View Full Version : ProBoat 1/8 Miss Llumar Build
Doby
12-25-2007, 11:55 AM
I decided to start the build today. Still waiting on the majority of the hardware to show up.
Mounted the rudder bracket with 2 water "pick-up tubes" as well as the water "exit tubes" in the side of the hull.
For the exit tubes, I found two "Aircraft nuts" with plastic inserts and inserted a duplicate set of "pick-up" tubes through the inserts and then inserted the nuts in the pre-existing holes in the hull. With the "exit tubes" aimed to the sky, it should make determining the water flow very easy :smile:
Doby
12-25-2007, 12:01 PM
Here is another shot.
Doby
12-25-2007, 12:23 PM
Here are some more of the inside, with one of my 5S and 4S packs for scale. Theres going to be lots of room for 4 Battery packs:D
Diegoboy
12-25-2007, 12:34 PM
I wish I had a pair like that in the Miss Bud hull!!
txboatpilot
12-25-2007, 01:39 PM
Doby, the LLumar looks great!!:thumbup1: What motor and Esc are you planning on??
Doby
12-25-2007, 01:55 PM
Thanks TX;
I love my 1/12 Llumar version and the 1/8 should be even more fun.
As for the motor and speed controller, still a bit "up in the air", The speed controller will probably be one of the new High Voltage Hyrdas, They are good to 50V and come in a few different current ratings, Probably the 180 Amp version. The motor that was suggested by Daren Jordan is this one in the 1.5Y variation;
Product ID: neu-1527
Neu Motor 1527 Details
For years we had to buy European motors for top performance and workmanship! No More! Steve Neu has developed a line of Motors that can compete with the Hacker, Lehner and Plettenberg Motors of Europe! These Neu motors are unsurpassed in efficiency and torque! They are making and breaking many of the Fast Electric Boat records in the USA 2007!
1527 Specifications:
Standard KV Options: 1250KV, 850KV
Competition KV Options: 2160KV Extra $30.
Smooth Can for Water Cooling
Weight: 21.8 Ounces
Length: 4.00"
# of Poles: 4
Rm: .002 - .012 depending on winding choice.
Motor Shaft: 8mm
Comes with 4mm Motor screws.
Motor hole spacing is 1", most 540 mounts will have to be modified to fit this motor.
winds/rpm: Please Select...1D 2160KV (+$30.00) 1Y 1250KV 1.5Y 850KV
Price: $403.00
txboatpilot
12-25-2007, 02:10 PM
1527/1.5Y (850KV) Man thats going to be fun!!!:w00t:
SJFE
12-25-2007, 02:18 PM
Thank you for sharing this build Doby. I will enjoy it very much :D. It may even give me some pointers for the Vegas on a smaller scale.
Doby
12-25-2007, 02:36 PM
Thanks SJFE, hopefully pointers will flow both ways from all of us here at OSE:w00t: This will be my 4th "noise maker to swiftly silent" makeover.
1) My 1/12 Llumar
2) My BlackJack 26
3) My Aquacraft V-24
:olleyes: :olleyes:
Eyekandyboats
12-25-2007, 03:18 PM
i like that a 1527 in a 1/8th. . . . I plan on using a 1527 in a . . smaller boat then that. One size up from N2 mono ! Ahahaha but thats OK. i like to live on the edge ..
Doug Smock
12-25-2007, 04:49 PM
Nice!! Can we see her bottom?;)
Doby
12-25-2007, 05:03 PM
Doug; That's a bit personal, don't you think :glare:
:smile:
Here it is.
I don't think that you have suggested a motor for 8S-10S configurations,,,,would you like to "weigh in":confused1:
SJFE
12-25-2007, 06:06 PM
Any one know what diffrence the under hull strut is as oposed to the transom mount??? Better, worse trade offs..anything?
Eyekandyboats
12-25-2007, 06:44 PM
on a one 8th scale the strut needs to be mounted under the hull for scale appearance. If its mounted on the back it will be DQ'd.
it is fully adjustable ( in most cased) so there is no real disadvantage other then you need to seal the hole under the hull with caulking
Oh and there is to some extent a prop size limit. . . because it would hit the hull. But still you would need one HUGE wheel to do that
SJFE
12-26-2007, 04:15 PM
Gotach thanks :). I think I am going with the under hull strut. I like the look.
Doby
12-26-2007, 04:57 PM
Just want to say thanks to River Rat for offering his machine shop services to make my motor mount:smile:
There are good people here:D
Final design will depend on motor decision.
Doby
12-31-2007, 11:26 AM
Just got the remaining harware from Horizon !!!! The build continues !
Doby
12-31-2007, 04:35 PM
Rudder installed, Turn Fin installed, Drive Shaft installed,,,now, just need motor , speed control and warmer weather :smile:
Doby
12-31-2007, 04:36 PM
And one more;;;
tylerm
12-31-2007, 06:47 PM
Nice lookin man, wat rudder is it? have u got a link i like the look of it.
Tyler.
FE_Chris
12-31-2007, 07:28 PM
Is that a 6717 prop?
I loved that prop before I lost it! Nice boat man!
Doby
01-02-2008, 02:52 PM
Tyler.
Its all Pro Boat harware from Horizon Hobby, I'll attach a link later.
Doby
01-02-2008, 03:16 PM
Heres the link for all the hardware:smile:
http://www.horizonhobby.com/Products/RelatedParts.aspx?ProdID=PRB3250&Category=Parts%20Listing
SJFE
01-02-2008, 04:53 PM
I like that strut. I hope the 12th scale strut is the same. I think it would work out nice on the Vegas.
ReddyWatts
01-02-2008, 05:19 PM
1/12 hydro strut (http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB2508)
Doby
01-02-2008, 05:52 PM
Over the past few years, I have heard quite a bit of negativity regarding ProBoats products. I've now got 3 of their products and other than "self induced" issues, they have held up well and the quality is very good for the price, specifically the metal hardware. :smile:
Diegoboy
01-23-2008, 08:58 AM
Any updates Doby??
Doby
01-23-2008, 12:08 PM
Thanks for asking,,,I am currently working with RiverRat on a custom motor mount
that will use the stok mounting lugs seen in the photos, it will be adjustable for the motor angle, to help align with the flex shaft, as well as adjustable in a forward/backward manner.
I'm the holdup right now,,,waiting for Steven to get the big Neus in stock so we can finalize the design.
I'm currently adding foam flotation (spray can ) that will make the hull flex free .
Doby
01-24-2008, 08:06 PM
Well, ,,,,,,,motor selection has been made:thumbup1: and purchased:eek:
http://www.lehner-motoren.com/ms22.php?la=en
2280/12T:w00t:
Diegoboy
01-25-2008, 09:43 AM
Doby, Please keep me posted on this build. I have acquired the 1/8 miss Budweiser. I would like to follow you on this one (if $$ allows) I can't wait to see the awesome motor mount RiverRat is making for you. I may need one too! :o
Doby
01-25-2008, 10:07 AM
1/8 th's are nice and big aren't they:) But, everything else is nice and big as well, motor, batts, speed control etc $$$$$$$$$$$$$$$$:crying: :crying:
Motor, around $500
Speed Control, around $400
10S Lipos, around $1000
Tell Me,,,,Why do we do this to ourselves ??????????????
Bill-SOCAL
01-25-2008, 10:24 AM
2280/12T:w00t:
I run that motor in a large cat (AM Avenger Pro - 44") on 10S2P. It is also the motor that we have settled on along with the Midwest guys as one of the 3 we would use in our 1/8th scales too. I am setting up my 1/8th with a Neu 1527/1.5Y on 10S1P.
Doby
02-09-2008, 10:36 AM
Update time;
Still waiting on my motor from Fine Design,,,,,,I like Chris but his shipping is very slow.
Sent the motor specs to River Rat yesterday along with some dimensions for the motor mount.
Hopefully more updates and pics soon .
Doby
02-13-2008, 10:19 AM
RiverRat is working on the mount:rockon2:
As for the motor,,,still waiting,,,and waiting,,,,,:tongue_smilie:
Doby
02-16-2008, 10:39 AM
.........................And Waiting:frusty:
txboatpilot
02-16-2008, 10:59 AM
I need a 3060 as well, but I am going somewhere other than FDM!!
How long has it been, since you purchased the motor?
Doby
02-16-2008, 11:06 AM
3-4 weeks. He has always been reliable and I always get my stuff,,,,,,but he is sllllllllllllllllllllllllllllloooooooooooooooooooo oooowwwwwwwwwwwwwwwwwwwwwwwww .
justneedspeed
02-16-2008, 11:26 AM
Doby is this your only build or are you just working on this build?
Doby
02-16-2008, 02:25 PM
Just working on this one right now. Why ??:confused2:
justneedspeed
02-16-2008, 08:21 PM
Just wondering. I was going to say if you had the parts and time you could work on another project. I have to do something other than wait. You must be an extremely patient person.
Doby
02-16-2008, 09:40 PM
So True, but to many projects started at the same tme sometimes leads to none getting completed. I use the spare time to maintain the rest of my fleet and practice my flight simulator for my re-initiation into RC flight this year.:bounce:
Plus, shoveling snow takes quite a bit of time:cursing:
justneedspeed
02-19-2008, 05:03 PM
any updates to your build doby?
Doby
02-19-2008, 07:25 PM
Yup, Thanks for asking. Motor finally came in today:bounce: ,,,although the cooling jacket is on B/O.:frusty:
I'll post some pics a bit later
Doby
02-19-2008, 08:14 PM
Here are some shots of the 2280 next to a 9 XL for size comparison.
Stealth Assassin
02-20-2008, 08:33 AM
I like the motor mount Idea and what esc are you going to use?
Bill-SOCAL
02-20-2008, 09:59 AM
I strongly recommend using a mount that supports the motor both fore and aft.
Doby
02-20-2008, 10:22 AM
We think alike,,,RiverRat is making a 3 piece mount that will use the existing mounting studs in the stringers, both fore and aft.
Qty 2 "L" shaped brackets for the sides that will be adjustable up and down, and Qty 1 actual motor mount that will hold the motor and mount to the other brackets,,with adjustments fore and aft.
Should help a lot with alignment issues.:bounce:
Doby
02-20-2008, 10:24 AM
Probably a Hydra HV 180,,,if they ever get released,,or I could always move my Schultze 140/60 back and forth between this and my V-24. But that would be a pain, I would prefer a speed control in each.
Eyekandyboats
02-20-2008, 12:19 PM
Doby!
are you going to come play with us at centennial pond this year? we have 1/8th scales!
come on
Doby
02-20-2008, 03:13 PM
Where abouts is it ?????
Doby
02-20-2008, 03:19 PM
I have yet to "formally" race anything (trying to maintain my "amature" status)
I went to London this summer for a weekend of pit crewing for a friend. It was wild,,over 150 boats competing.
Right now we are trying to get legal rights to use a "Overflow pond" in Cambridge
Its perfect, fully accessable all the way around and in the middle of an industrial area by the big Toyota plant. No noise issues either as some guys like to run the smelly/ slimey/ greasy stuff!
Maybe we can get together if the winter ever lets go .
Eyekandyboats
02-20-2008, 03:58 PM
after no kidding about 25 mins of searching. . .
I found it. and THEN i found your post saying it was in the Toyota place.
URG LMAO
http://i152.photobucket.com/albums/s174/eyekandy19/doby.jpg
Doby
02-20-2008, 06:24 PM
How did you do the screen capture??????
Eyekandyboats
02-20-2008, 06:30 PM
go up in the top right hand corner of your keyboard. There are 3 buttons. first one says " prt Scr/sysRq
hit that button. then go into the paint program ( every computer has ) then hit "ctrl--V" and it will show up. then you crop it and such
Doby
02-20-2008, 06:33 PM
Thanks Man!
justneedspeed
02-24-2008, 12:02 PM
any updates doby or are you still waiting on parts?
Doby
02-24-2008, 06:59 PM
Waiting on the Cooling jacket and a 8mm to 1/4" coupler.
River Rat sent me a message last week that he has all the info he needs for the mount, so I assume its "in process.
As everything is forzen solid up here,,,,there is still about a month and a half left before I'll start to panic :bounce:
justneedspeed
02-24-2008, 07:06 PM
at least its not 70 degrees and your stuck without a boat.
Doby
02-24-2008, 08:06 PM
Soooooooooooooooo true !
Doby
02-28-2008, 05:57 PM
Just landed a coupler Woooo Hooooooo!
Details to follow!
txboatpilot
02-28-2008, 08:10 PM
Details to follow!
AWESOME MAN!!!! Cant wait to see this one all finished!!
Doby
02-28-2008, 09:52 PM
Me too, but no real hurry, its going down to -22C tonight with about 10cm of snow tonight. At least a month before any chance of open water.:crying:
Doby
02-29-2008, 08:59 PM
Just to let you all know, my source for the coupler is Steven V.
He has graciously offered one of his samples for my use. No Charge.:banana:
I'll post pics when it gets here.
Thanks again Steven:usa:
Doby
03-04-2008, 10:07 AM
Just got word from River Rat that the mount will be shipped today !!!!!!!!
Can't wait to see what he has created !
justneedspeed
03-04-2008, 02:41 PM
sweet cant wait to see it
Doby
03-07-2008, 06:12 PM
Got my coupler from Steven V today, I'll post pics a little later.
Doby
03-08-2008, 11:47 AM
Here are several shot of the coupler.
Now, waiting for the motor mount !
txboatpilot
03-08-2008, 11:56 AM
Very nice!!!! I thing I need one of those???
Lookin' good John!!!
justneedspeed
03-10-2008, 08:14 PM
Have you gotten your mount yet Doby?
Doby
03-10-2008, 09:18 PM
Nope, not yet. Things always seem to take a bit longer getting up here to the Great White North. Besides, 2 days ago we got another 1.5 feet of snow. There are snow banks 6 feet high around here right now.
Here are some shots of the tentative layout of everything.
justneedspeed
03-10-2008, 09:24 PM
i feel bad for you it 70 degrees farenhiet down where im at.
Doby
03-10-2008, 09:31 PM
Have a few runs for those of us that can't .....:crying: :frusty:
calcagno45
03-10-2008, 09:41 PM
Try 80-85 degrees without a boat(yet)
Doby
03-10-2008, 09:49 PM
Well hurry up and get one !:w00t:
calcagno45
03-10-2008, 09:56 PM
I'm working on it, thanks to txboatpilot i have a 30" Cat on the way to build up. Powered by a 9xl and unknown esc at the time.
The anticipation is killing me.
justneedspeed
03-11-2008, 06:13 AM
LOL Ill try i run my boats on the james river down in Virginia. It decides wether or not i can run due to wave height on windy days. Im trying to find some big coves near-by so i can run them more often but ill make a few runs for yall that cant run.:spy:
z400
03-11-2008, 06:08 PM
Woo
just went through this whole thread
Its Looking Good!!
gonna have some serious voltage i see.
cant wait to see some more pictures
justneedspeed
03-14-2008, 10:50 PM
Any updates Doby? :spy:
Doby
03-15-2008, 01:23 PM
You are an impatient one , aren't you?? :banana:
I got the motor mount yesterday and the workmanship from River Rat is first rate!
However, when designing something over the internet there can be interpritation issues ( as well as inadequate drawings from me ).
But hey,,,,we will adapt.
The side rails fit like a glove except the bow slots do not provide enough up and down movement to align the motor with the angle of the shaft. Right now that end is sitting on top of the existing mounting bolts. I will have to moe these mounts up ,,,,not to big of a deal. I love the fact that River threaded the holes on the side rail, no fumbling with hardware from below!
The actual mount is not high enough when mouting the motor the traditional way. The can hits the base and I still have to install the cooling jacket, If it ever gets here. (slight jab at Fine Design).
Now if I flip it around, everything is good....opinions, does anyone think this is a BAD idea, I think it would be fine.
Again thanks to River Rat for some first rate quality harware :bounce:
Doby
03-15-2008, 02:00 PM
SOLUTION FOUND !!!!!
I found the original Motor mounting brackets (for the Zenoah) that were supplied with the hull. Turned them upside down on the existing mounting bolts and PRESTO, the added height lines up the motor shaft to the prop shaft angle perfectly. :bounce:
Drilled a few new hole to line up with River Rats side brackets and the world is perfect again :banana:
justneedspeed
03-15-2008, 02:02 PM
Yes i am a very impatient person. LOL Im amazed i can sit down and build a boat. lol. Thats gonna be one sweet machine. Im living my dream through you. I want to build a 1/8th scale hydro but my pockets arent that deep yet. I love the bigger boats just as it get bigger seems to get more expensive. :sorry: If i seem pestering to you. Wohoo. Nice job with your build
Doby
03-15-2008, 02:13 PM
No Problem Man, just messin with ya :rofl:
justneedspeed
03-15-2008, 02:14 PM
ok, thanks for posting an update.
Doby
03-15-2008, 02:22 PM
Hey, I post updates when I have someting new to show,,,,now just waiting on my cooling jacket, CC to get off their butts and release the HV Hydra 180 and the snow to melt !
justneedspeed
03-15-2008, 02:36 PM
How fast do you think she'll run?
Doby
03-16-2008, 11:20 AM
According to some people, around the high 50's.
My GPS is waiting to be loaded as soon as the water clears !
justneedspeed
03-16-2008, 08:34 PM
Kool thats gotta be one sweet boat.
Doby
03-19-2008, 03:43 PM
Still waiting on delivery of my coling jacket (that was "in stock") that I ordered the same time as my motor from Fine Design...........not happy.:cursing:
RiverRat
03-20-2008, 05:19 AM
Looks like we could trim some weight off the side rails.
Thats a lot of motor. Does it need some support in the rear? Plenty of holes to work with, lol.
Mich. Maniac
03-23-2008, 04:41 PM
Hey Doby, this is one I cant wait to see run as well, I am wondering as to what prop you are starting with for tuning and if you have any specs and a link maybe. You are using 1/4" drive I take it? I didnt think OSE carried any that large and wondered if I could start a search soon for one of my own. At least I know who NOT to order it from!!! Hint Hint to FD. Thanks for sharing this build and hope the water loosens up the day after you get er done.
Doby
03-23-2008, 04:56 PM
Thanks Mich;
This has been one very slow thaw.:tongue_smilie:
I am using a 1/4" flex drive. All the hardware is from Horizon Hobby and is the stock ProBoat stuff. The props I'm initally going to use are;
Prop #1 will be from my AQ V-24 that I have lying around. Here is the link :
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMNM9&P=Z
Prop #2 will be a 3 bladed Vodoo prop thats also lying around. Here is the link;
http://www.voodooprops.com/ its a 65X18
I'll start with these and then I'm open to suggestions from everyone:bounce:
Still waiting for my cooling jacket that is apparently on B/O. I really wished I had waited for Steve to get the big Neus in stock and bought everything from him. This will be my last purchase from F/D. If the 180 HV Hydras are not released by the time the ponds thaw, then I'll probably use my Schultze 140/60 in the meantime, I just hate moving speed controlls from one boat to another.
Doby
03-28-2008, 12:33 PM
And the wait for the Hydra and the Cooling jacket goes on.
I did purchase a HV 180 from Castle directly but it will still be a few weeks wait. They were offering 25% off the price untill the end of March so it was to good of a deal to pass up.
As for the cooling jacket,,,,,,,,and FD,,,,,,:frusty:
Picked up some brass tubing to make up for the difference in the prop shaft diameter and the prop hole diameter. Cut them to size and it fits like a glove with no slop.:bounce:
Mich. Maniac
03-28-2008, 10:33 PM
try calling his goofy butt. Or call your cc company and tell em you were ripped.
THEN... order it from STEVEN!!! LOL
Or just dont use one for your first 30 second run. see how it goes. with the cold water you got there it might just be cold enought to wrap silicone tube around the motor a few times. OH OH how I hate the cold.
Doby
03-29-2008, 01:19 PM
Mike, I did get an Email from FD after 3 tries and it is on BO.....You are right though, it will still be pretty refreshing up here when the first run happens, so I can probably get away with out a cooling jacket for a few short runs.
62 bugzilla
04-01-2008, 03:48 AM
It's coming out great and can't wait to see vid. Before this thread I was on the fence about a bigger boat and if I were to get one if I would go conventional 2 stroke or electric and this has answered that. BRUSHLESS ALL THE WAY AND THE BIGGER THE THE BETTER. Thanx for all the pics and input from you and everyone else. I'm new to boats but been in rc offroad for 20 years and in the past 6 months with alot of help from this site I'm hooked in a big way!!!!Hope to post my first build in the future.
Doby
04-04-2008, 03:02 PM
And the wait goes on...............................:cursing: :swear: :angry:
Jeepers
04-04-2008, 10:15 PM
man i cant wait to see this thing run! nice build Doby!
Doby
04-04-2008, 11:22 PM
I just got offered a loaner cooling jacket from Txboatpilot (there are some nice people here) untill the FD "BO"' comes in. So thanks to that kind offer, this should be in the water in 2 weeks. The bigger ponds that I need to run the larger boats is still covered in ice , the smaller ones are going to get used tomorrow, time to get some boats wet after 5 looong months.
Woo Hooooo
Doby
04-07-2008, 09:50 PM
So, I fired up the LMT is evening using my Schultze 140/60 (as the HV Hydra is on BO....the story of my life !) and all is well. I love the sound of a BIG motor. TxBoatpilot has shipped the cooloing jacket for my "temporary" use (he will never see it again, but don't tell him that)
Its coming together !
calcagno45
04-07-2008, 10:36 PM
thats great. we all can't wait to see this beauty perform!!
Good luck.
txboatpilot
04-08-2008, 07:53 PM
HAHAHAHAHA,,, I cant wait for some video of this "Big Dog"......
Doby
04-13-2008, 02:22 PM
I cancelled my HV Hydra 180 on Thursday from Castle, they said a few more weeks for delivery. Steve mentioned he had one so I snapped it up, It shipped Friday,,,,so if all goes well, TX's cooling jacket arrives this week , the controller arrives this week,,,,,,then maybe,,,,,,,just maybe it will be in the water next weekend. A lot of things have to happen but its possible! I'm off now to run my SV with the 9XL.
Doby
04-16-2008, 05:49 PM
I got my cooling jacket today,,,Woooooooooo Hooooooooooooo!
Although I have to clarify that it was the "Loaner" (yeah,,,right) from TxBoatpilot:usa:. There are some good people here!
The one from FD is still nowhere to be seen:thumbsdown:
So if all goes well, this weekend might be the maiden voyage. If my HV 180 doesn't make it here by Friday, I'll use my Schultze. The weather forecast is 50/50 right now for the weekend.
txboatpilot
04-17-2008, 08:43 AM
[QUOTE=Doby;34990]I got my cooling jacket today,,,Woooooooooo Hooooooooooooo!
Just trying to help!:beerchug: Glad it got to you OK...
Now, LETS SEE THAT PUPPY MOVE!!!!!!!!:rockon2:
Doby
04-18-2008, 10:25 PM
Well; It looks as though it might get wet tomorrow. My Hydra is stuck in the mail for some reason so Schultze it is!
Here are some shots of the final setup, its cramped but should work !
txboatpilot
04-18-2008, 10:33 PM
Good Luck!!! Try and get some video...
What prop??
Mich. Maniac
04-18-2008, 10:35 PM
I just wish I was allowed those posters in the basement!!! Lookin good sir. Please share some vid.
Doby
04-19-2008, 05:06 PM
Went out today for the first time,,,ohhh the anticipation.
Boat in the water , powere up gently and went 20 feet, then stopped. I could here the motor spinning. When it got back to shore in about 30 seconds (it was windy) found the set screws on the coupler slipping. Tightened them up and repeated the launch, got plane instantly and went 100 feet till the same happened. Back to the dremel tonight !
Doby
04-24-2008, 07:00 AM
Well , Canada Post seems to have lost my Hydra , got my first delivery notice last Thursday,,,,,and a week later,,,,still nothing.
Eyekandyboats
04-24-2008, 08:37 AM
looks nice....
not surprising CP lost it.... they suck
Doby
04-28-2008, 07:24 PM
Canada Post found the package !!!!
Got it last night and will install it this evening, I'll post pics when done.
Doby
04-28-2008, 09:40 PM
Got the HV Hydra mounted. It would be nice if Castle would figure out a way to mount the capacitors a bit more rigidly. They seem a bit flimsy. Same on my Hydra 120 that I got last year. Now just waiting on one 6mm connector and LiPo's :w00t:
Doby
05-09-2008, 09:17 PM
Well, it looks as though tomorrow will be another attempt at getting in a run on this beast. Hopefully if all goes well I'll have some video as well!
SJFE
05-09-2008, 09:24 PM
Good luck man!! FYI if you want to bend lexan with out it bubbling I am told to bake it in the oven @ 250 until its plyable :wink:
62 bugzilla
05-10-2008, 03:16 AM
Good luck tomarrow with it and PLEASE take video can't wait to see it....
Doby
05-13-2008, 10:26 AM
Sorry I have not updated the thread on the run on the weekend.
It ran great for a lap, the 2280/12 planes it instantly, it was scary fast as well. On the second lap though, I had no rudder control so I shut it down and let it drift to shore. A few minutes later I found the problem,,,,the rudder broke off at the piont where the shaft meets the blade:w00t:
I must have hit something,,there are turtles around every now and then so maybe that was the cause. The rest of the boat appears to be fine. Anyway, I have a new rudder being shipped and hopefully it will be here for the weekend.
I have to say that a 1/8th scale boat is an impressive looking machine on the water, You really have to see one to appreciate it.
No video as I asked the girlfriend only to take some after a few shakedown laps.(just in case of disaster). I suppose she could have taken some vid of it floating back to shore.:bounce:
txboatpilot
05-13-2008, 10:43 AM
Did you run the Excite's??
Doby
05-13-2008, 12:03 PM
I did, they seemed fine after 1. 5 laps:laugh: :laugh: :laugh:
txboatpilot
05-13-2008, 12:39 PM
:beerchug: I think you will be pleased with thier performance!!
10gauge
05-18-2008, 11:35 AM
It would be great to see a video of the 1/8 scale Llumar! Good Luck!
Doby
05-18-2008, 08:21 PM
I'm going to try again tomorrow!
Doby
05-19-2008, 04:27 PM
OK,,,finally. Here is the vid. its of the first part of the run, never went beyond 1/2 throttle as it was blowing steady 20 Mph and gusting to almost 40 with about 5-6 inches of chop:w00t: Oh yeah, and it was only 8 Deg C up here, about 45 F so it was cold.
A few passes to make sure all water cooling was flowing I gave it a few half throttle bursts and it went like crazy!. The boat seemed nicely balanced. Just after the vid, I bought it in and all was nice and cool.
Sent it out and after a two more laps, it stopped:cursing:
It drifted to shore in about 2 minutes thanks to the wind. I pulled off the cowling and everything still nice and cool. The motor struggled to turn over, almost as though it was fried, but given the temps,,, it should not have been the problem. After a few more freezing minutes, I decided to call it a day.
At home it had the same problem,,,,I dried everything out and noticed some water in the Hydra. Castle says they are water resistant but I suppose not waterproof. I'll have to talk to Castle about methods for better waterproofing. I mounted the controller so it is in the direct path of the cowling intake to add some air cooling as well. Anyway, after a few hours of drying, the motor is turning over again like nothing happened so all seems to be good! (now if I can just program it!!)
More vid to come the next time I go out!
http://s167.photobucket.com/albums/u145/dobydog6507/?action=view&current=llumar001.flv
Doby
05-25-2008, 02:23 PM
Went out again today, much better weather. The thing flies, according to my Navbie GPS, 54 Mph !!!! Its scary, I kept thinking it was going to be air borne a few times. I think I need a bigger pond!
62 bugzilla
05-25-2008, 04:10 PM
It's great your finally getting to enjoy all your hard work and can't wait to see more vids as you get it more dialed in. So cool to see a big hydro like that at speed.
Doby
05-25-2008, 04:26 PM
Thanks Bug; Next weekend if all goes well, I`ll take the Camerman (in my case, Camerawoman:biggrin: ) along and take some more vid. I`m really not sure how much faster I want it to be.:flammes-09:
Stealth Assassin
05-25-2008, 05:42 PM
You need to learn to pull that trigger a little harder! :w00t: ;)
Doby
05-25-2008, 07:56 PM
I did today,,,Scary fast:w00t: :w00t:
Theres a different feeling waiting for your SV (300 bucks) to flip than there is waiting for your 1/8th (2000 bucks) to flip. Makes you think about your trigger finger just a bit more:flashfire:
calcagno45
05-25-2008, 07:59 PM
o boy!!! sounds like the Llumar got wet on top and bottom.... hope all is ok and a video is to come.
Doby
05-25-2008, 08:07 PM
Nope, she stayed right side up! Although there were a few tense moments,,hence the comments above.
Doby
05-26-2008, 03:09 PM
In case anyone is wondering,,,still nothing from Fine Design:cursing: :flashfire: :cursing:
SJFE
05-26-2008, 04:01 PM
I feel for you man. I bought that turbo tranny and I'm looking into a different source for gears & it hasent even arrived yet. If he is not going to do business why leave the site open?
Stealth Assassin
05-26-2008, 04:43 PM
Chris Is such a pain to talk to IMHO!
txboatpilot
05-26-2008, 07:16 PM
Ya,, where is my water jacket??? LOL:tongue_smilie:
Doby
05-26-2008, 07:24 PM
Right now its on a 54Mph Hydro,,,,catch it if you can:bounce:
Seriously though, if FD takes any longer I'll send you some $$$$$ for it if thats OK and then when the jacket does make it here (if it makes it here) I'll send you that as well.
He also owes me a wack of 6mm gold connectors.:cursing: :cursing:
The Excites are working well, after a 5 minute run they are barely warm. I'm tempted to try them in a 2S configuration and see how they do.
txboatpilot
05-26-2008, 09:23 PM
LOL,,, If I were there, I would chase you down with my Insane Cat!! Then take a look at my old jacket as I passed by!!! :tongue_smilie:
No hurries....
Hope you dont need them this season! HAHAHA
I would try it for a short run 1-2 min and check temps... How many mAH are you putting in each pack after 5min. ????
Doby
06-04-2008, 06:29 PM
Well, miracles never cease, my connectors finally showed up!!!!!!!:banana: :banana:
Unfortunately though, it still sucks to be TXBoatpilot as the cooling jacket is nowhere in sight:cursing:
Sorry Rich !
