View Full Version : props for my UL-1
wild bill
02-03-2011, 12:28 AM
any suggestions on props for my UL-1.we can't change motor or esc in boat (club rules).i am currently running a octura 440 3 blade or 442 2 blade.
Shooter
02-03-2011, 09:26 PM
Haven't run the UL-1 in a year or so, but the 440/3 is a great all around prop. If you want to push it, try the grim 40x57/3. Make sure it is REAL sharp. It will probably cavitate a bit on start, but when she catches, hold onto your hat!! Watch temps closely though and make sure you've added caps if you have an older esc. Good luck!
m4a1usr
02-03-2011, 10:51 PM
Look in the "Aquacraft" section on OSE. There is a UL1 area that has some decent info on prop choices. You can go up to a M445 using the stock components providing you move the strut down some. Do a search and it all there.
John
LiPo Power
02-05-2011, 01:03 AM
Hey try on Grim L45x68 and stock ESC and motor!!!
That thing will fly!! Slow down a little when turning!
Robert
wild bill
02-05-2011, 01:31 AM
thanks guys.i will give those props a try.i heard a h-5 prop might be a possiblity also. any opinions?
wild bill
02-07-2011, 12:26 AM
ok guys:i was looking thru my prop box & ran across a grim L40x67.do you think this will work? boat won't get on step with stock strut setting.any sugg's
detox
02-07-2011, 04:01 PM
M445 is a verygood prop. Everybody needs one of these in their prop box.
