View Full Version : MG stock Flexshaft prop nut.
Diesel6401
01-21-2011, 03:29 PM
Not sure if anyone has had a problem with finding the right size prop nut, but I did. I have a reverse and standard flexshaft from the MG that I am using in a twin. The flexcables did not come with prop nuts, so I dug in my stash pulled out 2 10-32 nuts like most of my other cables use and they did not fit. So I used a thread gauge and found they are metric m5-.8 nuts. You can pick a 4 pack up at Lowes for $.68, just though I would share that.
These worked for me: http://www.lowes.com/pd_138357-37672-880811_0__?newSearch=true&catalogId=10051&productId=3012828&UserSearch=138357&Ntt=138357&N=0&langId=-1&storeId=10151
GeoVW72
01-21-2011, 04:11 PM
really :confused2:
bought a new flex shaft and it even had the prop on it.
Octura brass bullet nuts (http://www.offshoreelectrics.com/proddetail.php?prod=oct-oc6pnmm&cat=38)also work
Darin Jordan
01-21-2011, 04:39 PM
That is weird... My replacement shafts came with a prop as well (plastic).
I keep trying to specify to the manufacturers that I want 10-32 sized threads... Guess I should be happy that they at least get the 3/16" prop-shaft part correct! ;)
I'll keep working on them for future products. Trying to get all of these US market boats to be standard sizes in these areas.
Diesel6401
01-21-2011, 05:19 PM
really :confused2:
What shaft did you buy? If it is the stocker http://www.horizonhobby.com/Products/Default.aspx?ProdID=PRB4107#quickOverview that bullet nut will not work
When they sent me the replacement cable for the reverse mix up it did not come with anything besides the flexcable/shaft. No drive dog, no nut. Just the assembled flexcable. I was shocked it wasn't 10/32.
GeoVW72
01-24-2011, 01:52 PM
:doh: that was the ose cable, my bad.
Darin, I thought you were making your own so the rest of us could get them :Shame_on_You:
:just-kidding:
I don't think they'll be running out anytime soon
