View Full Version : leopard 4082
MARKY C
02-04-2011, 11:50 AM
can someone answer this for me would the leopard 4082 1500kv get higher top speed than the 1450kv 4082 and what speeds would they make using turnigy 180amp esc using x445 prop on 2x3's 5000mah 40/50c in series 6's
LarrysDrifter
02-04-2011, 12:04 PM
On a 6s voltage set up,the 1500kv will be 33,300rpm.
The 1450kv will be 32,190rpm.Thats only 1,110rpm difference.It might not even be noticable.I run the 1500kv version and love it.It has great top speed and low temps.
02-04-2011, 12:38 PM
The 1500 Kv motor is a 2Y while the 1450 Kv motor is a 4D. The 2Y wind will be slightly more efficient based on the Io and RM values, but the differences are small. As Larry said, you probably would not notice a difference in performance, but I'd get the 1500 Kv motor.
Karfrik
02-06-2011, 02:38 AM
sorry to chime on this thread,but what would you guys put on a 37" Aeromarine Sport hydro to be run on 6S and t180 esc? a 4082 or a 4074? what prop do you guys suggest?...........
Thanks,Albert
MARKY C
02-06-2011, 09:51 AM
i would use the 4082 with a 445 prop with the 1500kv or the 1450kv motor if running on 6s with a 37'' hull the 4074 is a bit small
LarrysDrifter
02-06-2011, 11:00 AM
You would?
m4a1usr
02-06-2011, 01:49 PM
Thanks,Albert
Neither of those motors are decent choices for that 37" hull. Maybe a 5682 2Y as its a larger diameter can and has more power then a 4082. The CC/Neu 1717 would work, and better then either the 4074/4082, plus its also only $70! To get your hull rock'n you should look at a 1521 or a 2250. If budget is tight get the 1717.
John
Make-a-Wake
02-06-2011, 05:29 PM
John
Did you mean a 1527, which is more on par with a 1717.................a 1717 is more powerful than a 1521. Never heard of a 2250..........
m4a1usr
02-06-2011, 07:31 PM
Lehner.
John
Karfrik
02-06-2011, 07:38 PM
John
Where can i get the 1717 for that price?.....
m4a1usr
02-06-2011, 08:02 PM
Here you go! Good motors too! I bet the sale is going to be ending in the not too distant future. Might want to get 2. http://www.castlecreations.com/promos/motor_clearance/motor_clearance.html
John
Karfrik
02-06-2011, 08:08 PM
Thanks!!!......Al
Make-a-Wake
02-06-2011, 08:15 PM
Lehner.
John
Oh...........sorry, i havent delved into the high end stuff yet........heard they are pretty much top notch.
scoota
02-06-2011, 09:07 PM
For those who are interessted i did some data logging with the 4082 in a DF33 on 6s & its pretty much on par with a NEU 1521 , in size & power . i dont think it wouuld be big enough for a 37" hull, JMO , well not if your after a good top speed ...
Running a X 648 prop
Peak AMPS - 193
Peak WATTS - 3691 / 4.94 Horse power
GPS - 62 mph
richt
02-07-2011, 08:01 PM
i want to see if you can halp me i have a 35 in mono will the 4082 1450kv with a 240hv esc on 6s with a x445. i want to get it up to 60 mph can you let me know.
Karfrik
02-08-2011, 09:01 AM
Peak AMPS - 193
GPS - 62 mph
Well,don`t really want to break any speeds records.....wanna go fast enough.Thats why im considering the 4082.Plus im running out of water where i go and run.....lol
richt
02-11-2011, 10:08 PM
can you halp me i have a 35 inch mono i have a castle 1520 1600kv with a 240 hv esc and 2p 6s what is the best porp i can run to get good speed.
thanks
Make-a-Wake
02-11-2011, 10:32 PM
thanks
X448 - x450
LarrysDrifter
02-11-2011, 10:41 PM
Start with an X445 and check temps.Move up from there if everything is good.
