View Full Version : timing for leopard 4082 1450kv 4d motor?
MARKY C
02-18-2011, 05:42 PM
am i right in thinking the timming on the leopard 4082 1450kv 4d should be between 0/10 or low timming setting?
Diesel6401
02-18-2011, 05:50 PM
Reference Neu Motors:
Use low (0-10 degrees)or medium(10-15 degrees) advance settings for “Y” wind motors and low (0-10 degrees) advance settings for “D” wind versions.
Igoreski
02-20-2011, 07:45 PM
Hope you can help with similar question on Leopard made for Tacon 4 pole motor.Here is the # of the 2 motors I am using for a cat. LBP 2860 B/4D 2550 kv.I am running both on 3s and need to know if I should use the low timing like all the rest of the D motors.The timing on my 120a ESCs can be at 0,3.75,7.5,11.25,etc.The data sheet has the exact same specs as LBP 2860 4D 2550kv.
Diesel6401
02-20-2011, 07:51 PM
That is also a "D" wind motor, your seaking timing is default at 15. Turn the timing down some. Try 3.75 or 7.5 make a note which works better.
Igoreski
02-20-2011, 08:16 PM
Thanks I had it at 7.5 for my 2 pole Feigao 380XLs which might have been wrong.Should I look for which draws less amps,less heat or most rpms.
Diesel6401
02-20-2011, 08:19 PM
Least amount of amp draw and heat would be best...
7.5 is a good starting point, maybe try dropping down one and see how it works out for ya.
Igoreski
02-20-2011, 08:49 PM
Thanks for the info.
