View Full Version : Radio questions for micro boats
sjslhill
12-18-2007, 08:31 PM
I am building a 1/24th scale boat for R/C
What radios are out there for this. I need a very small receiver and servo. I will most likly be running at most 3 of these together in the future. Any ideas?
thanks for your time
Steve
crazzy maxx
12-18-2007, 08:32 PM
hs-55 micro steering servo
and a mini lst radio and reciver are pretty small to.
i have radio and reciver if u want it.
Steve you may want to look @ unitedhobbies. They have a ton of micro receivers. I'm sure you can find somthing that will work:).
ED66677
12-19-2007, 04:08 AM
beware of micro receiver, they were originaly designed for park flyers, so the range of use is very short, don't go too far with your model or you will loose control
Eyekandyboats
12-19-2007, 08:13 AM
I believe there is a servo called the blue bird which is even still smaller then the HS55.
as for receiver, will you will have to find one that works with your radio which is not always the easiest thing to do, Or you use a air plane radio and you will have a whole slew of recivers to fit the boat
sjslhill
12-20-2007, 06:44 PM
thanks guys....no airplanes where I run, it's a lake with trees everywhere.
