View Full Version : Anyone have use this motor?
Mel279
02-15-2011, 12:54 AM
hi guys
I was thinking of getting this motor http://www.rc-warbirds.com/product_info.php/cPath/67_130/products_id/1128
http://www.rc-warbirds.com/product_thumb.php?img=images/700-83_full.jpg&w=199&h=136
Here is the Specifications:
Recommended LiPo: 12S Lipo
Battery Dimensioning (90mm Fan): ~58A on 12S
KV: 975
Max Power (Watts): 3400
Poles: 4
Length (mm): 83
Dia (mm): 39
Shaft dia (mm): 5.00
Weight (grams): 460
Recommended ESC: Tsunami 100A
does anyone have ever experience using this motor?
Mel279
02-16-2011, 01:31 AM
guys
If I use two of these motors in my twin drifter M 36", 12s 5000mah, 2x 80HV seaking and 2x 40mm props. Is my setup ok or too overkill?:help:
oscarel
02-16-2011, 08:07 AM
I have a 700-68 that i've run in a 29" sprint cat and it ran great, they match pretty close to Neu spec wise.
Mel279
02-16-2011, 08:09 AM
thats great to hear, does the leopard 40mm waterjacket fits the motor?
oscarel
02-16-2011, 08:17 AM
If I remember the Neu jackets fit. Also I'm not sure where you are but here's where I bought mine http://shop.turbofanelectrics.com/product.sc?productId=251 they include shipping and that motor is $139 shippedhere. The 700-83 is equivalent to Neu 1518
Mel279
02-16-2011, 08:35 AM
Im from Brunei, the link of that motor is frm singapore, so its not far and much cheaper shipping. Could u give me the specific neu jacket that fit that motor?
oscarel
02-16-2011, 08:44 AM
Well if I look at this chart (http://www.offshoreelectrics.com/neu-motor-chart.htm) the 1518 is the same length as 1521 but I'm not sure about diameter. Here is the cooler for 1521 http://www.offshoreelectrics.com/proddetail.php?prod=ham-neu1521
Mel279
02-16-2011, 08:52 AM
I just saw someone selling the 1518 @ swapshop, its similiar to leopard 4082, so it seem that I can use the leopard waterjacket
oscarel
02-16-2011, 09:06 AM
This one http://forums.offshoreelectrics.com/showthread.php?t=21991 ?
Now that's the Castle 1518 not the Neu so the sizes are different. The Castles are finned and the one you're looking at it's smooth.
Mel279
02-16-2011, 09:18 AM
yeah I see its finned, hmm..anyway the 1518 waterjacket is the one that fit the motor that Im refering to, do u happen to know the I/D of the jacket?
oscarel
02-16-2011, 09:28 AM
No I don't know. Again make sure which 1518 you're looking at because there is a Castle/Neu 1518 an a Neu 1518 and the are physically different sizes. Here's the company that makes coolers, contact them and see if they can help. http://www.hrc-mfg.com/
Mel279
02-16-2011, 09:32 AM
ok thank you so much for your help, really appreciated :beerchug:
02-16-2011, 02:51 PM
...If I use two of these motors in my twin drifter M 36", 12s 5000mah, 2x 80HV seaking and 2x 40mm props. Is my setup ok or too overkill?...
That is not a good setup at all. The motor Kv is far too high for 12S and you will pull far too many amps. For 12S you will want a Kv between 600 and 700.
Mel279
02-16-2011, 07:50 PM
Even for twin drive its not possible?
