View Full Version : Is an Octura 1740/3 a good prop for....
Karfrik
01-29-2011, 02:48 AM
a 25" Maus/Bandit shovel running on 4S,Ammo 2300,MissGeico/proboat esc?......does it has the right lift for it or is it overkill?....thanks,...Al
dasboata
01-29-2011, 05:12 AM
1700 series are good for outboard riggers try it and see good luck !!
Chris Harris
01-29-2011, 07:30 AM
To expound on what dasboata said the 17 series are about the highest lift props Octura makes. The reason they work so well on O/B hydros. You may need to do some mods to the prop to make it work on a sport hydro and/or use a very high strut setting to compensate. We use to run 17 series a lot in oval riggers and they performed really well. Because of the blade progression they are very effecient but they do require a little different setup than lower lift props.
Chris
Karfrik
01-31-2011, 01:08 AM
thanks guys,...anyone more suggestions on this prop?.....bump!!!
egneg
01-31-2011, 02:03 AM
I run a Prather 215 in my Campbell Vintage shovel on the same motor.
