View Full Version : SeaKing 180 timming MG motor
pyroM!KE
02-20-2011, 10:08 AM
What should I set the timming to with my Miss Geico stock motor?
lectriglide
02-20-2011, 12:16 PM
4 pole motor between 10 and 15 degrees
pyroM!KE
02-20-2011, 01:18 PM
I thought the Miss Geico stock motor was a 6 pole?
lectriglide
02-20-2011, 01:55 PM
My bad, you are correct. Generally, 6 pole timing is between 10 - 20 degrees, but it all depends on prop and how the boat is run. Start with 10, run and check the speed and temps, then try 15 and do the same. Watch it real close with 20. IMO the best will be between 10 and 15. Let us know what you find.
pyroM!KE
02-20-2011, 03:17 PM
Thanks for the help..Im charging my batts right now to go to the pond..Damn its windy today!
