Schulze 40-160: Solder won't stick???
  • pmx
    • Nov 2010
    • 61
    Trying to solder connectors to a new Schulze 40-160. The solder won't stick to the wire like it should. It's as though the wires are specially coated or something.
    Is there a special solder needed, or a special prep for the wires?
    Thanks for helping a noob.
    Pops' fleet: Challenger 43, SuperVee 27, Pro Boat Fastech
    Mine: JAE 21-FE
  • Alexgar
    • Aug 2009
    • 3534
    rosin or acid flux might help
      • 8012
      You need to use quality lead/tin electrical solder. You also need a hot iron for the heavy wires, a soldering gun won't work. I use a 40W 1/4" wide wedge-tip Weller iron, but a 60W or 80W would work even better.
      • RaceMechaniX
        • Sep 2007
        • 2821
        I use a good wicking liquid flux to dip the stripped end into and then use an 80W soldering iron with the wide tip or a propane torch on low setting. Just a note you have to be careful if you use a torch as it can anneal the plugs and you will loose the firm fit.
        TG
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • pmx
          • Nov 2010
          • 61
          Cool, thanks.
          We've been using an old school Archer soldering gun. I think it is 100W. With 60/40 solder. It works fine on other wires, but just won't stick on the Schulze wires. We'll give the wicking liquid flux a try.
          Mine: JAE 21-FE
          • siberianhusky
            • Dec 2009
            • 2187
            NEVER EVER USE ACID CORE ON ELECTRONICS! You will never get it cleaned out of the strands of the wire then they WILL corrode! Everything else is good advice!
