View Full Version : Can this Happen
kck741
12-28-2007, 10:37 PM
WHen I went to run my SV today it would not Get on a plane,the bow would sit up high and the stern would dig into the water.Am I running the wrong prop.
All stock
3600 nimh pack(duratrax)
L38*55 prop-its a Lifter prop please explain this to me
thank you
Kris
txboatpilot
12-28-2007, 10:59 PM
You may be using a prop too small in diameter for the boat/setup... Motor rpm is not high enough to use 38mm prop... You should try 42mm prop or 45mm carbon props work well... Lifting props are mostly used on riggers and hydros....
raptor347
01-02-2008, 03:28 PM
Put either a 42x55 or X442 on it. Sharpened and balanced, both props will pull very well.
Bill-SOCAL
01-02-2008, 04:52 PM
I run a 42x55 GrimRacer prop in mine. Works well.
kck741
01-02-2008, 06:42 PM
Is that a lifter prop
Bill-SOCAL
01-02-2008, 06:53 PM
No, it is a standard prop. I usually do not run lifter props on mono hulls.
eric-paul
01-13-2008, 11:21 PM
just a thought. would the rudder angle cause it to dig in? lower tip of the rudder as fwd as possible, creating a small amount of downward force?
just a thought
Bill-SOCAL
01-14-2008, 12:20 AM
Take a look at this site. Tune up tips from the guy who designed the boat
http://www.aquacraftmodels.com/boats/aqub22-tuning.html
fastbaltek
01-26-2008, 04:46 AM
cf 45 is the way to go cheap and it works great.
