View Full Version : Scott's DF21 Mk2
Scott T
01-11-2011, 02:48 AM
Got my newest boat today - a yellow Delta Force 21 Mark2. I was looking for a boat for a 1717 Air, and saw a video for this hull posted on International Waters back in November. I knew straight away I had to have one!
The finish and shape are excellent. It's basically a 37" version of their 45 Mk2. Pics below show it with my DF33.
Scott T
01-11-2011, 02:52 AM
Set up will be:
Castle 1717 Air (1500 kV)
YGE Navy 155 ESC
XPS 65C 6S1P lipos
Speedmaster hardware
FE.com motor mount
Futaba FASST radio
Progress will be fairly slow on this one, as I'm also painting two other boats and building a Whiplash Sport 40 for my other 1717 (car version). Busy busy busy!
nobbiworld
01-11-2011, 04:30 AM
Lots of new toys. Good to see the classes growing. Should be a great year. Steve
Scott T
05-31-2011, 07:59 AM
Have been able to make some progress on this hull recently. First pic is of all the goodies to go on/in the boat.
Second shot shows the motor mounted in the mount. The 1717 has some end play, so I'm using a thrust bearing. The shaft is long enough that the thrust bearing can press on the motor mount and still have plenty of shaft for the coupler. It's all quite neat.
Next was mounting the strut. I've offset it about 3/32" to the starboard to counteract prop walk. I do this on most of my monos and it works well. The strut was shimmed 3mm off the workbench, holes marked, and the strut bolted to the hull. This should provide a good starting point.
Scott T
05-31-2011, 08:07 AM
Mounting the rudder proved a difficult task. I chose a 1" Speedmaster rudder, but the transom of the boat is quite small. The mounting bracket for the rudder is quite large and it took up a lot of space on the transom. The trim tabs weren't going to fit without some serious modifications.
The strut picture above shows the marking out of the rudder and tabs - not good..... I cut the tabs in half (they're quite big anyway) and drilled some new mounting holes for them. I was about to grind a corner off the starboard tab to make it all fit, and decided it was all too hard. I had a 1" tapered speedmaster rudder and it has a much smaller mounting bracket, but the blade is of a similar size. So my original rudder went back in the packet and the tapered rudder is going on. Everything fits much better now.
Scott T
05-31-2011, 08:16 AM
The internal rails were trimmed down because I plan on making a plate for the ESC and mounting it across the starboard rail and the hull.
I made up a spacer block out of some carbon sheet to put the rudder back further (more in line with the prop). Tabs were mounted and the pushrod aligned so I could start on the servo mount.
The servo mount is a 1/8" plywood tray that is held in with 4 screws. I like to be able to remove the tray to get into the shaft area if I ever need to. It works well on my DF33. Some localised thickening to 3/16" underneath will add some strength for the servo screws. The receiver will also be mounted on this plate. I'm happy with the result, it all lined up nicely.
raptor347
05-31-2011, 11:51 AM
Looking good Scott. I've got one here, just haven't gotten around to it yet. Nobody to race those cell counts with around here, so it's get built as a SAW/2-lap boat.
Scott T
06-01-2011, 07:51 AM
Thanks Brian. They're a great looking hull and 6S will pack a big punch! The only downside is the composite transom doubler - good for longevity, but bad for installing blind nuts!
Scott T
06-01-2011, 08:35 AM
I marked the potential CG locations at 30% and 33% and put in the major items. I moved the motor and battery until I was happy with their positions and marked it out. There's plenty of room if I need to adjust the CG later on, but I was looking to get a good place for the motor.
With the motor located, I drilled the holes for the mount. The motor angle was adjusted so that a 3/16 drill bit touched the floor and inch or so ahead of the transom. This will give a nice curve to the stuffing tube and ensures the tube is level where it leaves the hull, for a neat entry into the strut. This boat will have a flooded brass stuffing box, but that's a job for this weekend.
Scott T
06-11-2011, 12:38 AM
Flooded stuffing box is done. It's simply a piece of 9/16" brass for the outer tube and 1/4" brass for the inner tube. The two are sealed at the front with a piece of plywood epoxied in. This allows plenty of adjustment at the strut and good support for the shaft. The alignment of the flex shaft came out really nicely, so everything will run smooth.
Today I added trays for the battery and speed control. We only run 1P, so the tray is only sized to suit, with some allowance laterally for balance adjustments. The notches in the tray are for Velcro straps that will add the the Velcro to be added on top of the tray. The ESC will simply be held in with Velcro.
An extra support was also added at the front of the stuffing box. The boat will be put aside overnight now, and I'll do some work on the electronics.
Scott
i thought you were going to solder this stuffing box this time,,,
tms:confused2:
Scott T
06-12-2011, 08:15 AM
Hey John, I decided my soldering equipment wasn't up to the job. I did spend a while soldering up the ESC and safety loop parts today (iron is good enough for that). This one has all Castle 6.5mm plugs.
I also fitted the cooling jacket to the 1717. Being the Air version, it has flat spots on the fins that need to be filled. I used one of Andrew's Kuhlers (meant for a 1900 Neu) and some o-rings I sourced. The fins were spaced perfectly fo the o-rings to butt up hard against the ends of the Kuhler and keeping it centred on the motor. A liberal application of silicon before the o-rings were brought against the Kuhler sealed each end, and the flat spots on the fins. Sounds rough, but it came out quite neat. I will pressure test for leaks before use though.
Scott T
07-04-2011, 01:47 AM
Plywood trays for the battery and ESC were installed next. Velcro straps wrap under the battery tray, and should give plenty of restraint during the inevitable crashes.....
Scott T
07-04-2011, 01:52 AM
The boat is basically complete now. Just need to install the flotation (pool noodles), charge everything up and let it rip! Slight delay in my plans though, since my baby daughter arrived 4 weeks early! So priorities have changed a bit. My JAE build has also halted for now. I've got a few weeks off work though, so I might sneek out of the house for a test when the missus is asleep :spy:
Scott T
07-04-2011, 01:58 AM
The insides. RX pack is missing from these pics, which goes on the port side in front of the switch. Still needs to be stickered, but those haven't arrived yet.
Tunda
07-04-2011, 03:37 AM
Really nice and clean build.............
Fast One
07-04-2011, 08:41 AM
Hey Scott! Congrat's on the baby girl mate! You are now in our secret little dads club. Yes I have to agree the toys do stop for a while once the first bub is born but it's all good. What am I saying we are having our third child on the 25th July!
I hope you had fun at the Brisbane event, I just could not get the extra leave off work to get there. Might see you soon as I have to come and get my trailer from Artie's place.
Your build looks good though, it should go hard. I am still working on my 6s mono, one of Davos seducer things.
Cath up with you soon.
Shane.
Scott T
07-04-2011, 09:10 PM
Thanks Tunda.
Shane, I didn't race on the weekend, but I dropped in for a while for a look. I heard you've got another on the way. Ours was due on July 21, but she had other ideas! Will catch up next time you're in town.
CHeers,
Scott
Kris Flynn
07-04-2011, 10:39 PM
Hey Scott,
Good to catch up buddy! Looks nice and neat as per usual standards.
Glad to see someone is still supporting the local 'supplier' ;)
Cheers
Kris
Scott T
07-13-2011, 03:22 AM
Stickers have arrived!
Scott T
07-13-2011, 03:26 AM
Alongside my DF33 and SD29. Pick the odd one out! Also the happy owner....
Rumdog
07-13-2011, 01:36 PM
How did you buy this hull???
Chenige
07-13-2011, 02:41 PM
"Flooded stuffing box is done. It's simply a piece of 9/16" brass for the outer tube and 1/4" brass for the inner tube. The two are sealed at the front with a piece of plywood epoxied in. This allows plenty of adjustment at the strut and good support for the shaft. The alignment of the flex shaft came out really nicely, so everything will run smooth.
An extra support was also added at the front of the stuffing box. The boat will be put aside overnight now, and I'll do some work on the electronics."
Is the extra support attached to the bottom of the boat?
thanks
Scott T
07-13-2011, 10:00 PM
Rumdog, I got it locally from fastelectrics.com, but Steve should be able to get them, or order direct from Delta Force. They've been around for about 6 months now.
Chenige, the extra support is shaped to match the floor, and epoxied in place. See pics below.
Scott
i always like to see a boat well built, and well presented,
that way i might get some new ideas,,,,,,
TMS
Scott T
09-17-2011, 07:20 PM
First test runs yesterday (finally!). Could only test on a smaller lake in the area, but signs are good. No GPS, but speed looked good, handling was good, temps only warm. But the real test will be in race water with other boats. That happens next Sunday....
Scott T
09-26-2011, 07:19 AM
Raced her yesterday for the first time and managed 3 wins from 3 starts!! There was some luck involved along the way, but the speed and handling are right up there (against a few Neu/Schulze powered boats). It did hook a couple of times when turning at high speed in the chop, but so did a few of the other competitors. Very happy overall. The 1717 has plenty of power and the YGE speedy is nice and smooth. Temperatures were only midly warm for the motor and ESC, and warm for the cells (XPS 5,000 6S1P). Prop was a de-tongued X447/3.
Hopefully I will get my hands on some photos and video of the racing in the next few days.
Scott
Normal standard, quality built boat from the tapsall work shops
but where did you get that flash boat stand from, did you get it local,
or did you get it from overseas !!!!:tt2:
tms:tongue:
Scott T
09-27-2011, 05:24 AM
Scott
tms:tongue:
That stand is a high quality product! Anyway, here's some photos without the stand......taken by JWT :thumbup1:
lenny
08-18-2012, 08:25 AM
Hi,:tiphat:
I saw you put a link up of your build,
In the Boat hull choices post,
Thanks for sharing it with us.
Very nice boat you did up.:beerchug:
Do you have any videos of it running yet ?:popcorn2:
Looking to build a Pirate 35 or Delta Force Sniper 45 for sport running some day.:tongue_smilie:
KartRacer
08-18-2012, 11:36 AM
Scott
Thanks for posting this link on my thread. It is just the info I need to assist my build. Your boat turned out incredible! Hope I can achieve similar.
KartRacer
Scott T
08-18-2012, 07:18 PM
Thanks Lenny and KartRacer.
I don't have any videos of it myself, but it may be included in some of Joker RC's vids, I would have to check.
I've run the boat with 3 setups so far -
6S1P 5,000 mAh, Castle 1717 (1500), YGE Navy 155, X447/3 (detongued)
6S1P 5,000 mAh, Neu 1527/1.5D, Hydra ICE 240, X447/3 (detongued)
4S1P 5,800 mAh, Neu 1521/1.5D, Hydra ICE 240, X447/3 (detongued).
It's a race winner with all three set-ups, but does chew the cells a bit in the 4S configuration. It's ballistic with the 6 cells setups - gets a bit wild on the straights. I think this hull, or a similar sized hull, would be great with 6 cells, a 1717 motor and a 2-blade 447 prop for fast sport running. You could go 2P, but a full 10,000 mAh isn't really necessary.
KartRacer
10-15-2012, 10:58 PM
Heh Scott
Wanted to say thanks, your build thread was a huge help. Put my boat in the water tonight and am very happy with the outcome! There will be much tuning to finish it but was a big relief to finally get it wet!
