View Full Version : 6S on Turnigy / Seaking 180A ESC?
haianhusa
12-15-2010, 07:58 PM
Has anyone tried 5s or 6s on Turnigy / Seaking 180A ESC. It claims to support up to 6s but I tried 3 times (2 times on 6s and 1 time on 5s) and 3 of mine ESC got burnt. I used the internal BEC though. I want to try again without using the internal BEC but I am a bit too scared. Can anyone please give me your input.
Thanks.
Allen Pham
blackcat26
12-16-2010, 09:44 PM
I think you may have run into trouble is using the BEC over 4s. I think with a castle bec or a Rx battery you will have no trouble. There is a member here running a twin cat with castle 1717's on 6s no problems on t180's.
haianhusa
12-17-2010, 01:25 AM
How do you disable the internal BEC? Do you just remove the red wire from the connector that connects to the receiver?
blackcat26
12-17-2010, 07:41 AM
Yes. Just take a small screw driver or something and gently pry the metal section out of the connector (red wire). Then you can run battery pack or a Castle BEC.
Rumdog
12-17-2010, 09:07 AM
If you've burned 3.... why would you try again? Good luck.
forescott
12-17-2010, 05:20 PM
I'd be curious to hear the hull/motor/battery/prop setups used with your t-180's that burned.
