djmaincheese
02-23-2011, 09:09 PM
Tacon Brushless Motor LBP3674-B/5D-1300KV For 800mm to 1000mm RC Boats
Near New, Used twice in my Spartan, never got above 63*
Max Amps 56A
Lipo Cell 44V
Max Power 2400W
KV 1300
Resistance 0.0175
Diameter 36mm
Length 74mm
Hole Mounting Depth 6mm
Shaft Length 20mm
Shaft Diameter 5mm
Also inluded is a 540XL Aluminum Cooling Jacket from Kintec Racing
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0016-9.jpg
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0014-11.jpg
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0017-14.jpg
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0019-7.jpg
Also selling SEA KING 120A ESC
Features
Hobbywing Seaking 120A V2 Marine Brushless Electric Speed Controller ESC for Boat
Use top quality electronic components to enhance the current endurance ability of the ESC.
Special designed for RC boat, with excellent start-up, acceleration and linearity features.
With water cooling system and the whole ESC is waterproof to get a longer life.
2 running modes ("Forward Only" mode and "Forward/Backward" mode).
With 8 steps of timing adjustment to get the best compatibility with various of motors.
Multiple protection features: Low voltage cut-off protection for lithium or nickel battery / Over-heat protection / Throttle signal loss protection.
Switching mode built-in BEC has a very powerful output even working with 6 cells lipo battery.
User programmable and compatible with the pocket-sized Digital LED Program Card (Optional equipment) to set the ESC easily.
Specifications
Output: Continuous current 120A, burst current 240A.
Input: 6-18 cells NiMH/NiCd or 2-6 cells LiPo.
BEC Output: 6V@3A Switching mode built-in BEC.
Suitable Motor: Sensorless Brushless Motor
External diameter of the water cooling pipe: 5.0mm
Size: 94mm(L) * 33mm(W) * 18mm(H).
Weight: 91g
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0005-19.jpg
http://i689.photobucket.com/albums/vv259/djmeintjes/IMG_0006-15.jpg
$125 Shipped for Motor-Cooling Jacket-ESC & Series Connector
Max Amps 56A
Lipo Cell 44V
Max Power 2400W
KV 1300
Resistance 0.0175
Diameter 36mm
Length 74mm
Shaft Length 20mm
Shaft Diameter 5mm
Features
Specifications
Weight: 91g
