View Full Version : Skunkworks gen 2 twin...........
bigpapa
01-05-2011, 11:27 PM
Gen 2 skunkworks twin build, this is one awsome hull 4 sure
2 turnigy 26oo kv inrunners
hobbywing 120 esc x2
twin strut drives
hull mounted water pick ups
4s 5000mah 35c to start
carbon fiber matte
bwells
01-05-2011, 11:45 PM
Bigpapa, how long is it and why struts over stingers? Is there room on the transom for struts to attach?
bigpapa
01-05-2011, 11:54 PM
32" and had the struts something diffrent you might say
bigpapa
01-05-2011, 11:55 PM
Inside of the cat
bigpapa
01-05-2011, 11:57 PM
Struts and rudder mounted..................
bigpapa
01-05-2011, 11:58 PM
Water pickups and water outlets installed
JMSCARD
01-06-2011, 12:00 AM
Todd who makes that Pull/Pull rudder you are using? looks like a nice size for my maritimo project I just picked up....
Lookin really good too todd..., nice work...
bigpapa
01-06-2011, 12:02 AM
Really do not know jason aquired it with a lot of parts sorry
JMSCARD
01-06-2011, 12:04 AM
well it "fits" on your hull nicely... thanks anyways, take care and vid of it running for us:bowdown:
bigpapa
01-06-2011, 12:07 AM
I shall gonna pm u some one that may help u
bigpapa
01-06-2011, 12:09 AM
Pm sent jason
Jeff Wohlt
01-06-2011, 12:11 AM
Nice...those struts will always give you much more adjustment. You can run teflon and leave about 1"-1.5" to the strut with teflon only and you will be able to adjust easily. No problems with wire.
Yes, I will get you set up with some 078 wire drives and couplers.
bigpapa
01-06-2011, 12:20 AM
Tks my friend everything kinda just fell right into place................
bigpapa
01-06-2011, 12:21 AM
Used jan's water pickups the worked out perfect ...................
bigpapa
01-06-2011, 12:22 AM
Watercooled aluminim motor mounts on the way
bigpapa
01-06-2011, 12:30 AM
Jeff do you have telfon i need also...................
Jeff Wohlt
01-06-2011, 12:34 AM
I will look...not sure any more but.... I think McMaster has it.
Brushless55
01-06-2011, 01:42 PM
2600kv x 4s
holly crud, this thing is going to be fast! :rockon2:
johnf
01-06-2011, 07:07 PM
Todd loves building some water hot rods. Lol
LarrysDrifter
01-06-2011, 09:03 PM
Nice build.I like this one.Its a little different and should haul pretty good.Your doing a fine job my friend.
rearwheelin
01-06-2011, 11:26 PM
Perfect hull size !! Love the struts, super strong ! Dieing to tell you the way I did the struts on the Quad.............. I ran the stuffing tubes 100% in and then backed them out enouph to counter sink the bushings into the strut about 1-1/2 mm. You will never be able to do this with ease if you don't sand your brass tube and then hit it again with some finer stuff. The best way to do that is to put your brass into a drill and not tighten it to tight, then pull the trigger on high and fold your snd paper and pinch the brass , king of like a lathe. Be carfull using steel wool , it will grabb and tweek your brass if not carfull. Do that untill you get your desiered fit . Greese and should go on and of great and will never back track water ! Also I run 3/8 o.d. octura thrust washers and minimal gap. .....about a thumbnail.... .... Sound like its going to be fast !:thumbup:
bigpapa
01-09-2011, 02:13 PM
tks my friend
bigpapa
01-09-2011, 02:15 PM
watercooled motor mount 1 motor mounted and fitted, stuffing tube aligned ready for epoxy now..............
:banana::olleyes::banana:
egneg
01-09-2011, 02:28 PM
Looking good Todd. I took everything out of mine and am now waiting for it to warm up enough so I can paint it. Have you thought about what you are going to do?
bigpapa
01-09-2011, 02:39 PM
tks chuck two turnigy 2600 kv, 540's,2 turnigy 120 esc v2, 4s 5000 mah 30 c ,2 props u did for tracy 2 blade props u cut down to 45's lime green suck as my thunder tiger outlaw in my avatar
egneg
01-09-2011, 02:44 PM
Speaking of Thunder Tiger how is the Bandit BL.
bigpapa
01-09-2011, 02:47 PM
think the esc is bad starts off flying for about 45 seconds and then seems to go to just about half throttle, gonna swap the 60amp out for a 120 and see
bigpapa
01-09-2011, 02:48 PM
but other than that lover it great hull just gotta find time to piddle with her..........
bigpapa
01-09-2011, 11:43 PM
both mounts aligned and epoxed in place, progress progress progress
:banana::buttrock::banana:
johnf
01-09-2011, 11:51 PM
Awesome Todd! I'm coming to see it run when its ready! Those cut down props are 2 blade btw.
JMSCARD
01-09-2011, 11:52 PM
Very very nice todd!!
Brushless55
01-09-2011, 11:59 PM
Looks nice and clean man! :banana:
bigpapa
01-10-2011, 12:16 AM
tks guy's gettin kinda excited
bigpapa
01-11-2011, 12:40 AM
motors in (both)mounted cooling sleeves, now to epoxy tubes to boat next and mount servo and run servo wires and tubes ...............
:banana::Peace_Sign::banana:
bigpapa
01-20-2011, 11:00 PM
servo mount(carbon fiber) and steering rod boots in , now gotta mount, then off to paint
johnf
01-21-2011, 12:32 AM
Pics Todd!
bigpapa
01-23-2011, 10:19 AM
updated pics of the twin
bigpapa
01-23-2011, 10:21 AM
props and cables installed
Rumdog
01-23-2011, 11:01 AM
looking good Papa! Gonna go with outward spinning props, huh?
How long till some vid?
bigpapa
01-23-2011, 11:06 AM
Yes they are right and left rummy going as fast as i can lol
bigpapa
04-11-2011, 11:55 PM
update painted now
BakedMopar
04-12-2011, 02:26 AM
Very Nice Todd!
egneg
04-12-2011, 05:36 AM
Is that a pearl paint Todd?
bea5017
05-17-2011, 11:43 PM
can u please post a straight on side view if you get a chance, i wanna check out how the stuffing tube looks attached to ur struts... thx
tagasagwan
11-14-2011, 01:43 AM
Hi Bigpapa,
I'm wondering what happened to this twin motor project? any new developments? I love the color! I also painted my E-Speedmaster 29" mono project with pearl yellow from the new Lexus LFA.
More updates of your built pls.
Stephen
