View Full Version : Help! Battery packs
boaterkid333
02-27-2011, 09:27 PM
I am getting the proboat Miss Geico once i get my paycheck. I am getting an X642 to bump up the speed but now i have no idea which batterypack from hobbyking i should get. Hobbyking has all kinds of different brands i have no idea what to pick from.
From my research i found out i need something like 2s, 5000mah, and 40C
turnigy?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16194
or these nano techs? light batteries make the boat go faster?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11934
Help me out here :help: thanks a bunch
Diesel6401
02-27-2011, 10:43 PM
turnigy?
I run both those packs (well I dont have the nano 5000mah I have the 6000mah ones) both are AWESOME packs. Biggest difference over the nano vs the regular turnigy packs is you can charge them at a high rate. The difference in weight isn't enough to make a major difference in speed.
gek1946
04-03-2011, 05:15 PM
I am running the same compbination with the prop no. and the 5000mah 40c batterys. My run time isnt good about 10 minutes. Is that ok?
what can you tell me about going to the 3s batterys at 11.1 hooked in series using a stock control module
Thanks
GK
