seaking 180 timing
  • Gen
    • Dec 2010
    • 107
    seaking 180 timing
    guys the defult setting for the seaking 180 esc timing is 15.00 is this ok with 4s in a cat with 2100kv ? ,as i know in my cars the timing is always very low or 0 or your temps are thru the roof ,,please explain ??
  • sailr
    • Nov 2007
    • 6927
    What MOTOR? Feigao? Neu? Leopard? etc? That is what determines where you want the timing set.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • Gen
      • Dec 2010
      • 107
      feigao 2073 kv
      • 57burb
        • 17
        I'm also interested to know. I have a Neu 1515 1Y. I've run it at 18* and 22* but it doesn't seem to be any faster than at 15*. But the run times are shorter and temps are MUCH warmer with the higher advance settings. Thanks.
        • Diesel6401
          Memento Vivere
          • 4204
          Originally posted by Gen
          feigao 2073 kv
          Try 7.5*
          I would keep at 15*
          - Diesel's Youtube
          - Diesel's Fleet
          • sailr
            • Nov 2007
            • 6927
            I would run that motor around 10-12 degrees.
            feigao 2073 kv
            Mini Cat Racing USA
            • sailr
              • Nov 2007
              • 6927
              Too high. Some run that motor at ZERO-5 degrees. 15 degrees is as far as you want to go. The higher the timing, the shorter the runs and the temps go up.
              I run the 1515 1Y at 8-10 degrees
              This is direct from Steve Neu:
              Suggested controller settings when using the CC125 and CC180 controller.
              Set cutoff to 4 volts (option 2)
              Disable current limit (option 5)
              Brake type: Hard brake, no delay (option 4)
              Throttle type: Fixed throttle (option 2)
              Advance: Low advance timing (option 3)
              Cutoff Type: Soft cutoff (option 2)
              Soft Start: Fast start (option 3)
              PWM Switching Rate: 13 kHz (option 1)
              Mini Cat Racing USA
