JPriami
01-27-2011, 09:36 PM
So the other day I ordered some stuff from here on OSE. Heres some of what I did to make the cooling system better.
Speedmaster 4" setback Dual pickup Rudder (http://www.offshoreelectrics.com/proddetail.php?prod=ros-rud-dual-tap)
large diameter cooling line (http://www.offshoreelectrics.com/proddetail.php?prod=ose-tubing-1%2F4-clear)
540xl cooling jacket (http://www.offshoreelectrics.com/proddetail.php?prod=ose-mjacket-XL)
one gundert water pickup (http://www.offshoreelectrics.com/proddetail.php?prod=gnd-4191)
I modified the speedmaster transom bracket to fit on the spartan hull where i needed it to be.
trimmed down the rudder itself. so now its just under 1/2 longer than the original traxxas spartan rudder. Put a few reinforcing bars on the back sides of the nuts to the bracket bolts inside the transom
Drilled new holes for the dual cooling lines. because i utilized the old cooling line hole for one of rudder bracket bolts.
Installed the new cooling jacket on the motor. Ran 2 separate lines from the rudder one for the motor one for the esc. drilled a couple holes on the right side of the spartan in accordance to spacing of the other water outlet and used the gundert water pickup as a outlet because it was a closer match to the stock water outlet. So now there is an outlet on each side of the boat. one for the motor one for the esc.
Ran the boat on the stock NiMH packs at full throttle for several mins. Checked the temps, and got about 51 degrees F.
I'll try 6S run hopefully tomorrow.
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0457.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0459.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0462.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0466.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0464.jpg
http://img.photobucket.com/albums/v337/Jpriami/Traxxas%20Spartan2/IMG_0467.jpg
Justin
Justin
