View Full Version : Speedmaster Stinger Strut 3/16"
Alfa Spirit
11-11-2010, 06:59 AM
Hello guys,
This Speedmaster strut should be fine for my mono hull.
I want to know which drive shaft and flexshaft at OSE shop fit perfectly this 3/16" strut. Thanks
http://www.offshoreelectrics.com/proddetail.php?prod=ros-stinger-str
tiqueman
11-11-2010, 07:45 AM
Hey Alfa, What kind of power are you puting into the mono? What size is the mono? We may need those answers to help you out a bit more.. whether you could go .150, .187..???
Alfa Spirit
11-11-2010, 07:58 AM
Hi Tiqueman, this is for a 39" MHZ Fountain with one Castle 1717 motor
tiqueman
11-11-2010, 08:22 AM
Id think this.. but Im not 100% sure the 1717 wont eventually snap it?
http://www.offshoreelectrics.com/proddetail.php?prod=hug-b6666
Hiopefully someone w/ a similar power set up will chime in.
Alfa Spirit
11-11-2010, 08:34 AM
Yes, looks great but out of stock... The Castle have a nice torque, 30000 RPM unload with 5S 2P, depends of the prop.
You mean that the flexshaft can be broken?
tiqueman
11-11-2010, 08:48 AM
Yeah I saw a .187 snap on a Castle last week. It was Bill34207 boat.. DF41. Shoot him a PM if youd like and get his set up details as I do not know them off the top of my head. I can check my LHS if youd like. He usually has those cables in stock. Im not sure what shipping would be to get it to you though.
Alfa Spirit
11-11-2010, 09:04 AM
Okay, if you' ve got that Hughey .187 assembled cable for 3/16" propellers I put an order to Steven. I' m near Paris in France
tiqueman
11-12-2010, 07:35 PM
You have a PM.. My LHS has several in stock...
Rumdog
11-12-2010, 07:50 PM
.187" will be plenty for the 1717. I used .187" flex in a DF 40" mono with a 2215 on 9s and a x455 with no problems.
Alfa Spirit
11-15-2010, 02:01 PM
The Hugey flexshaft is out of stock at OSE shop, I bought a flexshaft from Dave Marles
3/16 x 21.5" , 17 €uros
Advice about those flexshafts?
http://cgi.ebay.fr/FLEXISHAFT-3-16-x-21-5-flex-shaft-rc-model-boat-cable-/120645423280?pt=UK_ToysGames_RadioControlled_JN&hash=item1c170710b0
http://img266.imageshack.us/img266/179/temp48.jpg
Alfa Spirit
11-24-2010, 01:41 PM
Finally I bought the 3/16" flexhaft from PMB Prestwich Model boats, quality is good. Speedmaster Stinger Strut, K&S Brass Tubing and Teflon liner come from QSE shop.
Total price isn' t high, cheaper than MHZ first price trimax alone :rockon2:
Alfa Spirit
11-30-2010, 09:55 AM
Flexshaft from Dave Marles and Speedmaster assembly, looks ok to me.
Total lenght is 120mm, the MHZ Fountain hull is 1 meter long
http://img252.imageshack.us/img252/331/mhzfountain34.jpg
http://img26.imageshack.us/img26/2176/mhzfountain33.jpg
bigwaveohs
11-30-2010, 05:03 PM
As long as we are on the Speedmaster stinger topic, any ideas as to how to eliminate the vertical play in the adjuster?
This isn't an optimal setup...
egneg
11-30-2010, 05:06 PM
Tighten the bottom screw on the adjuster.
bigwaveohs
11-30-2010, 06:51 PM
funny...there's too much clearance between the hole and the screw; they should have tightened up the tolerances...
DPeterson
11-30-2010, 07:47 PM
bigwaveohs
I run these on all my mono's. Actually I run the bigger one so I could modify it for bearings. I too found the verticle adjuster to be less than ideal. I removed the 2.56 screw on the bottom of the adjuster and then tapped the hole all the way through the parts with a 4.40. Run a 4.40 screw through it with a nut on the end. Still have to crank down good on the adjuster nuts but this modification made a hugh difference.
Doug
bigwaveohs
12-01-2010, 11:08 AM
bigwaveohs
Doug
That's what I had in mind...to use a larger fastener with a tighter tolerance for the hole...
