View Full Version : Prop Diagram
01-06-2011, 04:47 PM
http://www.offshoreelectrics.com/images/propeller_diagram/prop_diagram.jpg
bwells
12-21-2011, 11:29 PM
Broken tip on the left side?
12-22-2011, 06:07 AM
I used a new prop, so it wasn't broke. I think it's the way I took the photo.
Mike Caruso
09-10-2012, 09:41 AM
Great explanation and picture Steve need to be in a Read this first Newbe and yes for everyone.
Mike Caruso
10-07-2012, 07:38 AM
Steven,
Here is a copy of the latest Octura information sheet 9.2012 listing the Prop number, Diameter and then Pitch.
Makes it easier for me to follow and then make a decision on which ones to order.
Mike
10-07-2012, 09:01 PM
can you email it to me or try to attach it again?
Mike Caruso
10-07-2012, 09:22 PM
86032
Here you go Steven
Fixitguy1
01-09-2017, 02:19 PM
Trying to find where to buy a b/s x440/3 I think it is a stainless steel for my Miss Geico 29 v3 all stock
01-09-2017, 02:37 PM
I just sent you a pm.
Fixitguy1
02-06-2017, 11:21 AM
I just received two Octura X440/3 props and both of them seem to have the same problem, they will not fit the drive dog.
it seems that one side of the slotted end of the prop is misaligned and if I removed about 1/16" from one side on the leading edge it would fit, but would be out of balance. what would you recommend.
02-06-2017, 01:41 PM
Do you happen to have a picture? Sometimes the slots have to be opened.
Peter A
02-06-2017, 02:04 PM
Use a 5/16" (8mm) od drive dog.
ray schrauwen
02-06-2017, 04:14 PM
Yep use the little doggy.
02-06-2017, 06:40 PM
Removing material from the hub has less of an effect on practical balance than you may think. Removing 1/16" from the slot sounds like way too much however...
Fixitguy1
02-07-2017, 03:13 PM
The drive dog slots are fine the tongue material is covering the the drive dog slot on one only
Fixitguy1
02-07-2017, 08:30 PM
149347149348149349
Hope you can see this.
