figure...:lol:
domwilson
01-29-2008, 11:23 PM
Dang! Diego, Your cat sure has made you popular. :banana:
When you going to put that thing in the water? If you see any guys out there with a transmitter and no boat, you might want to keep it close to shore.:rockon2:
Diegoboy
01-29-2008, 11:25 PM
So true. I hope to get her in the water this weekend, if Dirty ever get's his arrow wind ready!
Dale Koblitz
01-30-2008, 12:51 AM
I did the same conversion with my mini V but when I twisted the stuffing tube out it cracked the hull a little near the strut. No big deal, I fixed it with a little ca glue and marine epoxy. I used a pulso 40amp esc, a feigao 16s 2500kv motor, detounged x432, and 3s 1650HV 15c battery. The battery is the weak link but the boat flies. It litterally jumps like 2 feet out of the water if you juice the throttle. I'm going to order this http://www.rcworldwide.com/v5/product_info.php?currency=USD&info=p701_Delta-Force-16--Mini-Hydro.html . and this http://www.offshoreelectrics.com/proddetail.php?prod=mcr-mhd&cat=69 which is the same set you ordered. Do you think this will be a decent set-up? The hull is only 16" so I figure I'll have a pretty quick little micro Hydro on my hands.
I noticed on that site I could just get a micro hydro boat for like $231. but that kind of defeats the purpose of finding a hull for the stuff I got. I also would like to build my own boat but I'll have to figure out what it'll cost for hull, hardware, mount, shaft and a pushrod if the mini-v one doesn't work.
Dale Koblitz
01-30-2008, 12:54 AM
I have a question for you. The hardware you used is the same I'm ordering for my project and it says to use .094 cable but all I can find is .098. I see you used .098 was there any issues with that?
domwilson
01-30-2008, 01:15 AM
Be careful with these guys. http://feedback.ebay.com/ws/eBayISAPI.dll?ViewFeedback2&ftab=AllFeedback&userid=com-rcworldwide&iid=-1&de=off&items=25&page=2
I ordered a few things from them in the past.
Got the wrong Feigao motor (20XL) and they said that it would cost me more to get the motor I paid for originally (9L). Took almost three months to get a rudder from them and it was the wrong one. Wouldn't take it back. Wouldn't answer emails. I was told that they were pulled from ebay for awhile because of their bad customer service. Part of the learning curve when getting into this hobby. Bad Vendors. You might have better luck.
Diegoboy
01-30-2008, 08:21 AM
The same thing happened to my Mini-V (not this Mini-Cat) when I did this to her also, she cracked like yours. She also had a serious issue with torque roll. Being a V hull, she had no left / right stability against the torque. This Mini-Cat, on the other hand, does. It's twin hulls will give her much more stability in defense of the torque than a V hull. Also, she's 14.5" long, only 1.5" shorter than that hydro you want to try. That hydro looks sweet, if you can find a US supplier for one.
Diegoboy
01-30-2008, 08:29 AM
The .098 had no issues. You will have to shim the strut if you go with a 1/8 stub (prop) shaft. If you stick with the 3mm shaft, your prop choice will be limited.
...Oh, If you only did the flex shaft mod to your V and left the stock steerable outdrive installed, that also adds to your instability with your V. You hear how the steerable outdrives handle like an 18 wheeler? well imagine a twin turbine 18 wheeler. :thumbsdown:
jeff180
01-30-2008, 03:54 PM
Do you really think it will kill the handling? Im really eager to do this but dont want to rob a bank to pay for all these parts I need. If I buy all the parts you mentioned on the first page minus the Mini Hydro hardware and I cut the shaft to fit the stock outdrive run it a few times and figure out that handling is crap and decide to shell out the money to get the Mini Hydro outdrive will my cable still fit or will I need a New one?
thanks
Diegoboy
01-30-2008, 05:05 PM
The steerable outdrive modded with the .098 flex shaft alone will not "kill" the handling.
It's that mod, coupled with overpowering the boat with a brushless motor that will do it.
Diegoboy
01-31-2008, 12:01 AM
thanks
Sorry... I missed this part.
The stock HW needs a longer cable than the Mini Hydro HW. So your cable will still fit with maybe a tiny bit of trimming.
Avanti
01-31-2008, 12:16 AM
where the vid of this thing running????? the wait is killing me
Diegoboy
01-31-2008, 11:13 AM
She should be getting wet on Saturday 2/2/08!
A vid of this is like the Loch Ness Monster,,,,there are rumours, but no-one can actually claim to have evidence yet:rofl:
domwilson
01-31-2008, 01:10 PM
I'll alert the media..:wink: .. Just kidding. I just wanted to say that. It's all Dudley Moore's fault!
domwilson
01-31-2008, 01:13 PM
For reference for the youngsters, Dudley Moore was the star of the movie "Arthur".
Avanti
01-31-2008, 01:23 PM
yeah that will help them :tongue_smilie:
good thing they have google for the youngsters :banana:
domwilson
01-31-2008, 01:31 PM
Ya think we'll get a gps reading too?
Avanti
01-31-2008, 02:05 PM
any early predictions as to how fast it will be???
Dale Koblitz
01-31-2008, 02:35 PM
thanks
The mod won't hurt the handling (if anything it will help) but he's saying with all the power of BL the upgraded hardware will handle much better then the stock stearable outdrive. But if you are going brushless it's a must to at least do the .098 cable drive because the stock streight drive with the plastic u-joints won't hold up and will cause lots of vibration and resistance causing unwanted heat. So just do theflex drive conversion and you can allways switch the hardware out later. Even if your going to do just run the stock motor the flex is a good upgrade. Some run the upgrade and a 3s lipo which gives great speed.
I predict the vid will be 15 seconds :rofl:
domwilson
01-31-2008, 03:11 PM
I will predict....31.625 mph against the wind. 34.950 with the wind.
If ladies in bikini's present 33.5 then into the wall!!:tongue_smilie:
domwilson
01-31-2008, 03:12 PM
My real guess is 24-28 mph.
Avanti
01-31-2008, 03:27 PM
I like the bikini / wall scenario
jeff180
01-31-2008, 04:27 PM
I bet 30mph+ and thanks for the help Dale Koblitz and Diegoboy.
Who else has done anything to there Mini-v/Mini cat? Lets see.
dirtysouth31
01-31-2008, 04:59 PM
i predict its gonna be on my shelf Sun 2/3/08
crazzy maxx
01-31-2008, 05:11 PM
i can belive i fell for ur icon
idk u may have to fight for it:zip-up:
dirtysouth31
01-31-2008, 05:26 PM
:stupid: :welcome: :banana:
Diegoboy
01-31-2008, 08:59 PM
My guess is that it'll try to leap out of the water, but I will not goose the throttle like last time. 32MPH is my estimate.
domwilson
01-31-2008, 09:36 PM
You fell for it! That is too funny!
Hey Diego, it was nice and sunny here. You know how brittle ABS gets in the cold.:rockon2:
Diegoboy
01-31-2008, 09:46 PM
Here's what I have as far as a forecast (http://www.weather.com/outlook/events/sports/tenday/23453?from=weekend_topnav_sports)
domwilson
01-31-2008, 09:59 PM
What? No 70's or 80's? Like I said, Cold. You don't want Dirty to catch a cold running that cat, do ya?
Diegoboy
01-31-2008, 10:08 PM
Dirty is gonna put his renegade against the cat. He was supposed to put the arrow wind against it. :confused2:
crazzy maxx
02-02-2008, 09:58 AM
today looks good...
Diegoboy
02-02-2008, 01:59 PM
...just waiting on Dirty and the rescue tug!
ace028
02-02-2008, 04:33 PM
Hurry up, I want to see some pics and vids
:bounce:
Diegoboy
02-02-2008, 04:35 PM
Batteries charged, boat ready, no Dirty?
I need his rescue tug just in case...
"Dirty" about sums it up.....lol.
Diegoboy
02-02-2008, 06:11 PM
I need to adjust her strut down some. otherwise, She did excellent!
Diegoboy
02-02-2008, 06:21 PM
I have the video!
It's 1 minute and 2 seconds long!
domwilson
02-02-2008, 06:23 PM
Post it man! Don't keep us in suspense.
Diegoboy
02-02-2008, 06:28 PM
I'm trying to edit it. it's 40Megabytes :sorry:
Diegoboy
02-02-2008, 06:34 PM
I stripped the audio off and resized it down. it's now 7M.
jeff180
02-02-2008, 06:53 PM
Why tell us this without a youtube link or a link to download the video?
Diegoboy
02-02-2008, 06:55 PM
Because it was still uploading to a server for you to enjoy!:tongue_smilie:
Diegoboy
02-02-2008, 06:59 PM
Here is the first run Video.
Video (http://www.diegoboy.com/media/mini-c00.wmv) <----
Youtube Video (http://www.youtube.com/watch?v=HUerVymJ_mw) <----
Need to make a few more adjustments.
...for those having difficulty with codec files, download this.
Defiler pak (http://hellninjacommando.com/defilerpak/DefilerPak-1.22.exe) <---
domwilson
02-02-2008, 07:19 PM
Man that thing is a little Rocket!!!
Diegoboy
02-02-2008, 07:21 PM
Ya, Lonewolf tells me that because my strut is higher than the sponson bottoms, is why she turns like she does. I will lower it for her next run!
domwilson
02-02-2008, 07:25 PM
Still looks fast. I like it.
Diegoboy
02-02-2008, 07:38 PM
She may go faster when the prop gets lowered and has more Bite!
ace028
02-02-2008, 07:47 PM
That is pretty sweet man, how do you like the hardware? Great job!
Diegoboy
02-02-2008, 08:06 PM
Thank you. The HW is great. a lot nicer than the stock stuff. I also have more room for adjustments.
jeff180
02-02-2008, 08:10 PM
Amaaaaaazing!!!!
Now I will definitely get the mini Hydro Hardware. Expect a video from me in a couple of weeks. I already have the Charger and the battery's coming. My hulls prepped and stripped down for the new flex cable.
Diegoboy
02-02-2008, 08:16 PM
Thank you,
She still could use tweaking.
Diegoboy
02-02-2008, 08:40 PM
Okay, all jokes aside, I am really contemplating the sale of this boat. Since my 1/8 Budweiser got damaged (http://www.rumrunnerracing.com/feforums/showthread.php?t=24860) before I could even start, I am just feeling down.
domwilson
02-02-2008, 09:07 PM
I knew it.
It will turn better when drivin like a cat should be. Powered through the turns :wink:
Diegoboy
02-02-2008, 09:49 PM
I was afraid to loose this one too, so I did release the throttle in every turn for fear of a roll.
Diegoboy
02-02-2008, 09:50 PM
Now that the vid is posted, what are the speed estimates now?
dirtysouth31
02-02-2008, 10:01 PM
10 km..okay 12km
Diegoboy
02-02-2008, 10:03 PM
...per mili-second
dirtysouth31
02-02-2008, 10:24 PM
Hey dom it does like the cold
domwilson
02-02-2008, 10:27 PM
tisk tisk...I'll be watching the swap shop.
Diegoboy
02-02-2008, 10:29 PM
Dom, you should be watching the "who's online" section for when it says:
Diegoboy - Creating new thread (swap shop)
domwilson
02-02-2008, 10:32 PM
Just have to distract Dirty so he doesn't notice. :tongue_smilie:
domwilson
02-02-2008, 10:33 PM
Hey Dirty...Look! It's Haley's Comet!
dirtysouth31
02-02-2008, 10:49 PM
I will know before diego even knows..
Diegoboy
02-02-2008, 11:05 PM
SJFE is trying to talk me out of selling it.
domwilson
02-02-2008, 11:17 PM
Peer pressure. It's a mother!
Diegoboy
02-03-2008, 11:29 AM
Video now available on Youtube (http://www.youtube.com/watch?v=HUerVymJ_mw)
Avanti
02-03-2008, 11:56 AM
looks good any speeds yet? looks like maybe 25
rcmaster1029
02-03-2008, 01:25 PM
That thing flies, man!
jeff180
02-03-2008, 10:53 PM
Im thinking about this esc what do you guys think?
http://cgi.ebay.com/Scorpion-35A-Brushless-ESC-Water-Cooling-Progam-Card_W0QQitemZ150175265704QQihZ005QQcategoryZ34058 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
thanks
Diegoboy
02-03-2008, 11:54 PM
It's 14mm longer, but the other dimensions are the same as mine. Amp wise, it should be fine. Do you intend to run the same motor as I did?
jeff180
02-04-2008, 06:12 AM
Yes and an Integy 11.1 Volt 1500mah 20c Lipo
Diegoboy
02-04-2008, 08:36 AM
That'll be a nice setup. I use the electrifly 11.1 1250mAh 15C
Dale Koblitz
02-04-2008, 11:55 AM
I use a 40 amp pulso esc and a 3s 1650hv 10c which is not the best battery for the job but it is working fine for now. The guy at the hobby shop said the 10c would be fine but once in a while the low-volt will cut-off for a second or 2 but then comes back on. I am going to order the cat hull I linked earlier since now the strut screws stripped out also and the V is just way overpowered. Diego your boat looks good. It porposes a little when you let off but settles down well when your on the throttle. Diegoboy, did you get the radio I sent you yet?
Diegoboy
02-04-2008, 05:27 PM
Thank you Dale! I got it on Sat. it didn't work when installed, I found out the TX XTAL is missing. The RX XTAL was there. I went to the LHS today to get the TX XTAL, but they only sell sets. $20.
Dale Koblitz
02-04-2008, 06:50 PM
Oh man, I'm not sure why I took it out but I must have. I can look for it and mail it if you didn't buy the set allready. I'm very sorry, I didn't mean to do that. I have no use for one chrystal. I feel stupid now. Let me know what you whant me to do. If you whant me to send the chrystal let me know what frequency it is and hopefully it won't cost me much to send it to you.
Sorry again,
Dale
Diegoboy
02-04-2008, 07:36 PM
It's AM ch72 75.630 If it's not too much trouble, & if you find it, just fold some paper around it, pop it in an envelope and lick a 0.41¢ stamp! Thank you again.
How's the RX/ESC working?
domwilson
02-04-2008, 09:19 PM
Hey Diego, Look at this.
http://cgi.ebay.com/32-fibreglass-catamaran-hull-for-electric-rc-boat_W0QQitemZ300195847382QQihZ020QQcategoryZ34058 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
domwilson
02-04-2008, 09:21 PM
:doh: I should have PM'd you. Maybe Dirty might be interested...
Dale Koblitz
02-05-2008, 02:12 AM
I'll look for it tomorrow and try and get it out asap. As far as the esc goes I'm still haveing the same problem? I tried moving the wires around but haven't tried a different t/x allthough the mini-t one is brand new and the same as the mini-v one. I'll try the mini-v radio one of these days? Did you ever use the esc? If so did you notice any range issues?
Diegoboy
02-05-2008, 07:35 AM
It was never powered on. I opened the box, took out the boat, removed everything in just a few minutes.
Dale Koblitz
02-05-2008, 10:51 AM
Must be the one out of your mini-cat!
Diegoboy
02-06-2008, 08:09 PM
She is "FOR SALE" on ebay. Auction starts at 10:00PM EST
Item # 250213673386
It won't be viewable till the start of the auction.
Dale Koblitz
02-07-2008, 01:17 AM
I just found that chrystal. I forgot I had a JR XR2 tx hooked up to the SV while I was testing it in the tub. I'll try and remember to get it in the mail the next couple of days. Sorry about that.
Why are you selling the BL mini-cat? Not happy with it? You only ran it a couple of times, right?
Diegoboy
02-07-2008, 07:58 AM
It's a number of reasons. the BIGGEST one is that I owe over $900.00 in taxes this year :censored:
02-07-2008, 10:04 AM
It ran great in a straight line. Did you ever attempt a full speed turn?
Diegoboy
02-07-2008, 11:07 AM
No, I was too afraid to turn with any bit of throttle. SJFE told me that it's how cats run, and it will turn flat given some throttle. Maybe the new owner will have the courage to try it. :spy:
Dale Koblitz
02-07-2008, 12:00 PM
Ouch, sorry to hear that. If it makes you feel any better I'm going to drop your chrystal in the mail today.:banana:
ray schrauwen
02-07-2008, 04:41 PM
This is a nice Hydroplane, what colour did you get? i got Green.
I'm putting a 1615 2 turn Mega in it with a 70 amp esc, lipo 2S-1500Mah 25C and a x427 prop. RC worldwide had (i bought the last one) the blue rudder (micro) for $15. I'm using a Fullers strut with .130 cable and octura coupler. Should bea handfull!:rockon2:
Eyekandyboats
02-08-2008, 05:16 PM
i am using a .098 shaft, but i have not gotten a coupler yet Deigao?
Dale Koblitz
02-09-2008, 01:28 AM
I haven't ordered it yet. I'm waiting on my taxes that are suppose to be here next week. Not even rure what colors they offer?
Diegoboy
02-09-2008, 09:13 PM
Sorry Taylor,
I'll order one and have it shipped to you. :confused2:
Dale Koblitz
02-10-2008, 12:49 AM
Diegoboy, did you get your chrystal yet?
jeff180
02-10-2008, 08:36 PM
Diegoboy, I got some questions for you. First off, Did you reinforce the stern with anything?If you did what. What nuts and bolts did you use for your rudder assembly?
Did you get them from Ose or a hardware store?
thanks for a nice guide and sorry if you answered any of these.
Dale Koblitz
02-10-2008, 10:13 PM
He said he poured 2 part foam in the servo linkage hole I believe. I asked him that before on another forum.
ace028
02-29-2008, 10:01 PM
Diegoboy, did the 1/8 shaft fit the bearings for the mini cat racing hardware? I am thinking about using this hardware on a hydromite but want to use 1/8 props like you did. Thanks.
ray schrauwen
03-01-2008, 12:09 AM
I would like to know also.
Did you just drill out the strut bearings? :help:
Thanks.
Diegoboy
03-01-2008, 05:33 PM
Sorry guys... I've been away for too long.
Anyway, I didn't use the bearings, I used brass tube as a bushing. (one inside another) it was a nice fit, using 3 different sizes.
ray schrauwen
03-01-2008, 07:39 PM
Thank you, I forgot that was possible. I'll machine a new bushing on my micro lathe in brass for my buddies Mini-V. :bounce:
10gauge
03-02-2008, 10:25 AM
Excellent build and very nice thread on your Mini-Cat! I tried to find the Team Orion Avionics Captain 35A or the 45A ESC, but it's discontinued. I wonder what would be a good replacement? Is it an Aircraft or Car/Buggy ESC? Do you need a Pistix Adapter?
Man this thread is getting EPIC. Just when you think it's dying out BAM it's back.....lol
jeff180
03-22-2008, 09:09 PM
diegoboy where did you get the motor from? I have been searching all over the place and have not found one in stock.
Diegoboy
03-22-2008, 11:30 PM
I ordered it through my LHS. I ordered another one 3 weeks ago, I'm still waiting for that one. I guess there must have been a run on those motors recently. It's like everyone wants that motor for some odd reason.
Diegoboy
03-22-2008, 11:32 PM
Sorry, I missed this one.
It's a plane ESC, but it doesn't need the pistix. I was unaware it was discontinued. I can still get it from the LHS here. LMK if you want one. I'll get it for you.
pisimi
04-11-2008, 03:05 AM
hi i was just wondering i have the same setup as Diego but i cant find the ESC he has so i saw this one would this be good? http://www.amainhobbies.com/product_info.php/cPath/1_221_223/products_id/20805
im using same battery as him to. and if that isnt a good one could someone suggest one. thanks.
pisimi
04-11-2008, 04:23 AM
oh i just checked out this one to i think this one should be the one but i am waiting for someone more experience to reply.
http://www.offshoreelectrics.com/proddetail.php?prod=dh-prb3309&cat=75
Diegoboy
04-11-2008, 08:18 AM
That ESC is a bit heavy and may be too big (size). Let me try to come up with an alternative ESC since they are so hard to come by...
pisimi
04-11-2008, 04:32 PM
thx man thats alot of help.
keon718nyc
04-13-2008, 05:43 PM
Hey, Just wanted to see if you guys can give me a link to where i can get the u-joint link that will fit the stock mini c. The first thing to go it seemed was this as the 1.5mm screw stripped the plastic. also what other brushless motors will fit the stock set up that can run 7.4v-11.1 lipo's and nimh ? Any help would be appriciated...
Diegoboy
04-13-2008, 07:22 PM
Pull out the straight shafts & U-joints, replace them with a flex cable.
Dale Koblitz
04-15-2008, 01:15 AM
Any 380 size BL motor will fit but you don't want to get to crazy with the KV's. And by asking what works with the stock set-up I'm assuming you know you have to get a BL ESC and a standalone reciever?
cafe00
06-24-2008, 05:17 PM
Hi guys, I'm new to the forum and RC boats. I race 1/5 scale cars and fly RC electric planes with lipos. The youtube video had me hooked. This is my first RC boat. I'm not toally clueless to RC stuff but have some questions on this build. I have the mini c boat already and ordered all parts on page 1 except for the hardware outrigger set.
*What kind of epoxy is good to seal the hull hole you need to make for the foam install? I'm not aware of many glues other than goop that will work on this type of plastic. I've read there is a permatex plastic welder epoxy? Is that good for this plastic? Also do I use same glue to glue in the replacement stuffing tube?
*Does the .098 flex cable fit in the stock stuffing tube? Kind of unclear from some of the replies. Also if I don't buy the mini outrigger setup, can I run the flex cable thru the stock steerable outdrive? Even with a lipo and brushless? What ultimately will happen?
TIA.
ray schrauwen
06-24-2008, 10:09 PM
TIA.
*EPOXY, I use a Permatex product from the auto section called COLD WELD. Be careful if you use ut since it sets quite fast. Treat it like 5 minute epoxy.
Always sand the area to be glued with rough paper 80 grit or so and clean with alcohol before gluing.
You can use JB Quick Weld, it is about the same as the permatex stuff. There are other epoxies but its good to go with a good name brand and from a place that turns its stock alot.
You can use the same glue for the stuffing tube or some very thick CA like Slow ZAP.
I used a new piece of tubing because the teflon fit better.
Yes you can use the stock outdrive but for brushless it depends how insane you want to make it. You don't want to have to fish it out after it flips, that a drag:cursing: ....Also with brushless you may need to lube the cable more often if you are spinning alot faster.
I would try to post pictures but I'm a little busy this moment.
Of course I did this for my buddies Mini-V but, no fear the same setup will work on the cat too :rockon2:
Now that I fixed his boat up he is 200% more satisfied than before.
If you haven't changed the battery connector to a full size Dean, I would, seems to help alot.
You may need a new coupler that is 2mm at the motor and .098" at the flex end.
I made my own, I have a lathe.
Hope I was some help.
P.S. Don't use a Mamba BL system, at least not the motor... the ESC is o.k. (Sidewinder is cheaper). The mamba motor is too small and will overheat.
This is a nice motor, https://www.unitedhobbies.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=4197&Product_Name=HXT_2445_(370L)_2900kv_Brushless_Inru nner
It is 24mm in diameter, not too shure if the stock motor is 24 or 28mm. If it is 28mm Steve has some nice feigao 380 motors in his online shop OSE, just click over to see them.
cafe00
06-25-2008, 12:12 AM
Thanks Ray, thats a lot of help. Couple of more questions from the noob. Sorry if they are stupid :) Except for the outrigger, I have all the same equipment as Diegoboy
*what kind of lube should I use for the flex cable?
*what does the outrigger do exactly? That's for stability while turning to avoid flipping? It seems that thing could add more weight on the back which would cause the front to lift at speed and flip end over end?
*What spec lipo did you run for your buddies build? I have an extra thunderpower 910mah 11.1v but am thinking it will last a total of a minute with this setup? Does the electronic compartment get much leakage in these boats even if no flipping?
gracias,
ms
Dale Koblitz
06-27-2008, 11:54 AM
Just skimming over the reply 2 your ? I didn't see an answer 2 your stuffing tube dilema. The answer is no. You'll need a 1/8" tube and of course the liner that comes with the flex cable. And b carefull when removing the old tube cuz I cracked my hull doing this step. Nothing a little marine epoxy didn't take care of though. I just grabbed the tube on the motor shaft end with a needle nose pliers and twisted till it broke loose. You'll also need 2 remove the bushings in the outdrive and replace it with brass bushings large enough to accomidate the larger prop shaft unless your using different running gear all together. I built the mini-v with a 2500kv feigao, 45amp pulso esc, and 3s lipo's turning I believe a detounged Octura x432 prop. This boat is ballistic 4 it's size. It will keep up with my moderately modded supervee if you can keep it right side up. It tends to flip or barrel roll if you give it 2 much finger upon take off. I plan on getting a micro mogli hull 2 accomidate the electronics to better handle the power. This hull is just not meant for the power my set-up delivers. Maybe a mini-cat would be much better suited being it is a cat and would have less of a tendancy to roll. Good luck! If you want pictures let me know but it's not nearly as clean as diego's old cat!
cafe00
07-19-2008, 03:25 AM
For those copying this build, I found out the hard way. The flex shaft setup mentioned will not fit the bearings for the outrigger. Here is the info for what's needed from the distributor below. Also a 1/8 stuffing tube is probably better suited as well. The one listed is also too big unless you want to seal it off with a lot of shoe goo...
The bearings are for a 3mm shaft. You need to order the flex shaft with a 3mm shaft like this one.
http://www.offshoreelectrics.com/proddetail.php?prod=mcr-mhfs
ray schrauwen
07-19-2008, 08:02 AM
I found that a piece of 5/32" K&S tubing made a great bearing sleave for the strut.
It seemed loose so I put a dab of goop to keep it in place. That way an Octura flex cable system would fit nicely and then I could use any standard 1/8th" props.
Also, if you drill out a Graupner Carbon prop with a 7/64 drill bit(new bit) and then use a 5-40 Tap (from local supply store) you can thread it easily so they will go onto the shaft, just put a 5-40 locknut behind it.:w00t:
thegreat1
07-21-2008, 06:09 PM
hey if anyone is still looking for one of thos captain-45's i found a website today that has them in stock pm me if you want to know.
cafe00
07-24-2008, 01:57 AM
OK, yet another noob question. What's the best angle of attack for the prop? Should it be deeper in water or higher up? If I angle the outdrive similar to angle of shaft - making it Deeeper in water - it seems to go slower. Is this right? i'm trying to find balance between angle and putting too much bind on the shaft. I'm running bushings and not bearings so want as little friction as possible but still as much speed as possible :)
jfabcustom
11-03-2008, 11:12 PM
Hey Diego, do you mean lowering the whole strut, or just changing the angle?
poobs
07-10-2010, 09:57 PM
Sorry, I don't have my KVs straight yet... :sorry:
How about the Mistery Ebay motor for this hull ? http://cgi.ebay.com/1700-Outrunner-Brushless-RC-Motor-30A-ESC-y-/250662338379?cmd=ViewItem&pt=Radio_Control_Parts_Accessories&hash=item3a5ca3bf4b
How will it compare to the Above AMMO motor ? :confused2:
pepperson4
07-10-2010, 10:26 PM
i have a brushless minic that had and outrunner the torque roll rediculously. just buy the turnigy motor form hobbyking for $20 and the 40a esc for $12 and yeah its like $10 more but it doesn't torque roll even a fourth.
poobs
07-10-2010, 10:32 PM
Thanks but which motor ? Hobby King carries several - no ? :confused1:
pepperson4
07-10-2010, 10:57 PM
i have this one it works perfectly with a flex drive and a 27mm-30mm prop(i have a 30mm)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4201&Product_Name=HXT_2835_(380S)_2700kv_Brushless_Inru nner
poobs
07-10-2010, 11:10 PM
Nice! You have it on a Mini Cat ?
pepperson4
07-11-2010, 12:26 PM
yes its on a mini c. its the exact same motor as the ammo one just cheaper. ill post pics soon
poobs
07-11-2010, 05:35 PM
Thanks! Yes, I'd love to see pics too. :thumbup1:
pepperson4
07-12-2010, 03:41 PM
heres some pics of my brushless mini c next to a brushless mini v. im still waiting on a new esc as my old one fried. heres the link. keep clicking next for more pics
http://s665.photobucket.com/albums/vv15/pepperson4/?action=view¤t=P7120181-1.jpg&mediafilter=images#!oZZ1QQcurrentZZhttp%3A%2F%2Fs6 65.photobucket.com%2Falbums%2Fvv15%2Fpepperson4%2F %3Faction%3Dview%26current%3DP7120181-1.jpg%26%26mediafilter%3Dimages
poobs
07-12-2010, 03:57 PM
Nice!!! :thumbup:
pepperson4
07-12-2010, 03:59 PM
i paid $12 for the ose strut, $10 for the flex drive system, $10 for the prop, $12 for the rudder, and $20 for the motor, and $4 for the metal gear servo, and a homemade watercooled motor mount from brass sheet and tubbing, and lastly $4 for the esc watercooler. i kinda had to save money when it came to the motor as i dont have much cause im 16 lol
poobs
07-12-2010, 04:07 PM
It is a great hobby :thumbup1:
RotorKop
05-08-2011, 08:17 AM
Old thread but..
Diegoboy the 2part foam link doesnt work for me..where did you get it from and what is the stuff called? Did it make your mini cat unsinkable? What about filling it into the sponsons also, would that make it safe from davey jones locker?
egneg
05-08-2011, 09:21 AM
Old thread but..
It sits on the bottom of the pond by his house. :sorry:
RotorKop
05-08-2011, 06:23 PM
Oh sorry to hear that. Is that his secound mini cat lost? 2-0 to mr Jones :(
Im glad I just won a lot of 3 mini cats on ebay then (122$ for 3, I think it was a bargain), because if this is how mini cats usually end up Im gonna need them all..Im new to rc boats so I dont really know what to expect..
But I would like to try to avoid sinking them if I can help it, so I want to try out the 2-part foam and put it in the front and on the sides inside the sponsons, but what is the stuff called..?
That two part foam has been discontinued by the manufacturer
damfurst
05-12-2011, 09:43 AM
This company has it available yet and in 3 different grades http://www.aeromarineproducts.com/boat-foam.htm
I have used this with sucess and in mini-c's to boot. Ask if you have any questions
RotorKop
05-12-2011, 06:43 PM
Thanks for the link damfurst. what density did you use on your mini-c, low, double or quadruple? You say you have used it with sucess on mini c, does that mean it cant sink anymore? Did you just do the front?
damfurst
05-12-2011, 07:30 PM
I used low because it was the cheapest and it works great. I have not lost any boats if they flipped since using this product. I have done 3 mini-c's. Two just the front and the other one more like 2/3. Just the front compartment is really all it takes to keep it from sinking.
