View Full Version : Hifei Swordfish 240 amp
jjrctech
02-13-2011, 09:05 PM
HI
I have a Hifei Swordfish 240 amp conneted to a Leopard 5692 Motor
I put everything in receier and batteries and the esc turn on but does not work?
http://s1218.photobucket.com/albums/dd412/Jr_Jose1/And idea?
http://i1218.photobucket.com/albums/dd412/Jr_Jose1/IMG_0021.jpg
Thanks
oscarel
02-13-2011, 09:21 PM
Are you able to program iit?
Alexgar
02-13-2011, 09:30 PM
calibrate the throttle
Alexgar
02-13-2011, 09:31 PM
may need to rev throttle channel also(futaba)
Alexgar
02-13-2011, 09:32 PM
also youll need a reciver pack for that esc
jjrctech
02-13-2011, 09:35 PM
Yes it a futaba)
and the its does have batteries on the esc and the receiver
Alexgar
02-13-2011, 09:37 PM
rev the throttle channel and try and calibrate it does it make any noise when you plug it in
Alexgar
02-13-2011, 09:39 PM
here are the instructions if you dont have them
http://www.astecmodels.co.uk/pdfs/Swordfish%20200A%20ESC.pdf
oscarel
02-13-2011, 09:40 PM
See 112 and 115 http://forums.offshoreelectrics.com/showthread.php?p=179370&highlight=futaba#post179370
jjrctech
02-13-2011, 09:58 PM
the only way I have been able to calibrate it is with it full throttle and then full reverse to stop , I would like to only have to use the throttle ??
Thanks
jjrctech
02-13-2011, 10:36 PM
got it to work , but the Esc should not turn red at full throttle should it??
what should the Pwm 8khz or 12 , or 16 ?? in the program?
Thanks
Alexgar
02-14-2011, 12:11 AM
i have the 120 and i never even noticed an led
jjrctech
02-14-2011, 12:17 AM
leds on are on the bottom if esc , what i like to know if how to tell if the motor is reaching top rpm correctly? 5692 I have make a very quiet
Thanks
K.R.Joye
02-14-2011, 09:17 AM
Your short shrunk leads off the ESC motor end are scarin the heck out of me. Please insulate your connectors before the fire works go off.
