View Full Version : Propellers for 57" hull with twin t600
FastVee
01-11-2011, 04:03 AM
Hi, so what would you suggest I should get?
The hull is 57" apache, two Turnigy T600 Brushless Outrunners (880kv)
two 200A esc´s
Will be using 6S on each motor. (17-19k rpm)
I need a pair so one left and one right.
-Pate
blackcat26
01-11-2011, 07:59 AM
I posted this in your other post, I think some x457's would work. Comes in l and r
FastVee
01-11-2011, 01:32 PM
Thanks, but I forgot to add that it will be 1/4 prop shaft/flex setup. x457 is 3/16 (or that is all what I found)
I think that 3/16 is too smal dia for this power?
would rrreally like cool looking/performing 3-5 blade
blackcat26
01-11-2011, 05:51 PM
3/16 is not too weak. There is plenty of boats going 100+ mph using that bore.....To get counter rotating in an octura in 1/4" bore the smallest 2 blade is a x470. ABC props have some cool 3 blade but the smallest size in counter-rotating is 2.6 dia. Still seems big but you are turning low rpm's......
dasboata
01-11-2011, 06:33 PM
I have some 5517/5 in bronze 55 X 95 MM problaby a little big and soft for a FE boat I am a prop shop dealer and can order anything for you thaanks chris
FastVee
01-12-2011, 03:08 AM
Thanks, the struts I have been looking at are 1/4. I guess that a smaller tube could be inserted and make them 3/16 thought.
(I have snapped one 3/16 octura using 7xl )
allthought I dont know what the torque difference is between gas and electric, the 26cc engines use 65-70+mm props so the55+ mm props that propshop has should work? -this will have about the same rpm´s also.
Octuras are great I know, but not really "scale" looking
Too bad they dont state what bore their(propshop uk) props are -or attleast I couldn´t find any info.
Chris, thanks lets think abou it!
-Pate
Brushless55
01-12-2011, 12:19 PM
Good to know :thumbup1:
FastVee
01-13-2011, 09:47 AM
I will order new struts soon and need to know is 55mm too much prop for this twin t600 apache?
-Propshop starts at 55mm on 1/4 bore props and really would like to get the 1/4 prop shaft, but 3/16 is also available using same 1/4 cable...
This big hull would also look weird if it has ridiculously small prop. :doh:
really starting to like these https://www.mtc-powerboat.de/index.php?lang=en§ion=13&produkt=1 (without fin)
FastVee
01-13-2011, 03:33 PM
update, got the 1/4" (they sell 3/16 shafts for it so no problem if I get smaller props later)
http://forums.offshoreelectrics.com/showpost.php?p=272133&postcount=6
dasboata
01-13-2011, 03:56 PM
Hughey sells a stepped down 1/4 " to 3/16" hardened shaft so you can use your 1/4" struts I usually stock them but I only have the reverse shaft at this time but that is what you need !!
FastVee
01-13-2011, 04:01 PM
Thamks for the info, but MTC also makes spares for this and the 3/16 can be bought seperatly also, one reason I spent 400€ on toy parts :crying:
just hope that everything fits and works...:doh:
edit. the prop shaft is 3/16" after all! -just hope that I can get big enough prop on that.(or use brass bushing and I guess then 1/4 will fit)
FastVee
05-21-2011, 06:24 PM
Ok, did the first drive using 2 bladed 57mm L&R graupners.
Diameter 57L mm(2.24"), Pitch 1.4x57=79.8mm or 3.14"
Now I am trying to get a bit faster props but 3 bladed if possible.
Stainless preferred.
Trying to get the boat to go a bit over 60kph so not much bigger props needed.
here is the video of the maiden ,maybe that helps to figure out better props.
http://forums.offshoreelectrics.com/showthread.php?t=25318
gps showed 55kph.
Rumdog
05-21-2011, 09:20 PM
I'd start by adding some trim tabs.
FastVee
05-22-2011, 08:57 AM
I doubt it needs tabs, the cog was way too back.(batteries ) so it bounced a bit.
I will make battery compartments and laminate them in the hull so the batteries wont move back and mess the cog.:doh:
