View Full Version : Miss Excite Hydro Thread
Has anyone ordered one of these boats yet? Figured I'd ask, haven't heard to much about it yet.
Brushless55
01-13-2011, 12:49 AM
like to know to..
jamespl
01-13-2011, 12:53 PM
Why would anyone pay over the adds for one of these when you can get the red evo for half the price!
Brushless55
01-13-2011, 02:10 PM
hey some do it..
jamespl
01-13-2011, 02:32 PM
I know and I must admit I like the miss exite paint job I just wouldn't pay the extra for it. Plus it comes with the outrunner clamp which limits your motor choice as I have found with my P1.
Brushless55
01-13-2011, 02:46 PM
I do like the Red Evo
martin
01-13-2011, 03:52 PM
A friend has the Red Evo, Saw it run last sunday. Its still early days in him running it but it wasnt that fast i would guess around 35mph. Its stock with a 2636kv FSD motor & 50amp esc so it will only take 3s. He had collided with another boat on a previous outing & had some very serious cracks indeed along the top of the sponson around 8-9" long right in the middle of the sponson about 1.5" in from the edge of the boat. The gel coat was very thick but the glass cloth was very thin & flexy. Thanks Martin.
jamespl
01-13-2011, 04:03 PM
I'm thinking about getting one and running it with the suppo/turnigy H3126 outrunner 2200kv 90a seaking and 4s, prob a x640 or x642. I'm using the H3126 1600kv in my P1 on 5s and it goes like stink.
Brushless55
01-13-2011, 07:08 PM
That sounds like a great combo on 4s!
JackBlack26
01-13-2011, 10:34 PM
Some guy had one at the lake last Saturday and it looked awesome!!
Where does one find the cheaper priced model? Any links??
Brushless55
01-13-2011, 10:45 PM
Right here!
http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=13779
JackBlack26
01-14-2011, 04:10 PM
Oh, thanks! They're out of stock but I had to add it to my wish list. I like the HK paint theme better than the Venon theme.
jamespl
01-14-2011, 04:19 PM
I have had it on my wishlist for around 3 months now, i don't think it's coming into stock any time soon. I've seem it at galaxy models in the UK for £170
JackBlack26
01-14-2011, 08:56 PM
It's probably not coming in to stock because Venom is getting first dibs, lol!
Gotta ask, but is this the same as the delta force 22" hydro that OSE sells the hull for $85? Looks the same. Just wondering.
Brian
Brushless55
01-14-2011, 11:04 PM
Brian
yeah, it's a splash of the CF hull :thumbup1:
BILL OXIDEAN
03-02-2011, 10:34 AM
The newer version of Miss excite is incredible. On 4s it hangs right in there with a UL-1.
If you're going to gut the boat as far as power system you're still better off with the excite. The package Venom puts together now is great and definitely an improvement over their previous kits..
I finished 1st place 3 out of 4 heats at the Grand prix classic against a field of nitro and electric sport 21 boats..
Just wamting to know some info on these i bought one today it's all good but the turn fin is on the left and is tilted inwards
is this normal
Namba328
08-24-2011, 06:29 PM
You mean the rudder? if its the one on the transom you want to straighten that out.
BILL OXIDEAN
08-24-2011, 06:33 PM
is this normal
That is correct, it shouldn't be on the left side.
A batch was made incorrectly. Send it back to Venom they will gladly replace it, or upgrade to a better turn fin as I did and mount it on the other side
I have modified the original one to fit the other side but i was thinking about using one from a ul1 for the adjustability or will it be too big, the stock one starts to lift on straights at full speed, the hull actualy sits about an inch above the water its fast but unstable. Ran a v940/3 with a 2200kv motor on 4s but still want it to go faster maybe doing 45-50 mph
BILL OXIDEAN
08-25-2011, 10:37 AM
I used one that was even bigger, but the UL-1 fin should work great..
Namba328
08-26-2011, 12:44 AM
Exactly. The Ul-1 should work and give you a lil more adjustability to work with and trust me Bill knows how to make one of these boats run sweet.
What rpm is good to run with hydros do they rather smaller props and high rpm, are two 5000mah 2s batterys to much weight in the front i was thinking about trying 3200mah
Namba328
08-26-2011, 11:08 AM
Honesty when it comes to hydros it depends on the hull and the equipment used. the 2 5000 2s packs will be fine being Bill runs a hard shell 4s Venom pack so im sure your packs arent as heavy as his lol. So my question for you is what motor, esc and prop are you using and 2. what c rating does your packs have?
well i am using 2 venom hard case 35c packs, with a hobyking 3650 2200kv and a mystery 80a esc and i have tried x637,x437/3, x442 back cut and detounged v940/3
also changed the rudder to one with pickup holes on both sides
Namba328
09-01-2011, 06:23 AM
and whats the fastest speed that you have hit?
have not put gps in it yet just trying to get the right set up i think when i was running the v940 it was very flat and turned well but the prop might have been a bit big and not letting it rev free enough so i want to try the v937 or something with less pitch maybe, as for speed i would say 40-45mph as my ekos does 55 and the gas version does 67 so im judging from that
Namba328
09-01-2011, 07:29 AM
have you tried the 36mm 1.4 pitch 3 blade alluminum prop from venom???
i have tried a x437/3 it runs ok not fast enough
Brushless55
09-01-2011, 08:58 AM
67mph?
what motor are you running in yours??
rctoyznhobby
09-01-2011, 11:27 AM
anyone have a red evo in the US for sale or the exsite
Namba328
09-01-2011, 07:57 PM
try a 440/3 or a 442/3 and do you have any angle in your strut?
in the gas one has a sikk 27 4 bolt version with porting done its got so much power now, it turns a x470/3 with ease
i have tried a x442 speed was ok but the lifting prop sat much nicer on the water
Brushless55
09-02-2011, 06:38 PM
I'de love to see a video of your gasser!!
I sold mine last year...
Namba328
09-03-2011, 06:18 AM
well lifting props work for some things lol ive never liked using them because i use the strut to raise the ass end up lol
BILL OXIDEAN
09-03-2011, 07:02 AM
You gotta remember these gas guys are limited in r's we do it with ease with electric but fuel boats need a little help keepin her arse up SOMETIMES.
Namba328
09-04-2011, 04:36 PM
exactly so the electrics don't absoulutely need to run lifting props because yall have all the r's u could ever need lol
i've actualy only got one gas and 8 electric but mostly cats and monos so im new to lifting props and as i tried one for the first time it ran real nice, i was impressed thats all
Namba328
09-05-2011, 11:31 AM
KOS i guess what im trying to figure out is how fast are you looking to go with your setup.
I think around 50mph should be ok thinking about using 5s and a x637, motor says it will handle 6s but i dont want to go that far
Namba328
09-07-2011, 12:50 AM
That otta do it lol. If not try a x642. I have had great luck with x642's when it comes to electric sport hydros lol.
sporthydrofan
06-13-2012, 10:41 AM
try running either a:
y536 it will lend itself to high rpms
for 3 blade the y537-3 it pretty good but needs a powerfull motor on 4S
x440 will give you big hole shoot but need a powerfull motor as well.
and the x640 is the top end prop i like the best but you better match up the motor and esc correctly or poof majic smoke from the ESC...
Rumdog
06-13-2012, 01:35 PM
Last post was 9 months ago, g freak.
sporthydrofan
06-13-2012, 03:03 PM
ohh god your like a little fly that keeps buzzing past my ears and i cant seem to swipe it out of the air.... enough with the gfreak crap already im not gfreak.. please stop bothering me ... im not going to all your posts and harrasing you am i?
Joe007
10-24-2012, 01:52 PM
sporthydrofan I just bought a Miss Excite and will be using the stock motor/esc what is the best prop to get for it in a 3 blade metal prop.
I want some more speed out of it. I will be running 3s and 4s lipo's.
Joe
Scamp73
12-23-2013, 12:54 PM
Can this boat handle 5s without any mods? Or what have you guys found to be the best battery set up?
BILL OXIDEAN
12-24-2013, 01:13 PM
She doesn't want 5s on the stock system. I have a 5s system that propells it to about 80+
http://www.youtube.com/watch?v=H4PadPAK-Ls
BILL OXIDEAN
12-24-2013, 01:15 PM
Joe
On 3s or 4s you will do well with the venom red 36mm cnc prop
Or, my uncle runs a V937 sharpened and ballanced and the thing blasts off..
Scamp73
12-24-2013, 01:31 PM
Great, thanks for the response. Literally at the lake about to put it in.
Shun Tung
03-15-2014, 02:07 PM
Hi bill,
Why you need red venom 36 mm 1.4 p prop ? I seem this item was discontinues in atomik web suite . But I seem
another one same size and pitch prop only is silver Aluminium. What's diffrence between of this two prop effect ?
Please advise ! Thanks !!
BILL OXIDEAN
03-15-2014, 02:29 PM
The red one may be a bit more durable, but the silver one is just fine! : )
Shun Tung
03-16-2014, 12:06 AM
Noted with thanks Bill . Can I asked you one more question ? I seem your miss excite is really very fast .
Did you change the motor and special setting ? If you don't mind , please teach me how can I improve my miss
Excite more speed and stable running in the lake . Thank you so much !!!
dlhcon
03-19-2014, 12:18 AM
I have a Red Evo i am willing to sell.
Shun Tung
09-21-2014, 11:08 AM
Any master can be advise me if I change the motor on this boat . The 3650 1800 kv inrunner or H3126 2200kv outrunner motor which one is better on the speed ? I tried to put proboat 1800 kv inrunner motor in this motor mount . But this mount is too small. Any same size motor mount plate but the hole is fit 3650 size motor ? Please
advise !! thanks
