View Full Version : Mark F pilots a mini hydro with watercooled brushelss motor
questtek
12-08-2010, 11:07 PM
Mark will fill in the details but here is the video..............
http://www.youtube.com/watch?v=ZCTzOVH33FM&feature=youtube_gdata
Jeff Wohlt
12-08-2010, 11:13 PM
Mark hit a bouy!??? No way that was Mark...:) Fast little bullet.
2S...3S and what...about a 3900 kv motor?
MarkF
12-09-2010, 12:16 AM
Yea the first thing out of Joe's mouth was you couldn't hit that buoy if you tryed. I was trying the new water cooled motor from AEO. The motor looks really nice and well built. I will get some pictures up when I can. The motor has a 3mm shaft instead of the normal 3.17 mm shaft, so the coupler I have doesn't fit right and I am getting a bad vibration. Anybody know where I can get a 3mm motor to 4 mm shaft coupler?
Mark
sailr
12-09-2010, 07:27 PM
Hi Mark. Jim here. I'll measure our couplers and shafts for you tomorrow.
Jeff Wohlt
12-09-2010, 10:15 PM
Couplers :) Joe knows where to get them.
MarkF
12-10-2010, 11:47 AM
Do you have one the size I need Jeff ?
Mark
MarkF
12-10-2010, 12:01 PM
Here is a link to the motor. The shaft size is 3mm. This motor looks very good by the way and I believe is going to run great once I get the coupler I need.
Mark
http://aeorc.cn/english/?product-249.html
Jeff Wohlt
12-10-2010, 06:41 PM
How many ya want? Running a cable?
MarkF
12-11-2010, 02:36 AM
Just 1 will be fine. The cable is one of those 4mm square drives that come with the boat. Its only square at the prop end though and round at the coupler end. Some set screws at both ends will work fine. I would like one as soon as possible Jeff.
Thanks
Mark
Jeff Wohlt
12-11-2010, 10:36 AM
I will try and get it out Monday for you. Is 3/8" stock okay for OD size?
MarkF
12-11-2010, 09:18 PM
Yes thats fine. Not alot of room in the boat so 3/4 long is pleanty as well.
Thanks Jeff
Mark
antslake
12-16-2010, 02:38 PM
Ha, I am testing the new AEO 400 water cooled outrunner, and ran into the same problem. There aren't many 3mm couplers out there. I need a 3mm-.098. Some guy over at RCgroups said he would make me one. I see ETTI has one, but it might cost me $20 by the time I ship it here.
mx174k
12-16-2010, 07:02 PM
I use a similar motor in my mini rio.http://www.hobbypartz.com/88e-ads-300l-watercool-motor.html The 1/8 in. couplers OSE sells fit great.I run the 1/8th to .98 cable.Hope this helps.
antslake
12-16-2010, 07:09 PM
I was thinking of giving that a try but I was playing with a 1/8" coupler, and it seemed to loose to me. There is .007 play in it. You don't get vibration?
mx174k
12-16-2010, 07:17 PM
There is actually less runout than the stock coupler had.I don't experience any vibration and I'm running 3s and a 31 mm carbon prop.
MarkF
12-16-2010, 09:33 PM
!/8 couplers are bigger than 3mm. Jeff Wohlt is making mine. I would suggest you order one from him.
Mark
sailr
12-17-2010, 07:16 PM
1/8" = 3.24mm
SweetAccord
12-17-2010, 07:29 PM
The second run what nice! Did you move the battery forward to gain more balance?
MarkF
12-18-2010, 12:59 AM
I adjusted the strut to have a little down in it.
Mark
MarkF
12-28-2010, 02:38 AM
For those of you who want to run this motor I got my coupler from Jeff Wolht and it fits perfectly. I'll get some video shortly of what this motor can do.
Mark
