View Full Version : seaking 180 on 6S power
carlcisneros
01-17-2011, 12:19 AM
OK folks, there are those of you that have/are running the Seaking/Turnegy 180A
Marine ESC on 6S power with a stand alone/BEC receiver power.
Please if you would speak up and let others know what your set-ups are so that other folks can get some information on what is good and not so good. (if you will)
Hull:
Motors: to include manufacturer, kv, amp rating, ect
Props:
Battery Mfg. and Amp/C rating
Thanks everyone for your info.
:w00t::w00t::thumbup1:
DISAR
01-17-2011, 03:45 AM
I run the mean machine on 5-6s
Hull: Mean Machine
Motors: Turnigy T600 1400kv, Scorpion 4025 1480kv
Props: 445 on 6s, 646/3 on 5s
Battery: 6s1p Turnigy 5000mah 40c
5s2p Turnigy nano 4000mah 25-50c
I also use the T180s in my Maritimo and twin sprintcat but on 5s with hpi 2200kv motors and 442 props
scoota
01-17-2011, 08:12 AM
I run a DF33 on 6s with the T180 ( BEC disconnected ) , 4082/1500kv leopard motor , x646 & X648 props , Hyperion 35c-6500mah 3s lipo packs, for a cheap ESC it has held up well , for the last 4 months i have been running it , the only problem i have had was the LVC was cutting in way to early ...
Make-a-Wake
01-17-2011, 08:45 AM
45" Dumas Scarab
T180
Neu 1527 1Y 1250kv
6s2p Zippy 6s 4000 40c x 2
Octura x447
Using internal bec
39" Mono
T180 (added two caps)
Castle 1717 1580kv
6s2p 4 x 5000mah turnigy 3s 40c's
X645(was using x447)
Using internall bec
Folks are hitting the LVC with the T180 prematurely, but the last guy found out it was due to running 1p..............thats usually the case........happened to me in my Dumas til i went 2p.
forescott
01-17-2011, 10:20 AM
40" mono
Leopard 5692(1340)
T-180
4-turnigy3600mah/3s/30c/=216A on 6S
internal bec
X-452
ScarabChris
01-17-2011, 10:27 AM
54" Bonzi Sports Fountain
Twin Leopard 5692 motors
Twin Sea King 180s
Four Turnigy 5000 mAh 40C 6s
carlcisneros
01-17-2011, 11:10 AM
Great guys!!!!!!!!!!!
keep the info coming so everyone can see how it all shapes up for the ESC and such.
This is what the forum is all about.
johnson22456
01-17-2011, 12:09 PM
Delta force 33
Neu 1515 1.5y
Turnigy 4.5 3s 30-40c (x2) in series
M445, x447
Bec disconnected
Alexgar
01-17-2011, 12:11 PM
fastech
cc1515
t180 on 6s internal bec
turnigy 6s 5000 30c
