View Full Version : HPR06 - Austrian Build
ManuelW
12-13-2010, 05:15 PM
Hello Guys,
as there seems to be some interest, I'll start the building review of a HPR06 also here on OSE. I hope you enjoy. Beside this, where would be a good place here to introduce myself and tell a bit about me and my hobbies?
Beside building my "Fort-Knox" (nice expression Gerwin) I'll also build a HPR06 for season 2011. With my Repsol I have already a HPR06 so a second one is not necessary. Only Hanspeters new C5009 Mystic would be worth a try...:rockon2:
So the HPR06 in this review is a remittance work, which I'll do for my friend Wolfgang. He has seen our boats on our homepage as well as on Youtube and wanted one. Thats why I should build this HPR06 completely RTR including testing and finding the right setup for the boat. The choice of the setup is mine, the demand is to reach about 120km/h (75mph). Its not intended to be a highspeed model, scale look and reliability are more important.
Therefore it will also include a second hatch with the cockpit glasses for the glass cabinet as well as some pilots inside the cockpit. Surely the boat will also get a nice paint job, maybe with some airbrush.
Setup
hull: HPR06 in CFK (carbon/fibre - newest Version)
hardware: original HPR hardware including hydraulic steering
engines: 2x Tenshock 2250/7 with WK
ESC: 2x 180A Seaking/Turnigy with aditional caps
lipos: 2x 6S Turnigy 4000mAh 40C
props: pair of Octura X442 to Octura X447
speed: personal aim is to reach 130km/h (81mph)
transmitter: Futaba T3PM 2.4GHz mit FASST
miscellaneous: lipo-rail-system, CFK-motor mounts, CFK-servo mount, Notaus, 5mm Flex-Wire v. Gundert, 6mm LMT-bullets (best in the world I think), bolted hatch, div. scale parts
hull
As mentioned the hull is a HPR 115 in carbon/fibre. Hanspeter has again improved some parts of the laminate, this hull is the up-to-date version, beside being a "default-laminat" if you can say that to his hulls. The seam as well as the finish are crafted beautifully. As with all of my hulls it had to prove itself on the scale. The hull has 1975g, the hatch 275g --> makes altogether 2250g or 4.5pounds. Its not an ultralight hull but a normal carbon/fibre hull with reasonably weight and exceptional stiffness.
Here some pictures:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_100.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_101.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_102.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_103.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_109.JPG
ManuelW
12-13-2010, 05:22 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_104.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_105.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_106.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_107.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_108.JPG
(I still like the look of this hull very much altough it might be a bit old-fashioned compared to the new mystic design)
mounting the rudder
First I have mounted the rudder. For this I use double sided tape on the mounting surface of the rudder and cut the shape out as exact as possible. Afterwards I stamp out the holes for the mounting drills and adjust the rudder on the hull using a bracket and an even surface.The height adjustment is just with visual judgment, I think thats good enough.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_110.JPG
ManuelW
12-13-2010, 05:27 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_111.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_112.JPG
Then I take of the rudder, leaving the template still on the hull. I mark the holes and pre-drill them a bit by hand. Then I take the cordless screwdriver and drill them through, followed by a short test mounting if it fits as desired. As you see, the screws don't look good, they need an even surface.
So I use my Dremel with a spherical miller and grind the inside before filling it up with black epoxy resin. At least I put in a suitable piece of carbon fibre for strength and optics.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_113.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_114.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_115.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_116.JPG
ManuelW
12-13-2010, 05:28 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_117.JPG
Finally I use some extra-long M3 screws (stainless steel !), cut them to the right length and the rudder can be mounted.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_118.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_120.JPG
F1 madness
12-13-2010, 05:43 PM
Love these HPR cats,will be watching with interest:spy:
Gerwin Brommer
12-13-2010, 05:59 PM
Manuel : Fort Know ? ;-)
ManuelW
12-14-2010, 02:11 AM
@ Gerwin: Sorry for the typing, now its "Fort Knox" :cool2:
mounting the hydraulics
It was also my first time to mount these hydraulic mockups but its really easy and just looks amazing. How have I done it? First I mounted the hydraulik steering to the pivot of the rudder and adjusted the two hydraulic cylinders parallel to the "rump" of the hull. This means a distance of 6mm (1/4" should be right as well) between the mounting parts on the rear side of the hull to the bend for the "rumpf". Then I aligned them horizontally and fixed the 2 plates with double sided tape.
Maybe its contingency but the stainless steel wire exactly goes through the seam of the hull. At least drill the holes with a 2mm drill - finished.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_121.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_122.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_123.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_124.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_125.JPG
ManuelW
12-14-2010, 02:24 AM
drives
Last parts of the original hardware are the drives. This is my way, maybe a bit unconventional but it works. First I fit the drives to the desired position, I don't try to fit them exactly to the apex of the rear side. As you can see on the pictures the mounting plates have an offset of about 3mm to the edge of the tunnel.
On the upper mountings I made a little fillet, now they fit exactly in their position. These are the first parts I mount first, as before double sided tape before drilling the holes and screw them to the hull. Afterwards the same procedure to the mountings on the rear side of the hull. They have to be aligned 100% parallel to the hull, for this I use an aluminium profile and drills in 0.5mm steps. I put the aluminium profile to the inner side of the hull and adjust the drive till the gap between the drill and the drive is even over the whole length. I think the right distance was 8.5mm. Then you can mount the drives.
Last thing to do is to drill the hole for the "Steven-Tube" (brass tube where the flex shaft runs inside the teflon. For the used 5mm flex-wire I use a 6/8mm teflon tube and a 8/9mm aluminium tube. To mount it exactly in the middle I used a self made bushing with 9mm inner diameter and the right outer diameter. Now you can drill the holes and the'll be centered.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_126.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_127.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_128.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_129.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_130.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_131.JPG
DISAR
12-14-2010, 03:37 AM
This is a real beauty.... an exceptional interesting thread.......
What kind and how many extra caps will you use?
RaceMechaniX
12-14-2010, 04:24 PM
Great build detail, please keep it up!
TG
Anbjorn
12-14-2010, 05:16 PM
Very nice Manuel. :thumbup:
I will be following this closely.
Anbjørn
H2OCamel
12-14-2010, 09:03 PM
I love these cats!
old guy
12-16-2010, 11:10 PM
:popcorn2:
ManuelW
12-27-2010, 12:47 PM
motor mounts
For the motor mounts I made some models out of cardbord. Took three tries until I had the desired fit inside the sponson. The contour was lined two times on a 2mm thick CFK HT plate.
Afterwards the usual stuff, cutting it out roughly and then grinding, filing and drilling the holes. Used bolt circle is 6x60° with 25mm (600er can size). At least two clearances for the cooling circuit as well as for saving weight and the optic.
I'm really satiesfied with the result, they look as desired.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_132.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_139.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_140.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_141.JPG
ManuelW
12-27-2010, 01:06 PM
Securing of the hatch
Quite an often discussed topic here. Haempu recommends two screws and two bolts, I decided to use four countersunk M3 screws. They are easy, inconspicuous and strong enough for the desired performance. On faster hulls (like my own HPR135), I'd go for M4 screws and maybe also increase the number to six screws.
First I center the hatch "inside" the hull with leftovers of CFK/GFK plates because they are available in 0.5mm steps. When the position is fixed I mark the positions and then drill a 2mm hole through the hatch as well as the hatch border inside the hull. The holes in the hatch are bored up to 3.5mm and then I make the counter sunk for the screw. For the holes in the hatch border I bore them up to 6mm because inside I use M3 knurled nuts if you know them. They can directly used, you just have to grind them a bit as well as the border in the hull and after degreasing I glue them in with some epoxy resin. It gives a nice look too.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_133.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_134.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_135.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_145.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_148.JPG
ManuelW
12-27-2010, 01:09 PM
Air scoop
Haempu probably won't like my solution but I find it easy and convenient. I fixed it and then drilled three 2.5mm holes completely through the scoop and hatch. Then I cut M3 threads in the resin scoop and glued it with resin to the hatch as well as I secured it with M3 screws. Surely I have to grind the end of the screws and spackle the scoop but it should be a connection for eternitiy and looks nice inside too.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_136.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_137.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_138.JPG
Lipo Rail System
For mounting the Lipos I use a self made lipo rail system, probably the best known solution. I made the design with a CAD programm, the parts were cut out of CFK material on a milling machine. Ground plates measure 71x350mm and are out of 2.5mm HF CFK material. The sledges are out of 2mm black GFK, I think it gives a nice contrast concerning optic. You can move the packs about 125mm and 4-6S packs can be mounted - way enough for that project. For bigger projects I make these systems quite bigger, in my Supercat XL one ground plate already measures 475x120mm (!), at the moment I'm limited in size of CFK parts through the available material at 1000x500mm :confused2:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_182.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_183.JPG
ManuelW
12-27-2010, 02:08 PM
fixing the motor mounts
First I mount the motors on the mounts. As I still don't have the motors for this boat I used two LMT 1950 out of my HFK Prototype as kind of dummies. I need them to align both mounts as symmetrical as possible. Looks weird to me when the motors are not symmetric in a boat. The I position them in the hull and use a coupler and the flex shaft.
As flex shafts I use 5mm flex-wire from Gundert, I think its the best and strongest available. More common is the 4.75mm or 3/16" FlexWire but I'm not a fan of these. Then I adjust the mounts till I get a smooth curve in both flexwires.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_153.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_154.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_155.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_149.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_150.JPG
ManuelW
12-27-2010, 02:12 PM
Before I glue them in with resin I grind the right surfaces of the hull and the mounts, then I degrease everything with so-called "Bremsenreiniger". I didn't find a translation but it might would be "Brake Disc Cleaner".
Then I align the mounts again and fix them with some small dots of CA glue.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_157.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_156.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_159.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_160.JPG
ManuelW
12-27-2010, 02:53 PM
As you get dirty hands I have no photos of glueing them in, therefore I have to describe it. First I make a seam with some thickened 24h epoxy which I colored black. Then I laminate over each seam a layer of glassfibre with normal clear resin. Then I make the same on the other side of the mount. So each mount is fixed at about 20cm lenght with a resin seam and glass-fibre reinforcement.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_158.JPG
mounting the drive shafts
After the motor mounts I fit the drive shafts, they are made out of a10/9mm aluminium tube. I make a smooth bend till the flex runs nearly without any friction and the tube follows the natural bend given through the motor mount. The water intakes are out of 4mm brass tube, you can see the position and how its built in on the pictures. The support of the drive shafts is out of 2mm GFK. After carefully sanding and degreasing everything I glued it in with 5min epoxy resin which I colored black to match the optic of the hull.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_151.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_152.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_161.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_162.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_163.JPG
ManuelW
12-27-2010, 03:16 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_164.JPG
radio plate
Wolfgang likes scale optic and also a normal servo mount didn't appeal to him so it was the first time I built a radio plate in a boat. As it should be something special I designed it with a CNC program and it was also cut out with a milling machine. The letters are a groove in the surface and I think the optic is astonishing. With some motivation I'll paint the inside surfaces of the letters. The RC plate is mounted with glued in knurled nuts as sockets.
As for sure I used black expoxy resin as well as glassfibre reinforcements.
You may excuse the dusty optic of the hull but as I'm working all the time I had little motivation to clean it every time I make pictures. You may also see how I glued in the drive shafts and the water intake.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_165.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_166.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_167.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_176.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_177.JPG
ManuelW
12-27-2010, 03:25 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_175.JPG
glueing in the lipo rails
I already presented the lipo rails, they are glued in using silicone. You may also use resin but silicon is strong enough as well and damps a bit in the case of a crash. They may also be removed whereas with resin this can get tricky. To glue them in properly I refilled the silicone in a syringe. The uper side of the plates I taped with Tesa to stay clean.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_168.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_174.JPG
Anbjorn
12-27-2010, 03:39 PM
Very nice build and well explained.
Thank you for sharing:thumbup:
Anbjørn
ManuelW
12-27-2010, 03:42 PM
built in parts
These pictures don't really fit anywhere but as I like them that much I'll present them here at this point. They show a decent constellation of all the parts that came inside the hull. You can also see the four 6S1P 4000mAh 40C Turnigy Lipos which will be used.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_142.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_143.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_144.JPG
ManuelW
12-27-2010, 03:44 PM
Drives and Flex-Wires
This was a work I acutally did today. I glued the flanged ball bearings in the drives as well as the flex-wires in the drive shafts. For this I use Loctite 648. The drive shafts I bored up to 4.9mm on Flos turning lathe and sanded the 5mm Flexwire until it fitted perfectly inside the drive shafts. After glueing these parts together I put them in the oven at about 60°C for tempering and improved strengthness.
(Leave them inside and turn them after 45min until they are golden brown and crispy on both sides, enjoy them still hot..... :w00t:)
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_170.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_171.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_172.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_173.JPG
So thats enough review for today and a lot of work is already done. I hope you may enjoy it. You can also ask questions or propose improvements if you like.
Best regards,
ManuelW
JCAustralia
12-27-2010, 05:48 PM
Manuel
This thread is fantatstic and will undoubtledly be a reference to any boats I build in the future. Well done:hug1:
Cheers
JC
domp444
01-06-2011, 12:08 AM
Hello! Beautiful boat and I love your work. I would like to know what type of silicone you are using to glue in the lipo trays?
ManuelW
01-08-2011, 04:03 PM
Well I can recommend to use aquarium silicone which you use for aquariums/fishtanks. Its also availabe in black and you get a nice optic.
Best regards,
Manuel
domp444
01-08-2011, 04:05 PM
Thanks! I will try to find some.
ManuelW
03-02-2011, 05:13 PM
Hello Guys,
and here another part of the HPR06 Austrian build - review.
Not-Aus
As far as I can see it here a "Not-Aus" is not very common here at OSE. Where I live I think its nearly a must have and also a need on every boat meeting. What it does: Disconnects the receiver from power supply, eg. UBEC or reveiver battery. What for: Its a safety thing, when you pull the "Not-Aus" and the controller (without BEC) has no power it can not run. So if you have to rescue the boat or just want to change props without opening the hatch I can only recommend it. Here I used 3.5mm female bullet connectors which i glued to the surface of the hull. But be aware: CF-Sheet conducts electricity, therefore these connectors have to be 100% isolated from the hull:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_193.JPG
The built-in system can be seen on the following pictures!
Exhaust
As Wolfgang turned out to be an absolute scale fan I decided to make some custom exhausts for his HPR06. So basically I made a mockup from wood, used shrink tube and wax to get a kind of a positive mold. With some CF- and GFK sheet I laminated the "surface". After a bit of cutting and grinding I had the desired shape. Then I cut off two small pieces of brass tube and some CA glue to make the prototype and hoped Wolfgang would like them. On the photos you can also see the "Not-Aus", already with the male connectors in them.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_194.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_195.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_196.JPG
ManuelW
03-02-2011, 05:18 PM
Luckily Wolfgang liked it and so I could make the final ones. As brass tube was not perfect my friend Christian made me some exhausts out of aluminium on his lathe. First I wanted to polish them but then I decided to have the "brushed"-look. As it can be seen I glued a small GFK sheet inside the exhaust and drilled two holes in each one. Behind these I filled everything with expoxy and also put in two M3 nuts. So I can srew each exhaust with an M3 counter sunk screw to the exhaust. I hope you may understand.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_211.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_212.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_213.JPG
ManuelW
03-02-2011, 05:23 PM
Wind Screen
If you want each HPR06 is delivered with a windscreen and window frame. As said Wolfgang likes Scale this was a "must-have". But as this might also be a weak point I used a broken and repaired hatch from my HPR06 for this. So basically he has two hatches, one for driving just with the air scoop and another one for presenting it with air scoop and window-glass.
First a picture of the set and the repaired hatch. For these I used M2 hew-screws with a flat head because they look the best.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_203.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_204.JPG
After that I drilled 25 holes with a 2mm drill, the holes are already implied on the window frame as you can see in the picture above. After that I cut it out and fitted it to the hatch:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_205.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_206.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_207.JPG
ManuelW
03-02-2011, 05:27 PM
As it can be seen above I fixed it to the hatch and drilled the 25 holes also through the hatch. The blue line marks where I have to cut out the hatch itself. But before this I cut out the plexiglass windscreen with a small scissor. Quite tricky to get it right, especially in the narrow corners.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_209.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_210.JPG
After that I cut out the windows from the hatch and screwed everything together. Doesn't it look nice?
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_214.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_215.JPG
ManuelW
03-02-2011, 05:34 PM
Next step was to mount the 6S1P 4000mAh 40C Turnigy Lipos to the "sledges" of the lipo rail system. For this first I stick them to the sledge with some double sided tape and then I used shrinking tube. To fit to the rest of the boat I used black one:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_201.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_202.JPG
The Setup
As the desired Tenshock 2250/7 are not available I had to change the motors. After some discussions with others I decided to go for two Leopard 4074/2Y engines with 2150kv. These should fit very well to the boat and allow speeds around 130km/h with Octura X447. As controllers I use two 180A Seaking ESC's, each with 3 additional caps directly soldered to the original circuit board. This gives 6000µF per controller, should be way enough. I also use the original Leopard water jackets, as some might see I turned on each one one of the nipples to get a shorter cooling circuit.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_197.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_200.JPG
ManuelW
03-02-2011, 05:40 PM
Then I connected everything up and cut the wires and soldered the connectors. As it can be seen I suited the parts in the hull and cut the wires to the minimum. As bullet connectors I use 6mm LMT system because I think it offers outstanding chucking power and little resistance. Here the wired up system outside the boat. I also marked the motors to know to which side each drive-train belongs. As you may see I want the props to spin "inside" and not outside.
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_198.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_199.JPG
Result
After that work the hull was ready for screwing all the components inside. The water outtakes are fitted to the inside of the tunnel, if you look carefully you'll see. As far as up to now I'm quite satiesfied because the cooling system as well as the rest of the wiring are kept as short and efficient as possible. As receiver/transmitter system I used a Futaba T3PK 2.4Ghz system. Servo is a Savöx SC 1251MG LowProfile Servo if not mentioned yet. I think the rest of the pictures are self explaining:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_184.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_190.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_216.JPG
ManuelW
03-02-2011, 05:42 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_217.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_225.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_289.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_185.JPG
ManuelW
03-02-2011, 05:43 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_218.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_186.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_187.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_188.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_192.JPG
ManuelW
03-02-2011, 05:50 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_191.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_224.JPG
The RTR weight of the boat is now about 5800g with LiFe Receiver pack. The test run was made at less than 0°C so it was very cold. I used a pair of Octura X447 cut to 45.5mm for the test. As it was the first real test and the CG and the trimms where not yet set right I couldn't give full throttle because otherwise I'd have to pump up the rescue boat which I didn't want. But setup seems to be pretty nice, I estimate the speed around 120km/h.
Video of the Test Run:
http://www.mb-forum.at/video_hpr_06_wolfgang_2.testfahrt.wmv
At the moment the hull is sent away to get a paint job. I hope you enjoy this review and my work, I'll continue when the boat is back from painting and I can present it as well as the rest of the testing before I'll hand it over to its owner.
Have a nice evening,
Manuel
Anbjorn
03-02-2011, 06:04 PM
Nice and clean job Manuel.:beerchug:
Anbjørn
DISAR
03-04-2011, 07:21 AM
Nice, well done.
What timing did you use?
I have the same setup and same props in my sprintcat 35" except that running on 5s, now I will run 6s!!! I suppose your temps were ok?
ManuelW
03-06-2011, 06:25 PM
Hi Dimitris,
Timing was set to 11.25° with the ProgCard. If the hull is back from the paint job and ready for testing I want to try a pair of Octura X447's Andy Browns and then may increase the timing stepwise. Temps were ice-cold, like the water, the air, my hands & everything else.
Best regards,
Manuel
Himalaya
03-10-2011, 12:35 AM
Brilliant thread. Man you build boats with your soul. :thumbup:
ManuelW
03-10-2011, 04:52 PM
Hello Himalaya,
thanks for the nice comment. But I looked the pictures of your HPR Building thread (couldn't read the text there and translator failed) and you also put a lot of effort and time in your boat. But I think HPR's really are worth the investment!
Best regards,
Manuel
ManuelW
05-09-2011, 04:40 PM
Hello Guys,
here the final results of my build:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_228.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_237.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_226.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_238.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_227.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_229.JPG
ManuelW
05-09-2011, 04:41 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_230.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_231.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_232.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_233.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_234.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_235.JPG
ManuelW
05-09-2011, 04:46 PM
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_236.JPG
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_239.JPG
And here a video of the last test run:
zMK_ae-Q2Gw
I wish you a nice evening,
Manuel
rc2266
05-09-2011, 05:12 PM
:w00t::w00t:
RaceMechaniX
05-09-2011, 08:50 PM
Stunning paint Manuel.
Tyler
tiqueman
05-09-2011, 10:17 PM
Amazing Manuel, just amazing. Your "two hatch" idea is one I though of doing as well. I love the scale appearance of the see thru windshield, yet was too worried about installing it for running purposes. I would like to do another hatch for when its on display, scale looking, with drivers... :drool:
Rumdog
05-09-2011, 10:33 PM
unreal..
norbique
05-10-2011, 08:57 AM
beautiful!
Punisher 67
05-10-2011, 11:57 AM
Very very nice build and detail Manuel , Where did you get the little metal hose clamps can you post the link please
Thank you
jb1234
05-10-2011, 03:09 PM
How do you mount the bullet connectors to the hull for the "not aus"?
LarrysDrifter
05-10-2011, 04:50 PM
Amazing! One wouldn't expect a China powertrain in an HPR, but they run great. Awesome job Manuel. She looks good with the Outerlimits paint scheme. Your build gives me much needed motivation for my builds.
ManuelW
05-11-2011, 04:42 PM
Hello Guys,
big thanks for the nice replys!
@ Punisher: I buy them at my local hobbyshop or here:
http://shop.lindinger.at/product_info.php?products_id=11800&osCsid=1ec4293b505c51660ab5118cae035ba4
(Maybe ask Steve from OSE if he includes them in his shop, I like these very much!)
@ jb1234: First I glued the two female bullets to a 1mm piece of GFK sheet and then I glued the complete sheet with the two female connectors to the inside of the hull that the connectors are on the same level as the outer surface of the hull. For the glue I used epoxy resin like I use it as glue for everything inside my boats.
Best regards,
Manuel
johnf
05-11-2011, 05:51 PM
That is just awesome. Great work.
millzee
05-11-2011, 07:03 PM
stunning paint work, excellent stuff.:thumbup:
Fast One
05-12-2011, 07:25 AM
Very cool looking boat. Well done!
I just have a question about the rudder you have used? Can you measure the size of the mounting pod bracket? I may need one for my cat hull but need to have the exact measurement to see if it will fit the pod on my cat, In mm if possibile.
Thank you Shane.:thumbup1:
westbeach
05-12-2011, 08:17 AM
It is about 23mm wide by 23mm high.
HYDROJERRY
05-12-2011, 12:25 PM
frickin sweet build,,what is the black looking glue you used to mount in everything and how did you glue in the nuts to screw down the hatch????
ManuelW
05-12-2011, 01:53 PM
Hello Guys,
thanks again for the comments, maybe I should make some photos when I run the boat again and post them here.
@ Shane: As far as I remember 25x25mm but I can measure it for you when I'm at home again.
@ Jerry: I use colored epoxy resin, also used it to glue the nuts for the hatch lock. There are many different colors available, you add 2-5% to the mixed resin and it will have the desired color. You may visit this thread: http://forums.offshoreelectrics.com/showthread.php?t=21765&page=2 and look at post #55. In that HPR C5009 I used blue epoxy resin color!
Best regards,
Manuel
JMSCARD
05-12-2011, 02:53 PM
Wow.... is all I can say... phenominal build job....
Manuel I take it you build for $.... may I ask the type of money this build cost the owner? and what could you produce another one like it for... I mean really... who of us here doesn't want one... :)
H2OCamel
05-12-2011, 03:12 PM
Yes !:iagree:
Fast One
05-13-2011, 03:23 AM
Thanks for the prompt reply regarding the rudder mount. So far the 25mm wide by 25mm long checks out. My pod is 25mm wide and 30mm long so it should fit. If you could double check with your one when its convienient that would be terrific.
And one last question where can I buy the rudder assembly from?
Thanks again Shane.
ManuelW
05-14-2011, 06:54 PM
Hello guys,
yesterday I worked again on the boat, some little finishing work. Removed the cable mess and installed a few more red-anodized M3 screws. Also assembled the scale hatch with the cockpit glasses. Will take a few pictures tomorrow and post them within the next few days.
@ Shane: Measured both today and they were 24mm wide and 25mm long. And these are available here: http://www.hpr-powerboats.ch/
@JMSCard:
You've got a PM!
Best regards,
Manuel
Fast One
05-17-2011, 03:47 AM
Thank you Manual for the info about the rudder it was a big help. I will get one direct from HPR. Its a pitty they dont have an internal water pick up in the blade but it is the way it has been designed.
Thank you for all the measurements, its good to have that info before you buy anything as the picture does not show that detail.
Best regards Shane.:smile:
ManuelW
05-17-2011, 03:01 PM
Hi Shane,
no problem at all.
And here a new picture of the second canopy with the installed window glasses:
http://www.mb-forum.at/temp_baubericht_hpr_115_wolfgang_240.JPG
mfg Manuel
HYDROJERRY
05-17-2011, 05:00 PM
Now that looks sweet,,
Siggy
07-19-2011, 09:05 AM
Thanks Manuel for the very informative and inspiring build thread. The videos of how beautiful these HPRs rips truly are mesmerizing. I can only imagine how exhilarating the driving experience must be. Cheers!
Chrisg81983
05-18-2012, 06:33 PM
Thanks for the link Manuel this is all the info I need
ManuelW
05-29-2012, 06:49 PM
Hello Guys,
thanks for the credits. Maybe soon I can upload a new video of that boat.
regards,
Manuel
