View Full Version : 6s miss geico
reefboy87
02-17-2011, 06:01 PM
im running the leopard 4074 1400kv 240 hydra 2 11.1v lipos on the octura x442 the motor is running very cool what prop should be the next step and at almost full speed it turns into a plane and if i put to battery up the boat just starts bouning what can i do it gps at 43 before it went up in the sky :help:
rchuntlsl
02-17-2011, 06:17 PM
Check your prop/shaft angle to make sure it parallel with the bottom of the boat and the center line even with the bottom of the boat. Run fecalc program to figure out what prop. Input your current set up, this will give you a good base line and then just keep putting in larger prop sizes till fecalc says you will burn up your esc. Good luck.
jac4412
02-17-2011, 09:37 PM
At 43 that boat should not be taking off of the water....
You have issue with the strut level get the thing to plane nice then work from there... I'd try a 3 blade prop
jac4412
I'm going to run a 42/55 on my 5s
reefboy87
03-10-2011, 02:15 PM
can you make the hydra 240 waterproof with liquid grip ?
shctexas
03-15-2011, 07:53 PM
I've run mine on 6s.....That thing jumped out of the water; good for 38mph. Temps were good but I haven't done it since.....time will tell. The MG is a reliable boat that will do what u ask.
PDR447
03-15-2011, 11:45 PM
38 that's all??? or did you mean 48?
Ripper
03-19-2011, 04:01 AM
Has anyone pushed MG passed 60 yet?
wilsta67
03-19-2011, 04:39 AM
as soon as my MG arrives i will be installing the same set up as my spartan and running 6s here is the vid
http://www.youtube.com/watch?v=8dTyfi8_agc
wilsta67
03-19-2011, 04:40 AM
i think she will be a wild time controlling it:buttrock:
Ripper
03-19-2011, 07:08 AM
Sweet! No handling problems there. Looks like you have it dialed in pretty well. Just runnin' on the prop.
