View Full Version : MG water outlet ?
dirty
02-27-2011, 02:26 PM
Is it a problem if my MG doesnt spray water out of the side? It doesnt get hot or anything,but ive noticed that the water pick up hose has water in it ,but nothing inside the hoses coming from the motor.It doesnt spray out of the side of boat.
egneg
02-27-2011, 03:23 PM
Can you blow through the water pickup hose?
dirty
02-27-2011, 04:06 PM
yes i can,it has water in the pickup,up until it goes into the boat.No water anywhere else inside boat.But everything is staying cool after running for 30 minutes to an hour
PDR447
02-27-2011, 05:11 PM
it's never going to shoot out like a hose. at full throttle it might shoot out 8 inches. slower speeds less obviously.
30 minutes to an hour??? what batteries?
dirty
02-27-2011, 05:23 PM
2 different sets of batteries..i have a set of 7.4 5000mah 45c,and 7.4 5000mah 40c...i get an average of about 25 to 30 minutes per set.I bought them from www.fastrcbatteries.com. #21
dirty
i know its not gonna shoot out far,but on my blackjack 26 shoots out enough that i can see it when driving towards me,the MG doesnt shoot out at all that im aware of
LiPo Power
02-27-2011, 08:31 PM
Place your outlet here and problem solved:
LiPo Power
02-27-2011, 08:33 PM
:confused2:
bbosncali
03-23-2011, 10:21 PM
Lipo what differnce does that make by moving the discharge line? I'm assuming you have done that with your boat
LiPo Power
03-27-2011, 02:08 PM
You can see the water comming out easier ....
Blockhart
06-07-2011, 07:12 PM
the hoses stock are pretty short. Make sure you don't have a kink anywhere
ron1950
06-07-2011, 07:25 PM
when u are going fast u just see spray coming out of the outlet....slow not much at all....medium i see a short streem like a old man with a enlarged prostate lol
Stone
06-09-2011, 05:26 AM
On my stock Geico I could easily see the spray coming out from the side outlet when running past, also at quite low speeds. Check for kinks in the tubes.
bbosncali
06-09-2011, 09:28 AM
I installed a 2nd pickup and I see water flying out of that hole and still never see any from my original hole so basicaly I use my 2nd pickup for half my esc and motor and my rudder I use just on half my esc. So far seems to be fine but I don't understand eithr why I never see anything from my rudder pickup?
