View Full Version : Finally got a hull. Its an oldie
frostyan
12-18-2007, 11:31 PM
I think I got a good deal. If not o well I like the hull . Got a AEROMARINE SPRINT CAT . She’s in ruff shape but it has all the hardware and radio tray . with time and money going to have her like new .I have no idea what to juice her with . The hull is Length 36" 915mm x Wide 14" 356mm all fiber glass. So what do you guys recommend . Paid $120 for it and a free cat stand lol.
2966 2967 2968 2969 2970
Diegoboy
12-18-2007, 11:34 PM
...are you good with FG?
frostyan
12-18-2007, 11:50 PM
going to make it FE . why ?
Rex R
12-19-2007, 02:01 AM
it is going to take a bit of work to patch/plug those holes in the hatch and make it look good.
Put her on a scale bud. We need and idea of weight to help with power systems. If I had to guess a KB10XL on 6s with a hydra 240. You may however need one of the larger Neu motors to get the torque you will need. This one going to cost you quite a bit.
frostyan
12-19-2007, 10:30 AM
it weights 6LB as is. good point , by the weight i mite have to go HV ESC and 24 cell .does the 45 Kb Brushless Motor have info torque .a buddy of mine works with fiberglass i have to take off all the stickers an give him the hull to fix it . the best way to take of sticker is with a hair dry or do you guys have a diffrent way.
Go to aeromarine and see how much a new uncut hatch is befor you go nuts glassing. I think you will be fighting a loosing battle attempting to use Nimh batteries. It will amount to just to much weight. I can really identifie with your excitement with regards to building a big cat. The fact is the components needed to power this cat reliabley are going to be very expensive. My honest opinion is to avoid this hull as your first build. I would shelv it for later on when you have gained the knoledge needed to do it right. What you need to build is one of the 26 to 30 inch monos or cats. A build like that will be half the cost and will be much more fun with far better results. The chance of failures that will cost money and stress will be much less. Sorry if that's what you where not looking to hear but I am looking to save you money and grief.
Tom G
ReddyWatts
12-19-2007, 02:46 PM
If you are determined to use this hull, this is a setup I would use.
KB45 11XL 1000KV
High Voltage controller, highest amp rating you can afford.
Lipo 8S2P 30C or 24 NiMH cells, but will add weight.
M545 prop
NiMH 70 - 80 amps 24300 rpm
Lipo 80 - 90 amps 26800 rpm
40's
Diegoboy
12-19-2007, 04:46 PM
Sorry... Good with FiberGlass is what I was trying to say
Ok having seen it on my PC and not my phone I can make a few suggestions. The first thing I'd do is cut the fat. I am unfamiliar with that hull but I'm betting you can out most of the stringers and remove the radio box with out compromising and strength. The cracked hull section needs a fair about of glasswork. I am not the person to talk to about that. OSE does stock what you need though. I you can cut & sand 2 or 3 pounds out of her you will have a fighting chance. Mr Watts setup up suggestion is "Spot On". You are looking @ about 400$ in parts and 250 to 300 in lipos. Half that for Nimh batteries. Try and save that pain...It's a nice looking cat ]Ok having seen it on my PC and not my phone I can make a few recomendations. The first thing I'd do is cut the fat. I am unfamilure with that hull but I'm betting you can out out most of the stringers and remove the radio box with out compromising and strength. The cracked hull section needs a fair about of glass work. I am not the person to talk to about that. OSE does stock what you need though. I you can cut & sand 2 or 3 pounds out of her you will have a fighting chance. Mr Watts setup up suggestion is "Spot On". You are looking @ about 400$ in parts and 250 to 300 in lipos. Half that for Nimh batteries. Try and save that pain...It's a nice looking cat:wink:
Avanti
12-19-2007, 06:28 PM
to remove the sticker a hair dryer will help. Have goo gone on hand you will need it. start at one end and move slowly across the hull try to get it off in as big a piece as possible to make it easier on yourself. also if it is glass and gel coat you can use acetone on it to clean it up to give to you glass guy.
frostyan
12-19-2007, 06:47 PM
allsome going to work on the hull now with the hair dry .thanks for the set up reddy , and which esc can i put thats water proof because i removed the radio box.
sjfe these are the stringers 2977 and radio box gone
ReddyWatts
12-19-2007, 07:06 PM
Offshore will be selling the Castle Creations Marine Hydra HV 120 and HV240 controllers after the first of the year. Dont know of any HV controllers that are waterproof.
http://www.castlecreations.com/products/hydra_hv_line.html
ReddyWatts
12-19-2007, 07:53 PM
I am using the OEMRC HV 100 amp controller on mine with NiMH cells. I am uncertain about recommending it for your setup, because of the heavy hull weight and power surges. It is about $100.00.
The Hydra controllers are the safe and best option.
I'm sorry but did i see a list price of 540 on all of them?????? Holy Shnikeies!!!!!!!!!!!!
Alex push down lightly on that tunnel. If it feels solid go ahead and cut those out of you wish. It will save you some weight. I have a motor mount I can give ya.
lonewolf
12-19-2007, 08:08 PM
Yup I seen it too gotta be a typo....
ReddyWatts
12-19-2007, 08:09 PM
Suggested retail prices. Will probably sell for 50 - 100 less than retail.
HV60 $279
HV120 $345
HV180 $450
HV240 $540
They are way out of my leauge.
Eyekandyboats
12-19-2007, 08:42 PM
i already got my eye on. . a 240 and two 180's.
frostyan
12-21-2007, 12:52 AM
got the sticker off . now what lol. now i have to find out if i have to sand it down or just the damage part and get it readdy to regel the hull and fiberglass the big hole3010
frostyan
12-22-2007, 08:48 PM
3042 no more stringers and radio box
my friend that does the fiber glass said he is coming back on dec 26. so he would patch up my cat and has white paint left over from a yacht he did.
Looking good!! Pull that flotation out and get some pool noodle it will be a little lighter and look better. Thats kewl you have a glass guy. be sure he uses a thin glass to keep weight down.
tylerm
12-23-2007, 03:48 AM
Lookin good there man, yea pool noodles will do a good job as well.
Which i knew a fibreglasser.....
Tyler.
bustitup
03-07-2009, 05:25 PM
any update on this ...looks interesting
Eyekandyboats
03-07-2009, 05:33 PM
http://www.cadillacforums.com/forums/images/smilies/ohthedrama.gif
wow this thread was last active in 2007, almost two years ago.
skipskip
03-07-2009, 06:04 PM
it looks a littile beat up for 120 bucks but good luck im sure it will be bad a@# when your done
frostyan
06-30-2009, 03:11 PM
well i did finish the FG and paint part of the boat but never did the guts of it to expensive for a big can motor and a HV SC. but know i see we have outboard brushless maybe two of those with 2 80amp cheap sc can get it movin on 8s http://i20.photobucket.com/albums/b244/frostyan/P6300185.jpg http://i20.photobucket.com/albums/b244/frostyan/P6300187.jpg http://i20.photobucket.com/albums/b244/frostyan/P6300188.jpg
