View Full Version : help
Hay guy's need some info I have a H/K eco 6/10 balance charger and itsay's Operating voltage range 10.0/18.0 volt /Can I use my laptop cord if it is over the out put range it says 65w/ac input 100/240v/50/60hz1.5a////out put 19.5///3.34a is the out put OK for the charger!! :help:
Too much voltage and not enough amps. Even at 20V you would need 12 to 15 amps, 4 to 5 times what your PS can provide.
I wouldn't even try.
I wouldn't even try.THANKS GP73 I think I will just go with hooking it up to my bat in my truck. or taking the bat out of the truck.
HYDROJERRY
02-21-2011, 08:42 AM
So i dont no but can anyone recomend a cheap power supply for his charger just in case he wants to charge at home,, im sure he'll get tired of charging off his truck!! I no i did...
LiPo Power
02-21-2011, 01:28 PM
PC power supply will do just fine ....
http://web2.murraystate.edu/andy.batts/ps/powersupply.htm
