View Full Version : Now lets upgrade some more stuff on the Spartan
JPriami
02-03-2011, 06:48 PM
Well I did a kick ass job with the new dual pickup rudder and cooling system upgrades. So let do a little more!
New Turnigy 180 marine ESC, Leopard 4082 1500Kv & Cooling jacket.
Fits in there all nice and snug dont you think?
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0583s.jpg
After doing the new rudder and setup I was able to keep the stock traxxas 36mm 1600Kv motor and ESC cool. Well under 90*F. So I felt I should have no problems keeping the new motor and ESC cool as well.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/29b99243.jpg
Cant wait to test. Too bad the weather is taking a dump for the next few days.
Make-a-Wake
02-03-2011, 06:55 PM
Now we'll all see the first 50mph Spartan for sure!
LarrysDrifter
02-03-2011, 06:58 PM
Nice.Looks great.I run the same combo on 6s in my 33"mono.I was seeing low 50's.Good luck Justin.Hope your water isnt solid in TN.If it isnt,Im coming down so I can run my boats.:just-kidding:
martin
02-03-2011, 07:03 PM
It will be interesting to see how the hull rides giving the side to side roll we have seen on this hull with the extra speed & torque that you should get with this set up esspecially if you put bigger props on. Lets hope the weather improves soon. Thanks Martin.
Make-a-Wake
02-03-2011, 07:07 PM
I'm thinkin' x447
JPriami
02-03-2011, 07:10 PM
Yeah I'm worried about that myself. In my other runs I had that problem at higher speeds sometimes. But I noticed battery placement helped. Also it didn't do it all the time. Seemed a little induced after hitting wakes. Still sucks tho. I'm going to try strut angles, props, trim tabs and battery placement. If I can't get it dialed in for good handling over 50. I think I'll just put the stock stuff back in it and sell it. Then use the stuff I bought towards another cat. Those genisis cats might be fun
JPriami
02-03-2011, 07:20 PM
Come on down Larry your welcome too. You can crash on the couch in the basement. Down there where I tinker on stuff. Bring a mini revo if you have one. I have a ramp down there too lol.
I've got some really nice lakes for running here. About 20 or so miles away.
martin
02-03-2011, 07:27 PM
I think the hull could benefit with either wider trim tabs are an extra set to get them closer to the strut because when the boat is at high speed up on the v theres no tab in the water. The tabs on the boat also look a bit on the short side as well. Thanks Martin.
JPriami
02-05-2011, 01:57 PM
So i hit 50.3 yesterday testing it. but I had to use an m445. i didnt have much luck with the prather 220. but my gps was acting up so I dont think the speed readings i got from the 220 were accurate.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/b203ebfc.jpg
The boat was still wanting to chine on WOT passes. I guess I will try adjusting the strut a little and maybe give the tabs a few turns down.
I wanted to ask do you guys think the stock traxxas servo of 80oz is enough for the rudder? I was wondering if the rudder could wiggle and cause the boat to act like its chine walking at wot.
martin
02-05-2011, 03:39 PM
If you look at most deep v boats around they use much wider tabs that go much closer down to the strut, When thats up on the v theirs no tab in the water. Thats also not a very powerful servo for a boat that size doing 50+ mph. Are the temps much lower now than with original motor & esc
Make-a-Wake
02-05-2011, 04:41 PM
Great, so the m445 worked out! The prather is just too much prop.
JPriami
02-05-2011, 05:32 PM
Today's new speed. 55.4mph
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/615a2e1f.jpg
Rumdog
02-05-2011, 05:52 PM
Do NOT put tabs closer to the keel. It will create even more lift in the transom in the straits and induce more chine walk.
martin
02-05-2011, 06:42 PM
The reason i said tabs further down towards the keel is i have a 15" mono deep v that runs 45mph & was getting chine walk to the point it would put the boat in. To the point i was practicaly destroying the boat each time it went in hiting the bottom of the lake. The boat did not have tabs at all, So i added a set down towards the strut & it has stabalised the boats chine walk but still has its speed. If the waters a bit rippley it will still go in now & again but not to often but on flatish water its stable where as before it would go in even on flat water where the chine walking completally upset the trim of how the hull ran. But this is on a 15" hull though. Thanks Martin.
JPriami
02-05-2011, 08:55 PM
Here is the video (http://www.youtube.com/watch?v=EUefZFohpEk)
EUefZFohpEk
There was only about one good pass. I think that's where it hit the best speed.
Boomer
02-05-2011, 09:12 PM
You do some fine work! Lookin good amigo!
Boomer:rockon2:
Brushless55
02-05-2011, 10:39 PM
EUefZFohpEk
Keep it going man!:beerchug:
Make-a-Wake
02-05-2011, 11:15 PM
Now you can call traxxas or post on their forum that "i finally hit 50 with your boat................................after major cooling changes and 200 bucks worth of upgrades"..............:bounce:
JPriami
02-05-2011, 11:17 PM
Hell man I think I should sell it back to them and say ok here is the v2 boat you need to make!
Make-a-Wake
02-05-2011, 11:37 PM
Yea............tell 'em this v2 will actually hit the 50 they claimed for the v1 turd.:tongue_smilie:
In my opinion, they really screwed the whole deal up....................months of hype, an original name that they stole...................months of peeling off all the titan stickers..................then an underpowered ABS boat that underperforms!!! Way to go Traxxas:ThumbsDown01:
Someone at Traxxas is gonna lose their job over this one........................:o
LarrysDrifter
02-05-2011, 11:41 PM
No,they will just promote them.
Brushless55
02-06-2011, 12:01 AM
:iagree:
100%
Brushless55
02-06-2011, 12:02 AM
and just think of all the young guys who buy this because of the 50mph+ posted on all these boxes..
dag-nabit
02-06-2011, 12:21 AM
Young guys??
Some of us old guys bought in too :doh:
Make-a-Wake
02-06-2011, 12:22 AM
Speaking of the boxes...................i went into my crappy local LHS...................i wont mention their name but the intitials are Hobbytown USA, and saw one Spartan sitting on the shelf. Asked the guy about it, he could care less if i had dropped dead, and I said "can i see the boat out of the box?" Well it was in a plastic wrap..............He said no, we cant open it. I said "What?.every other boat in the store is opened except this one." I have opened many boat boxes there, how do you know what you're getting otherwise............... I said "ok, then i'll just pay you for it, open it here, then return it right now", he told me it had to be in the original unopened packaging..................and I told him, "and thats the way its gonna stay as long as no-one is allowed to see and feel it"...............Traxxas wants it that way i bet.
BTW, these guys at Hobbytown USA could easily get a job in a morgue................i have given them too many chances to be kind and helpful..........they are complete idiots.
JPriami
02-06-2011, 12:27 AM
Thats just down right rude on their part. I've never had problems opening a box to check it out before you buy. But it wasn't at hobbytown. I did sorta know a cool peep that worked at one. Lost touch with him tho.
Make-a-Wake
02-06-2011, 12:31 AM
What were your temps with the 4082..........stupid low i bet...............70*'s?
JPriami
02-06-2011, 12:38 AM
I forgot to check it today. Had my girl and 18mo old son with me that's why I rushed back to the car. Plus it was cold like 33 and windy. I checked it Friday after I ran and hit LVC. The motor an esc were like 50/55.
Make-a-Wake
02-06-2011, 12:53 AM
Looks like you got a solid setup there!! Nice job.:thumbup1:
Brushless55
02-06-2011, 12:57 AM
Young guys??
Sucker!
:roflol:
JPriami
02-06-2011, 01:11 AM
I'm 35. But I feel like I've been here the entirety of our earths exsitance. And I'm still learning
Brushless55
02-06-2011, 01:22 AM
:thumbup1:
JPriami
02-06-2011, 03:07 PM
Well I changed out the rudder servo to a hitec 645mg (106-130oz tq) just to test today to make sure im not having issues with the stock traxxas servo(80oz tq). and trimmed the tabs down just a hair. hope it goes well.
Also Im going to try a onboard camera facing forward since i got it working again. It quit working when it was on my mini revo vxl doing about 60mph and flipped.
dag-nabit
02-06-2011, 03:30 PM
Go figure :roflol:
Kevin
JPriami
02-06-2011, 05:37 PM
ive got to just quit using that little camera on my rc's. i swear every time i use it just about on whatever vehicle there is an accident. This time the boat did a few flips. Camera stayed on. but it messed up the video so nothing got recorded.
GPS said 57MPH today. I dont know if i believe it or not. I think it was a fluke. so im not boasting that one till I reproduce it.
still got the death wobble. but its inconsistent i can make a few passes at wot and it rides right and wont wobble. seems to be when i gradually get up to speed it rides better
my temps were 60/65 on motor and esc. it was about 50 outside today
dag-nabit
02-06-2011, 06:40 PM
That 57MPH might have been air time :smile:
Too bad about loosing the video, would heve been cool to see the wipe out :Sinking:
Kevin
Hooligan
02-06-2011, 11:45 PM
Awesome, my first boat happens to be a Spartan. Are you going to push for 60Mph? I’d love to see it, lots of skeptics.
Best~
Brushless55
02-07-2011, 12:11 AM
Best~
Skeptics?
for the RTR but not this baby! :rockon2:
Make-a-Wake
02-07-2011, 12:54 AM
This may get you 60 if the hull can stand it.................m545, may be the ticket.
http://www.offshoreelectrics.com/proddetail.php?prod=oct-m545
JPriami
02-07-2011, 02:08 PM
I've got a m645 and a coulple other carbon props on the way. Ordered saturday.
martin
02-07-2011, 02:41 PM
An m545 should get you to around 60-61mph & an m645 should see 64-65mph, Should be interesting to see what the limit is on this hull though. Thanks Martin.
martin
02-07-2011, 02:45 PM
Have you scrubed the hull yet, If not its good to know you still have something in hand to possibly use. Thanks Martin.
JPriami
02-07-2011, 02:52 PM
I went over the ride areas with 1000 grit. That was before I read about other users using a lower grit.
Brushless55
02-07-2011, 03:19 PM
come on now! :rockon2:
JPriami
02-07-2011, 07:17 PM
Here is the clip where the GPS said 57mph Sunday. this was its first time in the water that day & on freshly charged packs.
I can only see one pass where maybe it did it.
PmF7OhH-pw0
JPriami
02-07-2011, 07:29 PM
Ive been thinking a lot about the chine walking issue. I tried to adjust the tabs but all that did is the boat seems to run with more of the hull in the water at high speed and its still chine walking.
It looks like the boat wants to twist (right side drops down) from the torque from the motor & pushing the prop into the water. I was wondering about weight placement. What if I stagger the batteries so that one of them on the left is up further so that it might be harder for the boat to raise that side. Or maybe I should put the GPS on the left side to add a little extra to make it harder to lift that side.Or should i drop the right trim tab down more to help push that back up? not sure about that solution though.
Its an odd problem because its inconsistent. I have been able to make some high speed passes without chine it just gets on plane and goes good. Seems that if i ease into wot it does better too. So i feel that something is exciting the chine and once it starts it dosent quit till you drop the rpms down.
Brushless55
02-07-2011, 07:58 PM
I place my gps on the left side and I think that helps my SV out
martin
02-08-2011, 10:03 AM
With the Spartan the weight inside the hull is distributed pretty much even i think, This dosnt help with torque roll. I know with the self righting boats theirs a lot more weight on the left side looking from the rear along with the flood chamber as well so theirs quite a lot off biased to the left. This seems to help reducing torque roll with this type of boat. Thanks Martin.
Rumdog
02-08-2011, 01:36 PM
This boat suffers from chine walk, not torque roll. Most all fast monos do since the ride right on the very rear of the hull (ride pad) if set up correctly. Weighting the port side will not change this. Prop walk comes into effect when propping to big for a give hull. Then it will tend to pull the starboard side down toward the water. The teeny prop on the Spartan isn't effecting it's handling.
The larger props JP is using may be causing prop walk however. Try adjusting just the starboard side tab a little bit negative and run the port side neutral. Or, try a prop with less pitch(lift).
jamespl
02-09-2011, 11:40 AM
With regards to the stock heat issue i have found that traxxas say there products can do something and they arent fibbing they just dont seem to be able to do it for long, take my rustler vxl for example, it says it can do 70mph with a 3s lipo and the right gearing- yes it can but for real world use around the street the heat it generates is unreal! so for day to day tyre bashing its no good and i would imagine its the same sort of thing with the spartan.
JPriami
02-09-2011, 12:18 PM
The fine print on my box say 50+MPH in the vehicle it's being hauled in when going to the lake.
Brushless55
02-09-2011, 12:19 PM
This boat was said to do 50mph+ out of the box on 6s
and it can't! :ThumbsDown01:
Brushless55
02-09-2011, 12:20 PM
:roflol:
jamespl
02-09-2011, 12:21 PM
Oh right. I thought it could do 50 on 6s but was getting stupidly hot!
JPriami
02-09-2011, 12:30 PM
Best speed i got on mine stock was 43. I think a little more might be squeezed out of it stock on a good day.
I hope the snow goes away soon. It's cold and sucks.
maxmekker
02-09-2011, 02:32 PM
Then come on over to Norway. :-)
ray schrauwen
02-09-2011, 03:32 PM
This boat suffers from chine walk, not torque roll. ).
Plastic hull.... :tape:
Darin Jordan
02-09-2011, 04:38 PM
:popcorn2: :tape:
Brushless55
02-09-2011, 04:48 PM
:popcorn2: :tape:
Big reason I'm sold on PB and AQ
they don't hype and lead the new guys on, and they build rock solid stuff!
oh and better yet PB and AQ actually listens to their customers and helps them out when things go wrong :thumbup1:
My Spartan is going right back to traxxas
they keep deleting comments and threads on their site that talks about issues everyone is having with the spartan :ThumbsDown01:
jamespl
02-09-2011, 04:55 PM
I'm not into bashing products but from what I'm reading most people that have this boat are very underwhelmed by it! When venom kept putting the P1 production back I thought about getting the Titan plus the impression I got with venom
Is that they weren't that good. I'm glad to say I went with the P1 and love it.
Brushless55
02-09-2011, 05:00 PM
isn't this called false advertisement? :spy:
dag-nabit
02-09-2011, 08:11 PM
Misleading at the very least.
I'm not sticking up for Traxxas, nor am I saying their hype and claims aren't over stated, but in reality this is nothing new in the marketing world.
Watch any Ford/Dodge/GMC pick up truck ad on TV and they all claim to be the toughest, most reliable, longest lasting pick up on the market, all the while showing video footage of them bouncing over boulders, rooting through mud with the tires spinning and throwing mud every which way, and then jumping the front end 2 feet in the air coming out of a ditch at the construction site. Yeah, you can do that a few times, but drive your truck like that on a daily basis and you will soon find out out how tough, reliable, and long lasting it is.
Or those commercials for those "certain" products for the ladies that show them swimming in the tropics, and riding horseback down the beach with big happy smiles on their face. Don't know about you fellas, but it don't work like that in my house. (well; maybe it would if I sent the ladies on a tropical vacation once a month, but they don't tell you that on the box)
Yes, it's wrong that Traxxas (and other companies) attempt to mislead us into believing their products will perform beyond what they are actually designed/intended to do, but it certainly isn't a new tactic.
It seems like everything about the Spartan has been a let down, but I'm thinking I can still have fun with my kids with a mid 40's 36" boat, as long as I can keep it from overheating without too much expense, and, if it proves to be reliable in the long run (which is debatable at this point, I know).
Kevin
JPriami
02-11-2011, 04:28 PM
Ok the ice needs to melt so I can go run again. its been almost a week. Got my new props to try. I need to sell these z06 motorsport wheels so i can buy some more lipos too lol.and maybe another catamaran
martin
02-11-2011, 04:54 PM
Ive got a 41" deep v Osprey hull which is one of the various DF knock off type hulls around & was looking at putting the same motor & esc into it as you have in the Spartan. Some recommend going to the Leopard 5692 in this size hull to get around 60mph but thats mega expensive with motor a 240hv esc + big mods to custom mounts & much bigger shaft & strengthening the hull bottom. Id be happy with high 40s in this hull that would be at much reduced cost & considerably less work useing the 4082 motor & t180 esc on 6s but not sure if this set up would be good in this hull. Thanks Martin.
Hooligan
02-11-2011, 11:32 PM
Kevin
Nicely said.... :thumbup1:
Make-a-Wake
02-11-2011, 11:41 PM
I bet you'd be suprised what that 4082 can do.................I'd throw an X445 on and watch her rip.......................................to about 45 or so.:rockon2:
Brushless55
02-12-2011, 12:44 AM
Kevin
no one claims to have a speed but Traxxas and no one can get to the said speed of 50mph
it's an outright lie
I think something should be said about this bogus claim :glare:
Diesel6401
02-12-2011, 01:01 AM
Traxxas prob hit 50, they just burned up a whole lot of motors doing it :laugh:
:rofl:
Brushless55
02-12-2011, 01:03 AM
:rofl:
I'm thinking they did it running it down hill! :roflol:
TazMotorsports
02-12-2011, 02:21 AM
Ran the Spartan today with the gps and it showed 48.7. Pretty close to 50 and its all stock. Lets see if I can get a better prop and hit the magic 50 number. Heading to Daytona later today to watch some racing. Might be next week sometime.:thumbup1:
dag-nabit
02-12-2011, 10:21 AM
True, but I was just illustrating the general concept that most products are marketed with exaggerated/accentuated claims as to how wonderful they are.
We don't know that Traxxas hasn't successfully achieved 50MPH with the Spartan during development and testing with the out of box components installed. With a perfectly dialed in set up, perfect water and wind conditions, high quality packs, etc. it may well have been accomplished.
EPA fuel economy ratings on vehicles is a similar concept. Take a vehicle that has been thoroughly inspected and dialed in by a team of mechanics and engineers, on a flat test track with a perfect road surface, no wind, correct tire pressures, at a steady optimum speed, etc, etc, and vehicle manufactures can achieve their claimed fuel economy ratings. In the real world, we never see those claimed fuel economy numbers, but they still post them on the window stickers and brag about them on TV commercials.
Different set of circumstances, same basic concept.
I'm more concerned with the reports of torched ESC's and overheated motors. I can live with 45-48mph instead of 50mph out of the box, if the Spartan can prove itself as reliable.
Time will tell if failed components affect only a small percentage of these boats, or if the Spartan is destined to be a lemon.
Just my opinion.
Kevin
Brushless55
02-12-2011, 11:32 AM
Just my opinion.
Kevin
not the same thing bro
if Traxxas says it does low 50's (50mph+), we should be seeing 51-54mph on 6s no matter what.. stock prop on 2 3s packs
and your epa comments...
EPA regulations are a lot defferent today even over the past 5-7 years
they take the cars and trucks and run them on computers and take them out in the real world with real conditions!
they don't run with a tail wind and tires over inflated to get more mpg that you and I would get in the real world
not a concept but factual data
just would be nice if they didn't have the lame claims and had good stuff like AQ and PB :biggrin:
JPriami
02-12-2011, 12:03 PM
Bored bored bored. Waiting for the sun to warm it up out there. Decided to start looking at the boat as I do my helicopters. And factor in balance. I made a level spot to set the V part of the hull on. Put a bubble level on the hulls flat spots . Then placed the batteries and stuff in. And I've noticed the right side is a little heavier. Prob the rudder. Then experimented with placement of packs laying flat and on their side along with and without gps. Found some good base spots that make the hull evenly balanced as a new starting point for weight placement. Aparently it' been a bit out of balance this whole time.
Darin Jordan
02-12-2011, 12:17 PM
Generally speaking... Monos tend to do a little better with a tad bit of weight offset to the LEFT... Helps to counter prop torque, and the drag/weight of the hardware on the right...
JPriami
02-12-2011, 12:23 PM
Thanks. I was thinking that would help. I was just suprised that where i thought it would be evenly balanced it wasn't. And where i had it balanced for more weight on the left it was really just about balanced even.
dag-nabit
02-12-2011, 12:32 PM
Just would be nice if they didn't have the lame claims and had good stuff like AQ and PB :biggrin:
I didn't say tail wind, I said no wind, and I didn't say overinflated tires, I said properly inflated tires. i.e controlled conditions.
And if you think vehicle emissions/fuel economy testing isn't done under controlled test conditions, you are living in a dream world bro.
From the EPA web site:
Certification Emission Test Data
All new cars and trucks sold in the U.S. must be certified to meet federal emission standards. This is accomplished by performing laboratory tests on pre-production vehicles. Most testing is performed by manufacturers at their own facilities. EPA audits the data from this testing and performs its own testing on some of these vehicles to confirm the manufacturers' results. All of this test data is available to the public for review and analysis.
Note that it says laboratory tests, and at the manufactures "own facilities". That isn't real world testing.
The EPA performs independent testing on some vehicles. Admittedly, I don't know if EPA testing is done real world, or in an independent test facility.
Concept is exactly the same. Real world performance may not equal performance under controlled test conditions, and manufactures are going to accentuate positive data to sell their products.
We as consumers have the choice not to purchase if we feel the manufacture is in any way misleading or unethical, or if we feel the quality of the product is sub standard. We can also file complaints with various consumer advocacy groups should we choose to do so.
I don't have any hands on with PB, but I agree with you, my AQ products have proven to be excellent.
Diesel6401
02-12-2011, 03:39 PM
:rofl:
JPriami
02-12-2011, 03:54 PM
I've got a nice traxxas bouy out here on the lake.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0017.jpg
JPriami
02-12-2011, 04:47 PM
JPriami
02-12-2011, 05:59 PM
Just got to the lake and was about to test my traxxas spartan after a few adjustments & mods. It ended up just going airborne and flipped then turned into a buoy. Ripped the canopy clean off the boat. Good thing I installed flotation on the underside of it. Had to call a friend to bring me my paddle boat so I could go get it.
Next time ill pay a little more attention to the wind and not head into it when testing a new setup at wot.
Damages so far just seem to be a busted rudder servo. Drying out the electronics now then will test later.
hCvDxDfKq4g
LarrysDrifter
02-12-2011, 06:41 PM
Whoops.That sucks.I lost a hatch on my old rat boat because I didnt feel like adding flotation to it.
Rumdog
02-13-2011, 03:08 PM
You may have hit something in the water there. Doesn't look like a blowover. Plus, the busted servo..
JPriami
02-13-2011, 03:18 PM
Maybe but not sure.
It happened after i gunned then throttle the rest of the way. I was testing a new prop. I think it started to wheelie up then there she went.
Here is a video I redid in slow motion.
AWyyLAYUxoc
martin
02-13-2011, 03:39 PM
I think that took off rather than hit something, It was coming up for to long before it finally went. Judging by how you can clearly see the spray coming of the prop being blown by the wind when the boat was first going away from the bank. That was going into what must have been quite a strong head wind when it lifted. Thanks Martin.
JPriami
02-13-2011, 03:47 PM
Yeah I'm sure the wind had a good factor in it too. Normally I go wot downwind when testing something new and not knowing what exactly to expect. This time I was being ignorant and not thinking about it.
Rumdog
02-13-2011, 03:57 PM
Yup. I can see it now in slomo
martin
02-13-2011, 04:26 PM
Nothing to do with this crash but is it me or does the Spartan appear in the pictures ive seen of the transom to have a much steeper dead rise angle than most of the good deep v hulls around. What affect would this have on this hulls running characteristics if it turns out to be steeper. Thanks Martin.
Make-a-Wake
02-13-2011, 04:34 PM
Watched it several times....................dont think it hit anything........it just took off.
JPriami
02-17-2011, 09:07 PM
Got to run today. It wasn’t to bad. I did jump out of the water hitting a wake but, at least it didn’t jump up and crash :D
I was able to run wot and make some really nice passes with no death wobble!
So balancing the boat (little heavier on the left) out seems to have really helped it.
Sadly I only hit 53.8Mph today with the M645 prop. I was looking for high 50’s :(. And 47mph on the M445 that I had previously reproduced a couple times a 54mph speed. Seemed odd.
I feel it’s a couple reasons (hopefully) something to do with the previous water crash and making it a buoy for about an hour and all the electronics got soaked to some degree. Even some was inside the esc case. I water proofed it a little better now. I think all the settings on the esc were wiped out. I didn’t think to check and reset them when I got the boat back together.
The other reason being I went airborne last time, this time I had the packs for weight up further in the hull. BTW I know this isn’t the main reason it didn’t death wobble because ive run with the packs there before and had the same wobble.
Now that I seen it go today and it ran nice, I will start shifting the weight back and see if it gets faster. If not maybe try adjusting the strut. I’ll be happy to get it finished so I can just go and run it with confidence on how it runs consistently. But then again it might sit on the shelf after that because I’ll need another challenge and something to mess with.
I just had a thought i need to test my gps too. It was soaked for that hour in the crash and didnt work for a while. I'll try it on the way to work tomorrow.
Brushless55
02-17-2011, 10:00 PM
Justin, I hope nothing is jacked..
if you do move your packs back some like 1" at a time or even just 1/2" at a time, you should see a bit more speed out of it.. :beerchug:
JPriami
02-17-2011, 10:17 PM
it was another windy day. here is a quick clip.
Hr8SqIHTuRg
Brushless55
02-17-2011, 10:38 PM
sounds really good man! :rockon2:
Make-a-Wake
02-17-2011, 10:56 PM
Give an x642 a try.......................it may suprise you.
JPriami
02-17-2011, 11:05 PM
I dont have one yet. So I wouldn't mind having one for the collection & to try.
dag-nabit
02-17-2011, 11:38 PM
lookin' good, she was really flying today.
Kevin
JPriami
02-18-2011, 11:42 AM
Hit 57.5 this morn b4 work. Moved weight back about 1.5 inches. But it's becoming unstable again. Going after work to try something else. Maybe try dropping the strut down to level. It's just slightly prop up right now. Or place the gps up front on the left. Idk. Open to suggestions.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/749bcde3.jpg
Brushless55
02-18-2011, 12:29 PM
yes! :thumbup:
drop the strut level
having it prop up a degree or to will cause it to get loose
JPriami
02-18-2011, 04:58 PM
dropped the strut back to level. didnt help. I moved the batteries back more forward too and then that didnt help. very weird. I left the batteries forward then started pointing the prop back up and it got better. this is nuts.
LarrysDrifter
02-18-2011, 05:21 PM
57.5mph!Thats sweet.
Brushless55
02-18-2011, 05:23 PM
:bounce:
JPriami
02-18-2011, 05:26 PM
that smilely face must be riding in my boat bouncing around.. lol
JPriami
02-19-2011, 11:44 PM
I have a question.
So the boat seems to run stable with no bouncing side to side when the batteries are placed up front and about an 1 to 1.5 inches back. And it seems to like the prop pointed up a few degrees. Currently 54.4 MPH stable running
When I start to place the batteries further back it starts to increase the speed but also starts to bounce side to side. I understand why btw im just asking what other experience with this sort of problem and the solutions they found.
what would be best? leave the batteries up front where it runs stable or place the batteries further back and start to use the trim tabs to see if speed can increase and still be stable? I fear the tabs will just add drag and sort of cancel it out, thats my theory anyways
Make-a-Wake
02-20-2011, 12:37 AM
Hey J, i found out after LOTS of testing that when the batts are back a bit, the stinger wants more positive......................tried it numerous times. One would think move the stinger down to get the ass up, but it doesnt work that way on my 39 incher..................go figure that out:tongue_smilie: ????
:beerchug:
JPriami
02-20-2011, 12:48 AM
Pointing it up will force the nose of the boat up and push more of the hull out of the water. less hull in the water will equal less resistance. but it gets to a point its unstable\loose in any craft. Then theres a balancing act to fathom. If you point the prop down it will start to force the nose of the boat down into the water and you will get slower (in most cases). im starting to feel 54.6mph is about max for what i have atm. i heard you mention the x642. im worried the smaller diameter may not do much for me. but it might work too. I was thinking a prop thats still 45mm but more pitch. idk.. might just heat things up more. COG for it being stable seems to be about 9 3/4in up from the transom. anything behind that its becoming unstable. anything more than that slows it down.
JPriami
02-20-2011, 09:13 PM
Look what I found.
Alternate mounting holes for trim tabs molded into the transom. They just are not drilled out.
I noticed on the prototype that traxxas has that there were holes in the back of the transom closer to the strut. I figured it was just from testing different setups.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0071.jpg
Brushless55
02-20-2011, 09:26 PM
yep, you could add a second set
I saw these when the prototype photos started coming out
not sure how this could effect things with two sets of trims tabs :huh:
JPriami
02-20-2011, 09:30 PM
me either. Rumdog mentioned it maybe a bad thing to have them further down towards the strut.
Brushless55
02-20-2011, 09:31 PM
I'm sure it will cause the hull to run higher out of the water.. :confused2:
JPriami
02-20-2011, 09:34 PM
today I got the speed above 54mph to 55.8 but stability issues still rearing their ugly head. I can ease into the throttle and it goes on plane nicely. if i gun it or if its hitting wakes when getting on plane it excites the chine and keeps doing it.
uyhmuzjz3uI
youtube may remove my audio. they did in my other video
JPriami
02-20-2011, 09:36 PM
probably so. :thumbsdown:
Brushless55
02-20-2011, 09:43 PM
looks good!
JPriami
02-22-2011, 03:02 PM
Today was a good day. Found the right setup. 58.9 MPH and stable.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/f9e8c49d.jpg
JPriami
02-22-2011, 07:09 PM
Made some adjustments. Pulled 58.9 MPH 2 times off the GPS. Boat was running really well. I still have about 5% of an issue with chine walking. But it was dependent on my driving. If I gun it hard it excites the instability when coming on plane and keeps doing the chine. If I come up one plane with a smooth throttle response it just gets up and goes nicely.
p8qqVqoa6aQ
link (http://www.youtube.com/watch?v=p8qqVqoa6aQ)
Brushless55
02-22-2011, 07:14 PM
looks good and sounds great Justin :rockon2:
JPriami
02-22-2011, 07:42 PM
I added a little bit of lift to the starboard side of the boat. It was an experiment of an idea I had. I planned on using the right trim tab down a little. But looking at the rudder I thought about using it to do it. Sound weird? I kicked the rudder very slightly forward, I had been running it just a little kicked back. because I visualized it being more level when the boat is on plane and slightly nose up. Now I think the very bottom of the rudder is acting like a trim tab under the water and giving the starboard side a little lift the way it is kicked forward a hair when the boats on on plane. Its working because I was able to move the batteries further back and it was still being stable with out chine like all the other times ive tried it. But it still seems to be better with the packs about 3" back from all the way forward. I didnt seem to gain much when I moved them back on one of the test today. I think the same can be done with the starboard (right) trim tab. And I may try it as well.
bigcam406
02-22-2011, 08:09 PM
great job!:thumbup1:
dag-nabit
03-02-2011, 12:10 PM
JP,
How did you mount your 180 Amp ESC.
It looks like you have it sitting on the top rail of the tray, what do you use to support/secure it in place.
Thanks
Kevin
JPriami
03-02-2011, 12:17 PM
I had used rubber. I had left over from a car restoration project. I cut it to match the shape of the esc. Had to cut two pieces to get the right height. Used 3m heavy duty trim adhesive to glue the two together. Then used 3m body molding stick tape to mount it to the tray and esc. It's pretty hard to get off. Even when it was submerged the time I buoyed it.
dag-nabit
03-02-2011, 01:31 PM
That is similar to what I was thinking.
I was going to try and find some lexan/plexiglass type material about 1/4" thick to cut to size and then epoxy or screw it to the bottom of the tray. Then use some thicker foam type (vibration isolating) double sided mounting pads, or velcro strips, to mount the ESC to the pad. It looks like I need to lift it just under 3/8".
I'm not sure how well epoxy will hold on the plastic tray. It has a lot of flex.
Kevin
JPriami
03-02-2011, 01:35 PM
Try that 3M double sticky tape for automotive moldings. Works great.
dag-nabit
03-02-2011, 08:54 PM
I will have to try and find some.
I decided I didn't want to epoxy it, in case I decide to change something later, so I drilled and counter sunk the 4 corners. If I can't find good sticky tape, I can bolt it in place. :thumbup1:
Kevin
JPriami
03-18-2011, 11:29 PM
I just ordered a Speedmaster 3/16 stinger. So im going to be changing out my stock one with this one so I can run 3/16 propshafts. I have a wire drive in hand I will be giving a try in it.
http://www.offshoreelectrics.com/prodimages/large__01_04_2007_15_57_speedmaster_stinger_drives .JPG
Brushless55
03-19-2011, 01:34 PM
it's going to look sweet on the back of this hull!!
shctexas
03-20-2011, 08:58 PM
Thats not a trim tab!<a href="http://s1197.photobucket.com/albums/aa425/shcaskey/?action=view&current=IMG_0003.jpg" target="_blank"><img src="http://i1197.photobucket.com/albums/aa425/shcaskey/IMG_0003.jpg" border="0" alt="Photobucket"></a>
shctexas
03-20-2011, 09:00 PM
It would have been funnier if I had posted correctly. Lets try that a gain. http://i1197.photobucket.com/albums/aa425/shcaskey/IMG_0003.jpg
JPriami
03-20-2011, 09:01 PM
yeah it is. lol its just a little one.
PS i edited and posted pic for u
shctexas
Now thats a trim Tab! http://i1197.photobucket.com/albums/aa425/shcaskey/IMG_0004.jpg
JPriami
03-20-2011, 09:03 PM
JPriami
03-20-2011, 09:04 PM
looks like a winner!
Did you have to make new holes?
Brushless55
03-20-2011, 09:05 PM
has anyone tried to run their spartan without trim tabs??
shctexas
03-20-2011, 09:06 PM
Oddly enough it fits in the outside primary trim tab hole and the outside "alternate" hole without modification. I wasn't looking forward to poking another hole in the hull. It's off-center outside 1/4".
JPriami
Can you show the old one held up to the new ones and place the old one about where it was on the hull originally please?
JPriami
link to what ones you got. that might be my next buy
shctexas
03-20-2011, 09:32 PM
This is the best single shot. The outside holes are aligned. The stock trim tab is about the size of the single outside "new" tab and in approximately the same position. It hangs off the back of the transom in about the same position as the stock. The new tab essentially expands the width. I bought it from Kinetic. I don't have the part number but I believe OSE sells the same unit. http://i1197.photobucket.com/albums/aa425/shcaskey/IMG_0012.jpg
JPriami
03-20-2011, 09:41 PM
Thanks for showing that.
JPriami
When you going to test it? Whats inside your boat? Lets see that too :D
shctexas
03-20-2011, 09:49 PM
Let me get this photo thing squared away. Photos too big. I'll post tomorrow. I followed the"priamod" program....Leopard 4082 1450Kv, Seaking 180a, x645 prop. She rocks.
JPriami
03-20-2011, 09:56 PM
Great!:rockon2:
:beerchug:
dag-nabit
03-20-2011, 11:22 PM
I will be interested to hear how those trim tabs work out for you.
And, of course some video if possible to see how your entire setup pans out.
Kevin
shctexas
03-21-2011, 09:54 AM
Oh, I forgot to mention that adjusting the inside right trim tab (looking at the transom) will be difficult to adjust. The rudder and adjusting bolt are competing for space.
JPriami
03-21-2011, 05:27 PM
Here is some food for thought. Ive noticed some spartan owners that have upgraded boats say that their boats run well on 6S and are not chine walking. Then some that complain that they cant get it tuned out. Then im sure some of us have seen pics of crooked holes for mounting the hardware. I noticed my strut looked like it was slightly crooked in its stock location. If you move the strut up or down and its not dead straight it would kind of angle a few slight degrees to the left or right. I wonder if thats causing some of these problems?
When I get my new strut Im going to dead center it on the hull and see how it goes.
Brushless55
03-21-2011, 06:45 PM
maybe another nugget to chew on??
some may not even know the boat is doing so when it does walk some and may think this is totally normal :huh:
ericwpg
03-21-2011, 07:47 PM
Nitro Chicken
* View Profile
* View Forum Posts
* Visit Homepage
Nitro Chicken is offline
Traxxas Employee Nitro Chicken's Avatar
Join Date
Jan 2001
Location
Chicken coop
Posts
5,280
Hello Guys, Our engineers are looking into the reported issues and are certainly aware of your concerns. Reporting the issues you are having is one thing and there is nowhere on this board that says you cannot do so. Many people have already posted their boat issues and have had no problem with the Mods or management for doing so. Bashing Traxxas is a different issue altogether and if you cannot state your vehicle problems without flaming us then it is better that you do not post at all because I can assure you that we do have an issue with that. This is clearly stated, yet again, so I expect no surprise from anybody who receives infractions for flaming or Traxxas bashing.
ericwpg
03-21-2011, 07:48 PM
I just found this on the Traxxas site and thought it was interesting. Oh i see now that its awful old too which makes sense really as i don't think there's been anything lately from the responsible parties ...... Just waiting for parts and spring
Brushless55
03-21-2011, 08:13 PM
What's lame in my opinion is the fact that many threads and lots of comments (not traxxas bashing) of this boat, have gotten the ax on those forums! :glare:
JPriami
03-23-2011, 09:14 PM
Speedmaster 3/16 strut/stinger installed! Wire drive installed. Bench tested. Great! Now to put the rest together. Hope to try tomorrow.
JPriami
03-23-2011, 10:20 PM
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/42052447.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/3f9597a2.jpg
Brushless55
03-23-2011, 10:23 PM
that strut looks good man!
dag-nabit
03-23-2011, 10:45 PM
it does look good,
How well did did the mounting holes line up with all the plastic ribs etc on the transom.
Kevin
JPriami
03-23-2011, 10:55 PM
Top bolt came out in odd place.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/b8b345d1.jpg
I would of put a spacer there but don't have one. The washer is grabbing pretty good though.
Maybe I'm getting sick of this boat I'm getting sloppy.
ericwpg
03-23-2011, 11:06 PM
Great looking parts, And hopefully a good strong final drive for the rest of the gear. was it expensive? If you don't want to say I'll understand
JPriami
03-23-2011, 11:07 PM
$40 for the strut/stinger here on ose.
JPriami
03-23-2011, 11:14 PM
I also rounded off the end of my rudder. Should help chine walk too. And keep the rudder from being a lift point.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/b08a58f8.jpg
ericwpg
03-23-2011, 11:25 PM
40 bucks seems reasonable and rounding the rudder will be copied by everyone in a couple days I'm sure. Did you sharpen the turn fins too or was that done earlier?
JPriami
03-23-2011, 11:26 PM
I was first one to point out the turn fins and rudder needed sharpening ;)
ericwpg
03-23-2011, 11:38 PM
I was wondering how i came up with such a good idea! I'll try not to tell you your own advice in the future. Man that was fun...
JPriami
03-23-2011, 11:42 PM
Lol. It's all good.
ericwpg
03-23-2011, 11:49 PM
How big is that tube it looks much much smaller than the original monster on the boat and if it is then the bend should be better too right? Thanks j
JPriami
03-24-2011, 12:01 AM
What tube. I'm lost. It's late and my brain isn't working as well. :)
If your referring to the stinger tube it is a little smaller. The stock strut held a .195 propshaft. The new stinger holds a 3/16" .187 propshaft. But the stuffing tube inside the boat to the motor is stock. For a .150 flex. But I'm running piano wire drive .078 into a .187 propshaft.
Like these.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/239fefa6.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/654b0eea.jpg
ericwpg
03-24-2011, 07:31 AM
Nice Pictures and those shafts look cool. Is the plan to put a different Teflon sleeve or a smaller stuffing tube to take up the .072 difference in size or does that not matter? I thought(sorry about that) the wire might whip back and forth in the liner and maybe leak.
JPriami
03-24-2011, 11:46 PM
I ran 2 times today. Once in the morning then once in the evening. Both times with good results. Nice plane across the water at WOT. Speeds were pretty consistent between the runs 58.5Mph. Only instabilities were running over my own wake just right or when the wind would blow and make little waves in a certain area it would jump out of the water. I have some video but Im having trouble getting it up. I'll try to see if I can get the full video I made uploaded tomorrow.
For now I am making a clip to share that should be up shortly.
Brushless55
03-25-2011, 12:19 AM
so it sounds like this is working better for you?
JPriami
03-25-2011, 12:22 AM
0gWBGYlK7bE
Brushless55
03-25-2011, 01:02 AM
Dang that looks good man!
what prop are you running in this vid?
ericwpg
03-25-2011, 07:02 AM
So smooth. J I really hope this is fixed now so you can have your spare time back, We've been asking for allot lately. Looks great though Thanks !
JPriami
03-25-2011, 01:12 PM
quy9dYAmMwY
YouTube (http://www.youtube.com/watch?v=quy9dYAmMwY)
ron1950
03-25-2011, 02:54 PM
looks like u really hit the setup this time j
tomjr
03-25-2011, 04:12 PM
very nicely setup spartan......
Well almost perfect....
tomjr
03-25-2011, 04:13 PM
Can traxxas just bring back your boat and come out with a version 2......
JPriami
03-25-2011, 05:05 PM
Thanks everyone. It's been fun and agrevating all at the same time.
shctexas
03-26-2011, 06:12 AM
Ok, questions. The wire drive...where did you get it? I recall that someone might make them for the Spartan. Can a drive that is too long be cut down to the correct length? The Sppedmaster you got here, correct? Great job! Tra**as should contract your skills for their next project.
JPriami
03-26-2011, 09:52 AM
Yes got the stinger here on ose. the wire drive I got from Ben over at fightercat.com Jeff Wohlt makes them too rcraceboat.com They can be cut to length. Steve sells them too here on ose.
Shaun78
03-28-2011, 07:26 PM
in the manual on trim tab adj. says angle tab down will force bow down. If prop torque pulls boat to the right then wouldnt you angle the left tab down some to drop the left side bow to compensate? i set mine that way and it seems to run stable as long as batteries are more towards the front. Anyone else try that?
JPriami
03-28-2011, 07:39 PM
the torque will twist the boat hull to the right. that can be adjusted a little by right tab down. Ive found the boat doesnt twist as bad if you ease into the throttle. If the boats twisting really bad & cant seem to be adjusted out it can be a sign of the drive cable binding. Ive seen it many times on these boats.
Bigbore
03-29-2011, 12:11 PM
Like these.
http://img.photobucket.com/albums/v337/Jpriami/239fefa6.jpg
http://img.photobucket.com/albums/v337/Jpriami/654b0eea.jpg
Are you using a teflon tubing inside your stuffing tube? What's the outside diameter of your stuffing tube?
I have the same .078 wire drive with 3/16 prop shaft on my Titan 29" that I got used. From the beginning I had to fix the leak from the stuffing tube. In my case the stuffing tube were a 5/32" brass for Octura .098 Flex Cable ... I guess by measuring it and had no teflon tubing inside stuffing tube.
Now I have to test a new idea. A two pieces stuffing tube with a silicone tube (2mm inside diam. and 4mm outside diam.) that fits tight on the .078 wire drive and on the smaller stuffing tube. It could have more drag and in that case I will go back with the original stuffing tube.
One last question: What bullets are you using on the motor wires? The stock 4mm bullets of my Leopard 4074 are getting too hot and I will try the EC5 5mm type.
http://img843.imageshack.us/img843/3413/imagetay.jpg
http://img593.imageshack.us/img593/3300/imageyh.jpg
http://img703.imageshack.us/img703/4174/imagesoc.jpg
JPriami
04-03-2011, 08:48 AM
No GPS to use yesterday. It got wet and quit working on me. But it's no doubt doing low 60's in this clip. And I cant hold the throttle down for long it gains speed and becomes unstable again. Huh go figure. Lol
clHNodOVo7Q
JPriami's Mono (http://www.youtube.com/watch?v=clHNodOVo7Q)
JPriami
04-03-2011, 08:50 AM
BigBore I'll answer ur questions soon as I can. I'm not near the boats to check and measure right meow.
dag-nabit
04-03-2011, 08:51 AM
clHNodOVo7Q
Too cool the way it wants to jump out of the water when you pin it. Almost like your cat now.
What prop are you running in the vid??
Kevin
JPriami
04-03-2011, 09:01 AM
I'm not telling yet ;) that was a raw prop I need to finish so it still needs to be balanced and a little better sharpening. I just wanted to see if it was worth me putting work into finishing.
Shaun78
04-03-2011, 09:29 AM
Awesome, I'll take it....
Brushless55
04-03-2011, 09:50 AM
Awesome hole shot!
that's killer :rockon2:
dag-nabit
04-03-2011, 10:56 AM
Men with dark glasses will be arriving at your door soon :cool2::cool2:
Kevin
shctexas
04-03-2011, 06:41 PM
Great video title.... "experimental mono"
JPriami
04-03-2011, 10:09 PM
Yeah I'm not helping their sales with my hard work on any new things I do.
Brushless55
04-03-2011, 11:33 PM
lots of blank photos over at traxxas :roflol:
