View Full Version : 15" Small Bolt micro hydro
Basstronics
01-25-2011, 01:01 PM
I am going to be reworking my 15" Small Bolt micro hydro.
It is one from Hobby King. I have upgraded the ESC to a 30A Etti and a traxxas servo.
Anyone else have one?
SweetAccord
01-25-2011, 01:25 PM
I have another one on the way. The first one was damaged via postal and I get to keep it so extra parts, and another one is being sent. I'll probably swap the motor out for a 3900Kv and use a 30A Seaking ESC.
Basstronics
01-26-2011, 08:54 PM
I see you edited your post. I started the Small Bolt thread on RC universe. I find myself calling this board home over the others.
So I decided on a theme for the boat. Now I need someone who can make me decals! I also picked up the paint.
Can anyone guess the color? lolz
This is my first boat/decal graphics design. Is there anything else I should add? Im a fun run person, no racing.
I got some putty to sand and then to the paint booth- AKA the basement... Hopefully I can get the paint done over the weekend. Two coats of Rustoleum and no clear (for now).
Nice micro hull bass! If you need someone to do the decals try monojeff he did a nice job with my mini befu cat hull,:thumbup1:and hydrojerry's:popcorn2:
Basstronics
01-26-2011, 09:15 PM
I got a PM into him with no response as of yet.
wparsons
01-27-2011, 02:52 PM
I've got one, stock except for an x632 prop and some block sanding to the sponson bottoms. I also cut a bit off the stuffing tube so I could get a bit more negative angle on the strut. I've also reinforced the transom with some 1/32" ply after hitting a stick and breaking it apart a bit.
http://vnc.thewpp.ca/photos/toys/IMG_0624_1024.jpg
I've been thinking of repainting it, but I think I'll just leave it as is for now.
SweetAccord
01-27-2011, 05:36 PM
LOL! I removed my post after I realize you are the same Basstronics on there as you are on OSE. I'll give more input on this hydro when I get it and how it compares to the Minicat hydro.
igottalongone
01-27-2011, 05:41 PM
http://www.youtube.com/watch?v=H61Nu-FFmnc
http://i43.photobucket.com/albums/e395/igottalongone/WannaRace-1.jpg
CaptPJB
01-28-2011, 10:58 AM
Was considering upgrading my Small Bolt shaft to a one piece setup. Can anyone point me towards what is needed? I would prefer to support Steve and OSE if possible.
Thanks
Peter
wparsons
01-28-2011, 11:39 AM
I'm looking into options for the same. Right now I'm considering getting a coupler/flex/stub from a mini rio, unsoldering the flex and soldering in music wire and running that. I'm sure there's similar parts available, but I noticed it while upgrading a friends mini rio to a wire drive a few months ago.
Basstronics
01-28-2011, 12:08 PM
I just ordered up this option.
http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc098L-24c
Then you need a coupler- the fun part. There is one left in the swap shop- I bought the other.
http://forums.offshoreelectrics.com/showthread.php?t=21159
I decided to change up my theme on this. No more pink panther... Paint still happening this weekend. Gotta get this ready for the water!
CaptPJB
02-06-2011, 04:30 PM
Come someone please give a starting point for the CG for a Small Bolt? Some folk seem to prefer a sideways battery just ahead of the motor citing better CG adjustment range others put it in line down the center.
Mono's are 25-30% from transom but not sure about a hydro as they basically run on the two front pads and the prop.
Thanks for any help or comments
Peter
martin
02-06-2011, 05:36 PM
Tenshocks Minicat hydro is very simular hull to the Bolt in size & they use 6.1" in from the transom for the cog point, This should give a starting point & then go from their either way if nessesary. Thanks Martin.
wparsons
02-06-2011, 06:29 PM
I run my battery (3s 2200mah) lengthwise as far forward as I can without it interfering with the hatch.
CaptPJB
02-06-2011, 07:25 PM
OK I have to ask, is there an easy way to get the shaft out to grease etc. I removed the strut pulled off the drive end but had a heck of a time getting the flex shaft out. There is nothing to catch hold of as it is inside the copper tube, finally sort of pushed with a screwdriver on the flex shaft by the coupler until I could get some pliers to grip the other end.
igottalongone
02-06-2011, 07:33 PM
Your flex cable is not attached to the prop shaft???
martin
02-06-2011, 07:38 PM
I think most that have that design shaft dont like them & change them for one piece one where you just pull out without touching the strut. As far as what ive seen all the Hor boats use that design. Thanks Martin.
CaptPJB
It has a square end that fits in the female end that is in the strut, when I took the strut off they came apart
igottalongone
02-06-2011, 07:39 PM
If not, you will want to clean both the prop shaft and cable end with brake clean, or carb cleaner.. getting off any grease, etc... Then you attach the flex to the prop shaft with "red" loc-tite...
Ron
CaptPJB
02-06-2011, 07:45 PM
Thanks will do that, then I assume you undo the strut after loosening the grub screw on the coupling and pull the whole thing out from the back?
Appreciate the help
Ron
martin
02-06-2011, 07:46 PM
They use a separate stub shaft in the strut that has a step on it & is put in from the front of the strut, So if any thing comes loose or breaks you dont loose your shaft, prop ect, Theirs a square hole in the end of the stub shaft to witch the end of the flex has 4 flats ground so the square end of the flex goes into the square hole in the stub shaft. Thanks Martin.
Basstronics
02-06-2011, 07:48 PM
Im switching mine over to .098 cable, 1/8" prop shaft with a set screw coupler.
igottalongone
02-06-2011, 07:50 PM
Appreciate the help
Exactly...
igottalongone
02-06-2011, 07:54 PM
Yes, I know the sytem well...
When correctly installed the flex cable it affixed the the prop shaft with "red" loc-tite...
Ron
Basstronics
02-07-2011, 06:47 AM
Why would the drive side with the flats need to be loctited into place?
The contraction the cable makes is the slip offered with such a joint. I guess you could allow space behind the drive dog here also- but I dont think that is the designs intent.
Also "red" loctite? Thats the permanent threadlocker stuff. I tried that on a wire drive and it was instant fail. I switched to the right stuff, now its like steel!
wparsons
02-07-2011, 07:43 AM
Ron
You definitely don't want to glue/solder/weld the stub to the flex on a setup like this. There's no way to leave enough play between the drive dog and strut to allow room for the flex shaft to shrink under load.
Plus, the whole benefit to a one piece flex/stub is that you don't have to pull the strut off to remove it, but in this case you still would.
The best bet is to replace the flex and stub with a new one (or wire drive), it'll only be like $15 with a coupler anyway.
igottalongone
02-08-2011, 02:39 PM
Wrong... I have one in my hand right now, there is a good 2mm (more than enough) for cable shrink... I checked my Tenshock rigger as well, same exactly thing...
This type of system (stepped prop shaft) requires the strut be removed no matter if you affix the cable correctly or not...
Anyone who wants to install the cable correctly will want to red loc-tite the cable into the prop shaft... This system has been around for many years, the installation has always been the same. Either solder (harder to do correctly) or "red" loc-tite the cable to the propshaft, end of story..
Leaving a tiny (poor quality) cable loose in the hole is a great way to destroy the cable...
You also stated the "best" thing to do is replace the system... I disagree with that as well...
If I break a cable, I don't loose a prop I have a ton of work into... Not true when you switch to a wire or non-stepped cable... When you break a cable your prop goes to the bottom of the lake... Not an issue if your running $2 plastic props, I don't use $2 plastic props.. Changing it out, only makes it easier to maintain... A non-issue for myself... I'd rather keep my prop thanks... Everyone has their own opinions on this stuff, but like I said, this is an old system (octura has been doin it 30 years) and the method of installation has always been the same... We ain't breakin any ground here people...
This debate is as stupid as the water pick-up debate... I'll let my boats do the talkin instead of my typing finger...
wanna race? :laugh:
wparsons
02-08-2011, 02:55 PM
^^ 2mm isn't really enough room for cable shrink, you generally want the diameter of the stub shaft in space between the drive dog and strut.
I'd like to see your setup, on mine I had to pull the drive dog as far towards the threads as I could without taking it off the flat spot just to keep it from binding. Even now I have about 0.5 mm of space at best.
IMO, a one piece (non stepped) stub/flex is easier to maintain, and breaking a cable really isn't that big of an issue. The stock cable on this boat is WAY oversided for the power/load it's under.
As for the race, anytime :D Here's mine all stock with a plastic prop:
http://www.youtube.com/watch?v=y4yCpkgAAsI
It's a bit faster now with the S/B x632 on it, still otherwise stock.
igottalongone
02-08-2011, 03:12 PM
"you generally want the diameter of the stub shaft in space between the drive dog and strut."
Dude! really???
You do NOT want a 1/8" between your strut and dd...
I hope your running a thrust washer, if not your cable is trying to push the rotor through the back of your motor, lol...
Like I said, everyone has their opinion...
But, I don't think you even need to know anything about RC boats to know that leaving that tiny cable free to move around inside the prop shaft is a bad idea... But whatever...
Ron
igottalongone
02-08-2011, 03:14 PM
http://www.offshoreelectrics.com/info-pages/assemble-shaft.php
wparsons
02-08-2011, 03:17 PM
Seriously? You must have REALLY limited boating experience if you think that 1/8" is too much of a gap. If you think that a smaller gap will stop the flex from putting load on the motor you've been misinformed. You have two scenarios possible... Either you have enough space and load gets transferred to the motor, or you don't have enough gap and you get binding when the flex shrinks under load and pulls the drive dog into the strut.
Even the link you posted says 3mm (1/8"):
Measure the total length needed and add 3mm for the space needed between the drive dog and the end of your strut.
igottalongone
02-08-2011, 03:40 PM
3mm on a 3/16 cable!!!
1/8th gap for a 1/8th cable is too much, again, whatever...
good luck...
p.s.
As far as my "REALLY limited boating experience"
I think people can look at both our videos and figure out who knows what they are talking about...
I BUILT my boat from the hull up, I didn't let the chinamen do it for me...
You'll have to come to a bit bigger lake for our race, I couldn't even run my boat in that bathtub, LOL!!!
wparsons
02-08-2011, 04:13 PM
I'm not going to get into a pissing match about this 'cause I have better things to do with my time, but:
1) I've been building boats since I was 15, if you want to do the math, that's 14 years of experience. I've built mono's, cat's, outriggers, hydro's, electric, nitro and gas.
2) http://forums.offshoreelectrics.com/showthread.php?t=11247
3) http://www.rcgroups.com/forums/showthread.php?t=1295340
4) http://www.modelpowerboat.com/content.php?146-How-to-Assemble-a-RC-Model-Boat
5) http://forums.offshoreelectrics.com/showthread.php?t=15132&highlight=gap+drive+dog
You talk like your small bolt is so much faster than anyone else's, but it's still pretty stock. Sure you disassembled it, moved the water inlet, painted it and fused the flex/stub, but that's about it. Did you fix the angles on the bottom of the sponsons (mine had a degree or two of anhedral out of the box, and the trailing edges weren't the lowest point), is your CoG in the right area, did you cut back some of the stuffing box to give the strut more adjustment? You're even running a close to stock (or totally stock) motor.
I'm not putting down your boat in any way, but you're talking like everything is custom on your boat.
If you want a race, I'll put a spare 3600kv 380s in mine and see how yours does :D
I bought mine to have a super reliable no nonsense cheap boat. I put a battery in it, tape the hatch shut and it runs for 6 minutes on a charge. I can let anyone drive it as well.. Sure it's fast enough to flip, but it doesn't do any damage if it does.
igottalongone
02-08-2011, 04:37 PM
"Sure you disassembled it"
"but it's still pretty stock"
WTF???
WRONG YET AGAIN!!!
Better to be quiet and thought an idiot, than open your mouth and prove it...
What do YOU know about MY boat!!!
I bought a Hull on e-bay, I bought a Motor and ESC, I bought Drive Harware from Steven and BUILT IT!
I didn't disassemble sh*t!
I think your a talker, not a do'er...
If you had any stones you would have this legendary 3600KV installed allready, lol...
You pick the hull (mono-cat-hydro-rigger) and I'll lay waste to yours!!!
Videos with GPS to see who's the king of the pond...
No stories about what you "could do"
**VIDEO CHALLENGE**
Pick yer poison tough guy!
LOL!!!!!!
martin
02-08-2011, 04:54 PM
Ok lets keep things things civil guys, I have a question about this design shaft that has the shouldered stub shaft & square flex. Why do to need to Loctite or solder or any other method these two together. Thanks Martin.
wparsons
02-08-2011, 05:01 PM
^^ Agreed...
I could care less how fast you think your boat is (or how fast it really is), the whole point was about how much of a gap is generally a good idea. I gave 5 examples, and all you focus on is the degree to which you built your boat.
You can't seem read either, I clearly said I bought this boat to be simple and reliable, not a rocket. I'll be sure to build the tub wide enough in my 16" rigger to fit a GPS in it just for you though... :doh:
Back on topic, there's not really any need to fuse them together at all. I've got a good 15-20 runs through mine and there isn't the slightest sign of wear on either the stub or the flex shaft.
igottalongone
02-08-2011, 05:19 PM
LOL!! Retreat!!!
My eagletree data logger fit's right in my mini, so your weapon of choice is Mini Hydro's??? at 40 paces, lol!!! Done!
There is a data logger on the swap shop right now, go get it : )
"Martin" all the fun aside... Look at your cable bro, look at that tiny little square end made out of twisted sh*t china metal... Then look at your prop shaft, picture that little cable twisting back and forth while pulling in and out... Seem like a good idea??? Seem like letting the parts move around together metal to metal is a good idea??? No... It's not... Thats why they have been affixing them since they started building them 30 years ago... Like I said before, you don't even have to be into RC boats to see why they affix cables... I have a mini rigger, with a ton of motor running this system, I just measured it, I have 1.85mm between my drive dog and strut, and there is ZERO wear on the thin teflon washer. Meaning, it is shrinking less than 1.85mm under load... So, 2mm is more than enough gap, exactly what I said 36 posts ago...
Jim Bob
02-08-2011, 06:13 PM
For what it's worth, my rule of thumb for shaft spacing is 1/2 the diameter of the flex shaft. Been doin like that for 35 years.
Basstronics
02-08-2011, 06:17 PM
As a machinist and a mechanical engineer I can tell you there is no reason this "needs" to be done. I can also tell you that "red" loctite is permanent thread locker. This is not a thread. If anything the Retaining loctites should be used.
I got's fear is that he is going to twist that square end off while its moving about that little bit... I dont think theres a 2040 motor out there with that kind of balls...
I tried the "red" loctite ona wire drive. It held up about 10 seconds and 24 MPH... I switched to the proper stuff, Loctite 648 and I will be damned if I can break it...
Basstronics
02-08-2011, 06:22 PM
Where at in Michigan?
Its boring down here in Toledo area...
igottalongone
02-08-2011, 08:03 PM
"As a machinist and a mechanical engineer I can tell you there is no reason this "needs" to be done."
wow... ok, i'm done... you guys win...
So, CaptPBJ...
Just keep on digging your flex cable out of the stuffing tube with a screwdriver...
I found a bridgeport operator who says there is absolutly no reason to install your cable correctly... lol...
Just kidding Bassman ; ) It was a Joke!!!
But, you would have to agree that it's a pretty bold statement to say because you are a mechanical engineer that you have the final answer on this (to affix or not to affix) issue...
If you really are an engineer, you know that nothing is known for sure until enough data is collected... But for all I know you did your masters on tiny chinese drive cables...
The Tenshock rigger I'm running one of these systems on is putting out over 800watts, more than enough power to jack up an incorrectly installed cable...
"Where at in Michigan?"
I'm in Waterford...
I just drove down by you a couple weekends back to run in Monroe, they have a running river that never freezes : )
We have a sweet spot to run up here in Waterford, big lake all to ourselves...
Come hang out this summer and run boats...
Most of the guys I run with are flyer's as well, so bring a Seaplane if ya got one...
C-Ya...
Ron
Basstronics
02-09-2011, 06:15 AM
We are talking the same thing here, right? The square end female and square end male flex cable?
If so there is no "need" for the loctite. If your cable is ground inaccurate to the point you feel you need loctite then it really needs to be replaced. Even the green loctite only fills in about .010" area. You could have more than that in such a case.
The whole design intent on this is to allow slip at that point so the drie can remain tight...
Im about 20 minutes SE of Toledo. Monroe isnt to bad of a drive nor is Detroit. This summer we should get together. Im sure you could give me some advice for my fleet.
have a good one.
wparsons
02-09-2011, 08:08 AM
LOL!! Retreat!!!
Whatever man, you're clearly just bored and trying to start fights.
I'd like to see what you're using to measure 1.85mm though, 0.05mm is about 2 thousandths of an inch. How exactly are you measuring that accurately with the boat together?
Look at it this way... What's the harm in running more of a gap, absolutely nothing. What's the harm in not running enough gap, snapped cables.
Also, since you're using red loctite which isn't a permanent glue, there's a chance that the cable is still pulling out of the stub a tiny bit under load, which negates the need for a gap at all.
Square drive stubs are designed to use a thrust washer or teflon washer at the drive dog to carry the load when the prop pushes the drive dog into the strut and allow the cable to shrink as needed unimpeded.
What motor are you running in your mini rigger that puts out 800w, is it a 20mm can? The smallest reasonably priced (not lehner, etc) motor I've been able to find that puts out that kind of power is a leopard 2845, but if I can get a 20mm can motor that puts out that much power I can drop it into my mini rigger tub easily.
martin
02-09-2011, 10:01 AM
The design idea & theory of the 2 part shaft is a good design, But its not that popular with us boaters because its not so simple or easy to grease ( probably were being lazy ) over the ones where you just undo the coupling & pull out. My self included, Im sure most are aware of the advantages of the 2 piece shaft though. You cant loose your shaft & prop out the back ( unless the stub shaft breaks ).also you dont have to worry about setting dog to bearing clearance that allows for flex shrinkage, Because the dog runs against the bearing & not against the motor. The idea behind the square male & female is a floating shaft so it cant wind up to tight & snap the flex or where you have to adjust the clearance spot on where on a one piece shaft where you have to have the dog to bearing clearance right which in my opinion is pretty much impossible where you have exactally the right clearance that allows for shaft wind up whilst still having the dog running against the bearing. You either end up with shaft wind up with the dog not touching the bearing or the opposite where theres not enough clearance & the flex is then under load & will snap. The solid 1 piece drive shaft isnt realy a good design although most of us use them. On a front wheel drive car you wouldnt use a solid drive shaft, Thus putting the entire loads on the out put shaft bearings & not the wheel bearings. Just my take. Thanks Martin.
wparsons
02-09-2011, 10:34 AM
I wouldn't call it lazy so much, some boats take a lot of fine tuning to get the strut set perfectly, and then to have to pull it off and lose that setting everytime you grease the flex would be beyond painful.
You would basically spend a run or two getting it right again, only to have to remove it again to grease it after a couple more runs.
martin
02-09-2011, 10:51 AM
Thats the exact point i was making, I called it lazy. This is one big downside to this design where you have to keep removing the strut & loose your settings, So it possibly dosnt get removed as aften as it needs for greasing. I have friends that have this type & they leave the shaft in longer than they should where as the simple pull out ones the tend to grease more often because its simpler to do with less hassle re setting up again. Thanks Martin.
igottalongone
02-09-2011, 07:55 PM
As far as me starting fights, YOU made the first rude comment in our exchange, so blo me!
p.s.
I took a look at your you-tube videos, to see your RC prowess in action...
LMFAO!!!
:iagree:
Keep up the great work... :thumbup1:
igottalongone
02-09-2011, 08:54 PM
Just wondering fellers...
Anyone gonna help out the guy who originaly asked the question???
I attempted to help the man install his cable correctly, but the thread was then taken over with this stupid shyte...
CaptPBJ is at home right now digging his flex cable out of the stuffing tube with a screwdriver...
Well Capt, I'll shut up now and leave you to the pro's...
Ron
Basstronics
02-09-2011, 09:07 PM
Mine was jammed in the square end also. The square end is ground by hand and isnt fully square. I did it a favor by cleaning it up with my dremel tool and a cut off disk. However in the end I decided to replace it.
igottalongone
02-09-2011, 09:28 PM
Actually, if the cable was getting stuck in the prop shaft, he wouldn't have a problem, he would have it installed correctly...
But I won't go there again... lol..
The Captains problem was, when he removes the strut, there is not enough cable sticking out to grab ahold of.. So his only option was to use a screwdriver to poke the cable down the stuffing tube at the coupler....
Rumdog
02-09-2011, 09:32 PM
How about just replacing it with a standard flex? .098 will be perfect. Who the hell wants to pull the strut to grease every time? You could also go wire drive.
wparsons
02-09-2011, 09:33 PM
p.s.
LMFAO!!!
:iagree:
Good to see you're still carrying on...
I could care less about your approval, which is why I haven't bothered uploading videos of most of my boats/planes/trucks/helis. I know that I know what I'm doing, and don't need to get into a pissing match to prove it.
Back on topic yet again, small pliers or tweezers work wonders for getting the flex shaft out. At the very worst you can take the coupler off the motor to push the flex further down the stuffing tube.
I cut about 1/4" off my stuffing tube to give the strut more room for adjustment, which also exposed more of the flex when I pull the strut off.
I'll be making a wire drive for it when I get any time to work on it so I don't have to go through all this trouble every time I need to grease the flex.
Basstronics
02-10-2011, 07:03 AM
I purchased a wire drive for mine. The problem I seemed to notice was to much bend in it- making it hard to turn.
If the flex is stuck in the coupler grab it with pliers and pull it out. Get the coupler off the motor- remove the set screws. File the coupler where the set screws are- typical culprit of such things.
While your at it take the dremel and a cut off and sand the square end so it floats good inside the female square end.
wparsons
02-10-2011, 07:32 AM
^^ Do you remember what diameter the wire was? I'm going to test fit one from another boat that's a .047 wire when I get a chance.
Basstronics
02-10-2011, 07:43 AM
.062
wparsons
02-10-2011, 07:52 AM
I'll try the thinner wire with a plastic prop first :D
CaptPJB
02-10-2011, 08:00 AM
Thanks for all the info guys did not mean to stir things up. Lots of good info came out of the posts though and I learnt a lot. I won't stir things up again by saying which method I am going to use but lets say I have choices.
One of the things that made my life difficult was when I went to loosen the grub screw on the motor end it stripped but the flex end undid OK. hence I was trying to push the flex out with screwdriver/plier assist.
Now I guess I will have to find a small bit to drill out the stripped grub screw. Apart from making life more difficult to get the flex out it is holding fine so may leave repairs until I just have to do them and enjoy this little rocket.
Thanks again for the help
Peter
wparsons
02-10-2011, 09:25 AM
You might be able to get the grub screw out by using a tight fitting torx bit, but there's no guarantee of that working.
martin
02-10-2011, 10:08 AM
I had the same problem getting the allen grub screws out of the coupling all be it on a Tenshock mini eco which has a 2mm wire drive. The motor shaft screw came undone ok but the shaft one wouldnt undo without slipping in the hexagon. The keys i had were 1.5mm .058" so thought they might be 1/16".062"so bought a set of a/f size wrenches. used the 1/16" wrench & guess what it slipped the same, When i measured the 1/16" wrench it measures the same size as the 1.5mm. Whether they now use the same size wrenches for both these sizes because their very close i dont know. I managed to find a wrench out of many i had of this size that was new & had a bit of a burr on the end from manufacture so was a couple of thou bigger right at the tip which didnt slip & undone it. Thanks Martin.
SweetAccord
03-20-2011, 06:35 PM
After getting this boat from KH and reading all the threads on this boat I can see where some decided to change it's setup. After seeing how it's been designed, I do see how there is much drag in the driveline. I decided to copy the Tenshock design and put a bearing in the strut instead of the bushing. Wow what a difference! It also has a tighter seal so water should have a harder time to enter also. Also I'm stepping down the drive line from the stock 3.18mm flexdrive to a 2.37mm one with keeping the 1/8 prop shaft which is the same as the stock one. I took a few hours to carefully drill out (by hand) the stock bushing and bore it out to accept a 1/4" bearing. Sanded with 1000 grit sand paper to get a smooth inside diameter until the bearing was able to be (fimly) pressed in. You can get these bearings at the LHS.
http://public.blu.livefilestore.com/y1pJmRwi9rZI9ijYCqV46MpokplAiBeQbBYfJ8PtKpOB294Mrn Mhp0WtU9JNYKK7B6uI587fDdJCkNEBtg_AUOgZg/IMG_0083.JPG?psid=1
SweetAccord
03-20-2011, 06:41 PM
I also noticed it keeps the prop shaft more centered in the stuffing tube so it should also not rub against the inside of the stuffing tube when the strut is inserted into the stuffing tube. I think this also is contributing to the drag.
wparsons
03-20-2011, 08:01 PM
A lot of the binding out of the box is caused by the stub shaft rubbing against the front of the bushing, with the bearing is should spin MUCH easier. I had to take mine apart and move the drive dog back so the stub had more room to spin easier.
The stock flex is also huge for the power output, I'll be replacing mine with a smaller flex or a wire drive when I get some time.
Another thing you really need to do is re-bend the steering pushrod. Mine had A LOT of binding in it from the factory. I found bending it lower where it passes through the transom made a world of difference.
SweetAccord
03-20-2011, 08:08 PM
Yes, the steering pushrod is my next step once I get the new servo mounts from HK.
SweetAccord
03-21-2011, 07:01 PM
I'm also working on a break away method for the rudder. Here is the solution. Small graphite rod used instead of the stainless steel pin (it's lighter also). It's hollow and strong but will break when needed.
http://zrotcq.blu.livefilestore.com/y1plZF3Jq-5GYT00Z15-YOwg59EdjikCQawNCrqxzW7X8zy3QWHOrcVZmcopM_XYebAAwj 3Zgw72noRNf1MVIJQBMOkboxPw_aH/IMG_0089.JPG?psid=1 (http://zrotcq.blu.livefilestore.com/y1plZF3Jq-5GYT00Z15-YOwg59EdjikCQawqO5-Dy-kXN71-HBLfUx6Y-c7Ye8LkqdVIVhKz2u4D-k9q2WdjDVMjyTJM6n9JOOn/IMG_0089.JPG?psid=1)
