View Full Version : Video/s of the P1 in action, and my first thread here.
antslake
11-09-2010, 06:35 PM
Hello, my first thread here. I have done a lot of testing with this boat so far, and I am over-all very happy with it. I am also very happy with Venom's support. So far after 40-50 runs I've had two problems. One was with the transmitter (it still worked but was buggy) sent it back, and they sent me a new one right away, and the port trim tab needed to be relocated as it was not flush with the boat. I've also had a few of the glue/resin joints let go, but I am sure that has been from the pretty intense crashes I've had. Flexible CA is "DA BOMB" on these boats, and on marine stuff. A couple drops and it was all good again.
I hate to post a link to another forum, but I did a pretty intensive write as I went with this boat on RC groups, and I don't want to have to repeat all the info here, so here is the link:
http://www.rcgroups.com/forums/showthread.php?t=1320827
I have been through 3 props so far, and I just got in 3 more from OSE. Hopefully I will have time to work on them, and do some more testing before it gets too cold out. I have a ton of videos on this boat, including a music video I made(music by me, just a live recording while watching the video). The two most impressive are these:
http://www.youtube.com/watch?v=UjlYFbd1Spg
and a brief 6S run (need to do more testing with props before I go 6S again:
http://www.youtube.com/watch?v=RyFgJtc2scM
Anthony.
I think possibly I cannot embed video yet, as this is my first post.
Jesse J
11-09-2010, 08:50 PM
welcome to the board!
great work on the slo mo - what camera are you using? also, I would like to see the same clips of real speed. You captured what offshore models are - amazing!! and the slo mo makes them seem much bigger too.
antslake
11-10-2010, 12:53 AM
The camera is a Casio EX-FH20, those slo-mo clips were shot at 210fps. When shooting at that speed there is no sounds recorded, and the resolution is 420x240.
The stills were screen grabs from 720p hd video.
I did do some normal speed recording before I took the slo-mo clips, I won't have a chance to post it till next week. The slo-mo clips, I was running 3S, with a x437/3 prop sharpened by finedesign. That's all you need in those waves.
bwells
11-10-2010, 01:06 AM
Antslake, damn good job!
forescott
11-10-2010, 01:25 AM
Here ya go........
UjlYFbd1Spg
bwells
11-10-2010, 01:31 AM
It seems like the boat wants to roll to the right when the prop leaves the water and is still running, torque? It seems like it is all up to the throttleman when getting big air.
forescott
11-10-2010, 01:36 AM
Exactly correct. Its the narrow hull with the torque of the outrunner can causing it to twist. The p-1 becomes out of control in rough water. Its one of my biggest gripes with mine.
jamespl
11-10-2010, 12:29 PM
have you been running it on 5s stock without any problems?
matthj72
11-10-2010, 10:14 PM
how do you like the overall performance of the x437 3. most people seem to be running a 2 blade prop on this boat? THANKS!
antslake
11-12-2010, 10:51 AM
Ok, to answer all your questions.
1. Boat rolling to the right.
If you notice in the video, sometimes it will roll to the right, or to the left. By comparison, I think these waves I was in are equivalent to 15 seas, so the boat will roll any way the waves toss it. Yes, there is prop walk, especially with a 3 blade prop, but running on 3S (as I was in the video) there isn't much prop walk at all. On 3S with that prop, the boat can go 23mph, plenty fast for those waves.
I do look ahead though (from years of racing RC cars, and flying) and try to hit the waves right. I also sometimes let off the throttle a little, but it all happens so fast in real time, it's kind of hard to keep up with it. I hit about 2-3 waves per second, that leaves .3-.5 seconds for reaction.
2. 5S.
I ran the boat on 5S with that prop, and it got a little hot. I peaked around 88 amps. Remember the boat is rated for 60 amps. I was drawing a constant 70 amps at WOT. I only have one other prop a Y536, and it was my first attempt at shaping/polishing. It's all balanced correctly, but I may have messed up the face a little, so I don't think it's running correctly. I just bought 3 more props, X432, 435, 438, but my time this month is limited. Going to be traveling a lot, and the weather isn't getting any warmer. Right now the Y536 draws more amps than the X437/3 and goes slower, so not sure about it. More testing to come.
3. 2blade vs 3 blade.
AS stated, I only have the two props, and as far as handling goes, the 2 blade handles way better, has less prop walk. The 3 blade has more lift, but I am still tuning the boat (the tabs) and I haven't put any turn fins on yet. The 3 blade is also way better out of the hole, and better in the waves on 3S.
Forescott, do you run the port tab lower than the starboard tab?
Jamespl, don't run that plastic prop anything over 4S. (IMO)
forescott
11-12-2010, 08:06 PM
I dont use the trim tabs at all. They are both set at neutral.
JEDNJONES
11-12-2010, 09:42 PM
That is the best RC boat video I have ever seen. Great Job!
antslake
11-12-2010, 09:58 PM
Thanks Jed! Quite the compliment :)
Forescott, do you have videos of yours running? I am curious. I have both tabs down, other wise it will just drive itself out of the water with a 3 balde prop. The two blade doesn't do that. But even with the 2 blade, the boat drives "heavy" on the starboard side due to prop torque, so I offset it with the tab.
forescott
11-12-2010, 10:21 PM
just one......
rH_o20IgWVM
antslake
11-15-2010, 11:05 PM
What prop is that one Scott?
I noticed with my 2 blade, I didn't need any tab, but the 3 blade I did. Especially in the chop, any help to get the bow in the air, the thing will just fly out of that water.
forescott
11-16-2010, 05:54 PM
Its the octura x442.
antslake
11-16-2010, 10:07 PM
Do you know your amp draw on 4S?
I also think my flex cable may have a limited life. I noticed it's bent in between the motor and the stuffing tube. I don't think that was completely lined up from the factory.
bwells
11-17-2010, 01:29 AM
Yes, I agree also. That is the best true offshore RC I have seen. (King of shaves).
forescott
11-17-2010, 06:09 PM
I'm not sure of the amp draw. I don't have a data logger. And my motor/stuffing tube alignment was horrible from the factory. I ended up grinding away at the bottom of the motor mount and even bending the little "L" brackets to line it up better. It's still not perfect, but much better.
JackBlack26
11-25-2010, 12:30 AM
Man, this boat looks great! Awesome videos too. I checked out your RC Groups link and there is some good stuff there too, as well as in this thread. If you don't mind, can you tell us what prop worked best with what voltage? That would be awesome.
Like all boat it seems to have its bugs but I already made up my mind and asked the wife for 1, for X-mas. She approved since I have a $60 off coupon from Tower, $289 shipped. I have plenty of Turnigy 5000 MAH LiPos too and I think to start 4S will be enough for the "small" pond near me.
forescott
11-25-2010, 11:40 AM
The octura x640 seems to be the best all around prop for top speed/optimum handling and stinger adjustability.
antslake
11-28-2010, 09:35 PM
I haven't tried that prop yet. I have a few more props to try, but was traveling a lot, and no time to sharpen them. Hopefully before the ice comes, I will get to it. The x640 is on my list. But that prop would probably only be good for 4s. I will be testing for 5, and 6S. My goal is to hit 50mph with the stock motor and speed control @60amps.
forescott
11-28-2010, 11:00 PM
Your gonna have to run an m645 to get that kinda speed. That 45mm prop is too big and will hit the rudder linkage without adjusting the stinger way down which in turn will give you a nose down attitude and scrub speed. If the 60 amp esc doesn't burn up first from too much prop. Good luck though!
antslake
11-30-2010, 09:02 AM
I was going the other way, down in size to reduce amps and bring up rpm's. I think it might just be a matter of prop work, but 6S and the right prop might do it. The 60 amp goal may be unrealistic, could turn out to be 70 or 80 amps. I was told the motor would blow up before the speed control. I've peaked the speed control at 88amps already on one short run. I think I've had it up to 47-48 mph already. It's not the way I would run it all the time, just a goal to hit. Most likely I will stay around 4S and 40-44mph.
jamespl
11-30-2010, 09:38 AM
Why don't you do what I have done and get a turnigy H2136 motor in place of the stock one, this motor is good for 2-6 cells and should turn a bigger prop but as said you are limited by the hardware. I ran mine on 5s with a 90a esc and x640 prop and it was very fast, only had nod run as it's freezing in the uk at the mo. I have the 1600kv version but fightercat does the 2200kv and it's a straight swap motor.
antslake
11-30-2010, 10:08 AM
How fast exactly? I am using eagle tree to find out actual speeds. I can't see spending money, and taking out what is already good, just for a couple mph.
jamespl
11-30-2010, 10:24 AM
I don't knw how fast exactly but from running 4s and x640 to the turnigy motor and 5s there is a deffo speed improvement. But at $20 from hobbyking u can't go wrong. I wish I had a vid for u.
antslake
11-30-2010, 10:42 AM
I recorded with the stock setup and x437/3 prop, going from 4s to 5s went from 38 to 44mph. But I was drawing 70 amps on 5s. 60 amps on 4s.
jamespl
11-30-2010, 12:39 PM
That's why I recommended the turnigy motor, my esc died cos I got it wet so replaced it with a seaking 90a so both motor and esc are good for upto 6s. I would say the turnigy will be about as fast as the stock motor on 5s but it can handle it, venom only recommend 3s for that boat.
antslake
11-30-2010, 01:00 PM
Venom recommends up to 6s. I was working with there r and d guy about it. I have run it on 6s already, but I have the wrong prop on there
jamespl
11-30-2010, 01:48 PM
I have not seen venom say anywhere that the p1 can be used on 6s. I have seen them advertise that the esc can handle upto 6s but not the motor. When I emailed them about using 5s on the stock setup they said if I used 5s it would invalidate my warranty!
antslake
11-30-2010, 02:23 PM
Well over on RCgroups, I have an interesting thread about this boat. In this post:
http://www.rcgroups.com/forums/showpost.php?p=16288458&postcount=10
Chris from Venom states that the motor and ESC are rated at 6S. The instructions from Venom tell you how to program for 6S. Plus I have already run the boat on 3,4,5and 6S. And twice I have had problems with a Venom product, and both times they responded well and replaced my defective equipment extremely fast. I am very happy with them, and the product.
They would be as a company wary towards people who run the boat on 6S, because you really need to know what you are doing to stay within the limits. First off the plastic prop has to go, secondly you need a data logger to record amps, and keep them within spec. Can't say that I blame them.
I've pushed my boat very hard, and it has held up. It if blew up tomorrow, I would not be disappointed.
antslake
11-30-2010, 07:08 PM
Oh, and I am not trying to discredit you saying they wouldn't warranty their product. But, I think if you had a real problem, and talked to them, they might help you out. They did for me anyway.
forescott
11-30-2010, 11:12 PM
Isn't there a 2200kv version of that same motor?
antslake
11-30-2010, 11:53 PM
The turnigy? Yes, he said that a few posts back. I wonder which one would ultimately be faster, depending on cell count and prop. It's my understanding that lower kv and higher voltage will make a more efficient setup. Doesn't 6s and 2200kv give you like 48840rpms? that's a bit high no?
forescott
12-01-2010, 08:24 AM
No, I wasn't thinking 6s. Just an upgraded 4s motor.
jamespl
12-01-2010, 08:33 AM
I think the 2200kv would deliver about the same performance as the stock motor on 4s but it's a lot cheaper than from venom. Plus you could always use upto 6s without smoking the motor.
antslake
12-01-2010, 06:54 PM
Oh here is a video of the P1 on 6S with the wrong prop, and not setup correctly, but you get an idea of the speed.
RyFgJtc2scM
Jesse J
12-01-2010, 11:03 PM
I had same issue with the wobblies. I am thinking it might be time to try offset rudder on mine - alas, my ponds do not condone boating at any speed..... socked in for the winter, so I must content myself with your videos! nice work as always.
antslake
12-02-2010, 12:45 AM
I don't think it was the rudder that was the problem, it was more like prop selection, and tab settings, and prop angle.
Thanks for the compliment on the videos. Someone asked me why I do so much filming. It's for a few reasons, 1. it's another hobby of mine, 2. I can watch and learn from them, and it gives me a record of what I am doing, 3. I can get triple the enjoyment from a single run :)
antslake
12-02-2010, 12:48 AM
BTW, I love your videos too :)
