View Full Version : What is the difference 2s 1p or 2s 2p ?
lenny
12-09-2010, 04:28 PM
Looking to by lipos, not shore what to by.:confused2:
egneg
12-09-2010, 04:33 PM
2P or not 2P ...
All kidding aside a 2S2P is like having two 2S1P in parallel and doubles the mah. So if 1P is 5000 mah than a 2P will be 10000 mah.
lenny
12-09-2010, 04:51 PM
So what is better for long sport running ? A 2s 1p 30c 5400mah or 2s 2p 30c 5400mah
Thank for input.
egneg
12-09-2010, 04:56 PM
They are the same as far as power goes.
sailr
12-09-2010, 05:01 PM
If you are only running 2S (7.4V), you buy TWO 2S 5400 packs and wire them in parallel. That gives you 10,800mAh. That is what you want for long running. The same goes for running 3S or 4S, etc., parallel two packs to double the mAh. The mAh determines the run time.
Thank for input.
lenny
12-09-2010, 06:53 PM
OK ! than way do they make 1p and 2p ?
Feeling (dum) hear, Need to know. New to fe.
I have two boats a rio ep stock for now, looking to go brushless soon 1 lipo for it, and 2 lipos for other boat, 29"mono 540 9xl kv1898 esc 120 props not shore what to use yet x642 or m445.
dana
12-09-2010, 07:04 PM
Feeling dum hear, need to. New to fe.
I have to boat a rio ep stock for now, looking to go brushless soon 1 for it, 2 for other boat 29"mono 540 9xl kv1898 esc 120 props not shore yet x642 or m445.
is it ironic that you spell "dumb" wrong? cripes dood, i cant understand any of this
sailr
12-09-2010, 07:20 PM
ALL single packs for the most part are 1P. S is for series. P is for parallel. Just look for packs that are 2S, 3S, 4S, etc. They are all considered 1P (another way to look at it without confusing you further is that 1P stands for 1 PACK. If you want 2P, 3P, 4P, etc., that is paralleling multiple packs.
Come on! This is NOT that difficult!
dana
12-09-2010, 07:34 PM
2s1p = 2cells in the pack wired in series to the connector. 2s2p = 4 cells in a pack ( 2 sets of 2 cells wired parallel) then wired in series to the connector. either way they perform the same task the same way. i dunno why some companies make 2s2p rather than 2s1p. 2s2p just means there is more room for error because there are more connections made to acheive the same result as 2s1p
forescott
12-09-2010, 10:51 PM
I know venom makes some 3s 2p packs that have 6-cells shrink-wrapped together. Same as running 2-3s packs in paralell. Just together as one battery. I think these are more for single battery applications. Most rc boats require 2- batteries for proper weight distribution since the motor/stuffing tube sits right down the center.
marko500
12-10-2010, 07:51 AM
Maybe this will help you understand. http://www.offshoreelectrics.com/lipo.php
Mark
lenny
12-10-2010, 11:17 AM
Thanks for input,
Diagrams and schematics always clear things up for me !
HAPPY HOLIDAYS AND ALL THE BEST WISHES !
LENNY
sailr
12-10-2010, 11:33 AM
:laugh::laugh::banana::laugh:
ScarabChris
12-12-2010, 10:36 AM
Mark
Excellent information there as I had some questions also.
Just to be clear, if I want to double the mAh (longer run time) but keep the voltage the same I need to run two identical packs in parallel correct?
forescott
12-12-2010, 10:51 AM
Yes sir!!!
ScarabChris
12-12-2010, 10:59 AM
Do the batteries running in parallel need to be exactly the same? For example can one be a 5000 mAh 6s 40C and the other be the same but a 30C?
Or maybe a 4000 mAh 6s 40C in parallel with a 5000 6s 40C?
forescott
12-12-2010, 11:19 AM
Ideally it would be best to keep them the same because the amp ratings will be different on each pack. It will probably work, but if run down too low I'm not sure how the lvc on your speed control would see it and you might ruin the smaller pack. Lipos can be dangerous if not used correctly and if it were me I wouldn't chance it with that nice build and all that $$$ worth of components. JMO!
ScarabChris
12-12-2010, 11:46 AM
Gotcha, that makes sense about the LVC on the ESC. Damn......HK is out of the 5000 mAh 6s 40C Turnigy packs. I should have bought 4 from the get go instead of just 2.
sailr
12-12-2010, 06:33 PM
Do not mix packs! Stay with identical, including from the same manufacturer. You're asking for trouble otherwise.
ScarabChris
12-12-2010, 07:01 PM
Anyplace else I can get Turnigy packs besides HK? The packs I need are back ordered.
astyur77
01-15-2011, 03:42 AM
That was some explanation about the difference between the 2s 1p and 2s 2p that even a “dumbo” like me could understand what all that was about!! I am sure that must helped a lot of people to really make up their builds about how they want to go about building their boats!!
