View Full Version : L&R prop choices ?
drwayne
01-31-2011, 08:11 PM
Hi
anyone willing to share a list of available props for twins ?
W
forescott
01-31-2011, 08:33 PM
Most common is probably the x442. Also x447/cf-40/venom 32 & 36mm 3-blades. Kintecracing sells a 38mm 2-blades. Just skim through the prop section of the ose store.
Rumdog
01-31-2011, 08:44 PM
Check here sir: http://www.prop-shop.co.uk/
drwayne
01-31-2011, 08:57 PM
cheers, gents.
Im back to work !..
Mid day here in Au.
Wonderful day of 38c ( 100+f )
W
LarrysDrifter
02-01-2011, 12:25 AM
100+ degrees.That would feel great right now.
video200
02-01-2011, 01:40 AM
propshop UK make some damn nice props. a little sharpening and you good to go :thumbup1:
egneg
02-01-2011, 01:59 AM
ABC also has a pretty good selection.
drwayne
02-01-2011, 03:55 AM
When the hull arrives I will start to configure motors / watts and work from there.
Ta
W
:beerchug:
CornelP
02-01-2011, 04:29 AM
A good range of props is here:
http://www.tenshock-motors.de/Prop-Schraube-Aluminiun-prop-CNC_1
but I have no idea how good these are...
drwayne
02-01-2011, 04:36 AM
super light, cannot sharpen due 'soft' Alu, folds easy.
but ta for the thought !
Im smiling a lot at the ABC range . :smile:
carlcisneros
02-01-2011, 10:34 AM
you can't go wrong with the ABC props.
I use the only these days.
more efficient than the Octura props.
just have to set the strut up different than with the Octuras. (flatter)
just start on pitch range less than an X series and have fun.
Thats a CMB 90 powered insane mono with an ABC prop on it
in my avatar.
Rumdog
02-01-2011, 01:35 PM
Are these for your Maritimo? What will power be, and your speed goals?
drwayne
02-02-2011, 07:40 AM
A: Yes
A: 6S45C5000
A: warp 3
When hull arrives I will scrutineer and work from there.
Ive read of 9XL, 1415 and 1512 .. plenty of options..
W
Rumdog
02-02-2011, 09:03 AM
X442's will be enough for low 70's on this hull. I've got a twin Timo on the way myself.
drwayne
02-02-2011, 09:21 AM
/2 or /3 ?
motors ?
W
egneg
02-02-2011, 05:59 PM
/2 or /3 ?
motors ?
W
442's are /2
Boatman
02-02-2011, 06:05 PM
I don't see that unless you are using like 45k rpm neu motors. 447's yes. maybe that is what you meant. Running 447's would need some 10xl's or at least 1512's
Boatman
02-02-2011, 06:08 PM
8xl motors on 4S each to 442's yielded only low to mid fifties. That would be around 29k rpm unloaded. If you could run some 1515 1y's on 6S. Now THAT would get er done with 442's
Rumdog
02-02-2011, 07:10 PM
You are correct about the rpm. I used 442's in my Aeromarine Sprintcat. It's a 35" hull, but much larger in volume than a Timo. I ran twin Neu/Castle 1515 1y's on 5s1p each with 442's and it was in the low 70's. It was a reliable setup as well. http://www.youtube.com/watch?v=wW5O3sMSBkE
Boatman
02-02-2011, 08:23 PM
wow, do you still own that? Also that is a nice lake you have to run on.
Rumdog
02-02-2011, 10:04 PM
Yup, I've still got her. Don't think I'll ever get rid of this boat. Started as a nitro, then single FE with a 1527 1.5d, then twin 1515's. I may have a pair of x447's cut down to 45mm for my Maritimo though and run a little less rpm.
Mel279
04-05-2011, 07:57 AM
I've just contact propshops uk, they say, all the props that being order by their customer are sharpen, balanced and polished before they ship it. I haven't bought any prop from them but seem the price are pretty convincing:biggrin:
video200
04-05-2011, 08:00 AM
yes they are balanced. and sharpend.
they just not SHARP. compared to a raw prop from prather or octure they are brilliant. if you used to a b\s prop from OSE,cmdi or eggnegg and so on. they are not sharp at all.
