This is a little weird. I grease my flex cables after every day of running. Most of the time its only one set of packs a day (one run then re grease that night). Sometimes I might try it in the morning before work then charge up and run after work. So no more than 2 runs a day on a grease job. And the runs are 6-8 mins each. mostly 6 now that im drawing more amps.
I had 2 runs on this greasing. And when I tore it down to look into modifying something I found the stuffing tube brass showed signs of being hot and discolored. And it melted some of the plastic off the stuffing tube holder. I dont see anything in the tube to cause this and it doesn't have any bind to it when i put the liner and cable in it and spin it.
what I have noticed is that no matter what amount of grease I put on the flex cable it all seems to get taken off the cable when running. I have a Prather cable grease I bought 2 things of it years ago and still have about 1/2 of one can left.
