View Full Version : Turnigy 180 amp esc problem?
6sHyper
01-16-2011, 09:28 PM
Ok so i just literally finished putting together my apparition, I am using the turnigy 180 amp esc and at the moment i just have the stock motor, i just wanted to test everything to make sur eit was working so i hooked up the reciever, "learned" the radio to the ESC and everything seemed to work properly other thna the prop spinning the worng way, so i just reversed 2 of the motor wires and it was fixed. i literally spun the motor over for a second 2 or 3 times, then while in neutral i accidently dropped my radio and next thing you know the motro is spinning, i quickly hit the brake and it stopped (programmed no reverse) then back in neutral it stays stopped untill i hit the throttle and it would keep going even when i let off, weird. so i dosconnect the battery and check the settings on the radio and all seems right, i plug the batteries back in and the esc beeps 6 times quickly, the servo works fine, but i get no reaction form the motor at all. I tried switching the radios with a differnet recievr and everything and the esc doesn't even want to learn the new reciever, i alos noticed sometimes the ESC beeps differently when battery is hooked up. what could be wrong??
was using 6s to test btw. thanks
noodler
01-16-2011, 10:05 PM
When you first plug in your batteries the esc beeps per how many cells you have. 6 beeps equals 6s. Check your throttle trim it might have moved when it was dropped. Center your trim and relearn your reciever.
6sHyper
01-16-2011, 10:28 PM
thanks for the reply, something must have happened with the throttle when i dropped it and after that the esc was being a little prick, haha. anyways i installed a brand new trx 2.4 reciever and the Esc decided to "learn" to it and now all is good! thank god.
Make-a-Wake
01-16-2011, 10:32 PM
Kinda tough to harm a T180.....................
