View Full Version : motor #'s
byron
12-12-2010, 06:29 PM
hay guys what due the numbers mean 36-56 2030 . these are numbers to the ul 1 motor? i'm looking for a motor from hobby king and was wondering what would match up or what would be good for a p spec tunnel on 4s:help:
syncronized77
12-12-2010, 07:05 PM
It means the motor has a 36mm diameter and 56mm length and pushes 2030KV. If you're looking for something comparable to that...
here are some options from HobbyKing for anything less than a 30" hull...
Turnigy 1800KV Outrunner (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=9258)
1900KV 9XL Inrunner (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=6678)
2300KV 8L Inrunner (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=4938)
The last one might be a little on the hot side...depends on the size of your hull
byron
12-12-2010, 07:14 PM
thanks ,what is the big difference between an in runner and out runner . ? nitro seems easer lol.
what would you guys use for a outboard/
carlcisneros
12-12-2010, 07:24 PM
Byron;
IS that you Big Byron?
Carl Cisneros
byron
12-12-2010, 07:33 PM
Byron;
Carl Cisneros
no just little old me
siberianhusky
12-14-2010, 11:23 AM
I'd stay away from those KB or KD motors, known amp hogs and run hot! A buddy of mine is running a 36-56 2300kv turnigy inrunner in his SV 27, for 25$ it seems to be a great motor.
