View Full Version : Leopard 4082 timing?
JPriami
02-14-2011, 02:59 AM
Just wanted to see whats the best timing for a leopard 4082 1500kv on a turnigy 180 esc. Right now I have it set to 15* and it seems good.
battlefury
02-14-2011, 03:23 AM
Likewise, i am getting a smoother throttle curve on 15 degrees timing which i find best overall. On that note i tried 0 to max 26.75? 26.75 giving me temp motor readings around 60 celcius on a two min run Yikes~ with a setup: 440 prop 6s1p
02-14-2011, 07:23 AM
Except for the 1450 Kv version, all 4082 motors are Wye (Y) winds. This means they like some timing advance, and depending on your use 10* to 15* should be good. The 1450 motor is a Delta (D) wind and timing should be kept between 0* and 4*.
JPriami
02-14-2011, 09:17 AM
Thanks for the info.
