View Full Version : Ultra fast electric options
hyrulejedi86
11-08-2010, 09:00 PM
I was looking through the hulls here on OSE and started thinking it would be awesome if I could build a very fast electric boat sometime but just not yet. I want to start planning it though.
So here is my question:
While keeping things reasonably priced (not $500 hulls) what would be a couple examples of good hulls to use for this application? I was thinking 65-75mph range. :biggrin:
What kinds of hulls, specific examples, sizes etc? I welcome all good information for my panning purposes. :buttrock:
Cheers!
carlcisneros
11-08-2010, 09:12 PM
JAE outriggers are one boat to look at.
Carl
Rumdog
11-08-2010, 09:18 PM
Do you want a SAW type rig, or one that will run well in an oval?
electric
11-08-2010, 09:21 PM
Insane FE 30 will get you into the low 60's without to much trouble and at a reasonable price.
hyrulejedi86
11-08-2010, 09:28 PM
Hmmmm, I was thinking something that will allow you to run in an oval.
Good suggestions so far! Just based on what's been said and what I said would a feigao xl size be required or the even bigger size one? I just mention feiago because I like those motors.
Rumdog
11-08-2010, 09:31 PM
Not a Feigao. Not to run the speeds you want reliably. What kind of budget are we talking here, total?
LarrysDrifter
11-08-2010, 09:36 PM
Feigaos run decent,but are two pole.Go to lightflightrc.com and look at the Arc motors.They are 4 pole and are very dependable and if the motor ever quits working for any reason,you send it back to them and give them $35,and they send you a new motor.You can run a motor mount screw too far into it and do the above and youll still get a new replacement.Leopards are good running motors too.I just ran mine and am very impressed.For hulls,if you like cats,FighterCat57 is having cats made that might be worth a look too.They arent MHZ or H&M,but they might suit your needs.Obviously,a rigger or hydro will turn a lot better.Just go with what you like and what will suit your needs.
LarrysDrifter
11-08-2010, 09:38 PM
I tried to link this www.lightflightrc.com. Maybe itll work this time.
hyrulejedi86
11-08-2010, 09:50 PM
Well, as for budget since this is only planning I don't have one. If nothing else I want to know what it really takes to hit those speeds. To learn how to make a good boat and what to look for.
Rumdog
11-08-2010, 09:55 PM
THE best hull I've ever owned is the Aeromarine Sprintcat .40. It is a 34.5" cat. It will eat up the chop, and make WOT turns at 60 plus mph. It will hit low 60's with a 1527 on 6s. You could also use an outrunner to save some cash, or a castle/Neu 1717 would do pretty well. The hulls are in the 250 range I believe.
Rumdog
11-08-2010, 09:56 PM
It WILL turn as good or better than most hydros or riggers, and in both directions!
hyrulejedi86
11-08-2010, 09:59 PM
I will definitely take a look a the hulls tomorrow after I get out of clinic and the arc motors look really nice but I couldn't find watt rating or a voltage rating or an amp rating. Maybe I just missed it but I didn't see those stats.
Rumdog
11-08-2010, 10:12 PM
Vid of mine running twin 1515's. Just so you can see how they handle big speed! http://forums.offshoreelectrics.com/showthread.php?t=14659
Make-a-Wake
11-08-2010, 10:59 PM
Man, Rum...........everytime i watch that vid, the hair on my neck stands up...............it looks so solid and the sound is the best i have ever heard from a twin..............awesome.
oscarel
11-08-2010, 11:54 PM
Sprintcat with twin $70 castle 1520 or 1717
hyrulejedi86
11-09-2010, 04:51 PM
I really like the aeromarine sprintcat. Rumdog, yours is awesome. It looks like it handles very well and has a great speed!
Is it necessary to use the dual motors to get to those speeds and handling or would it be possible to do it with one motor? Do you have any pics of the inside and the hardware?
As for motors I also like the arcs alot but like I said I couldn't find any info on the specs and limits of them.
The JAE outrigger is also really nice but I had messed with an outrigger before and their lack of space kind of drove me nuts.
The FE 30 is pretty sweet looking also!
Rumdog
11-09-2010, 05:42 PM
It will handle just as good with one motor. Mine was a little better in bigger chop with a single 1527 on 5s2p. 62 mph I think with the single setup. Here ya go, with a single: http://www.youtube.com/watch?v=TqTIEOKMnTA
Rum you always throw a wrench in what I want to build this winter, Nice twin!
oscarel
11-09-2010, 06:01 PM
Awesome cat!
hyrulejedi86
11-09-2010, 07:52 PM
I agree the cat looks totally amazing but I gotta ask. I looked up that motor and it is a BEAST It said it's constant wattage was 2250 watts (on 5s ~121A) and 4500 watt burst (on 5s~243A) Does it generally reach those wattages? How hot does it run not on almost frozen water?
I also was wondering just because I still haven't figured it out what difference does the 5s2p make compared to using 5s?
Rumdog
11-09-2010, 08:00 PM
2p will give twice the capacity and allow the motor to draw twice the amount of amps . 30c x 5000 mah equals 150 amps continuous. 30c x 10000 mah equals 300 amps continuous. With a big enough prop, yes it will deliver that wattage. I ran it with a x 455 for mid sixties. It ran warm. Not hot, but needed every bit of the CC LV 240. It was a reliable setup in any water temp. The build was finished mid winter, hence the COLD vid.
A 15271y will pull less amps and be a 60 mph boat on 6s2p as well.
Even if you're not pulling said amps, the packs will supply the motor/esc with more efficient voltage when running 2p.
supafastsupra2
11-09-2010, 08:05 PM
What's a good alternative to the 1527 (cheaper)? for 6s2p on the the sprint cat .40? Looking for 60-65mph in gasser chop
hyrulejedi86
11-09-2010, 08:10 PM
I get it, So do you run 2 x 5s 5Ah packs in parellel in the hull then?
The aeromarine site doesn't give alot of details about their hulls so I was wondering also, where did you get the hardware to put on the boat and is it fiberglass? How heavy?
Rumdog
11-09-2010, 08:17 PM
Yes fiberglass.
I have the "heavy" nitro layup. You'll want that option if you're gonna be running 60 plus for sure. It has 4" rails for the motor mount.
Yes 2 5s 30c 5000 mah packs is what I ran.
Speedmaster Hardware from OSE.
.187 flex.
It is a big hull for 34.5"
Supra, the Neu/Castle 1717 may get you 60 mph, or close to it on 6s2p. You could try some of the big outrunners also.
hyrulejedi86
11-09-2010, 08:29 PM
Would this do well at all on that boat, the neu 1521/1.5D 1860Kv, running 4-6s? Too weak?
Do you have a weight comparison perhaps to the UL-1?
supafastsupra2
11-09-2010, 08:48 PM
It's probably better to run a WYE (Y) wind motor rather than a Delta (D) wind. D wind motors are amp hogs. I also heard the 1717 is an amp hog according to the guys on rc-monster.
Any suggestions on a specific outrunner? What about a Leopard 5692?
hyrulejedi86
11-09-2010, 08:53 PM
I see, are they wound differently or is it just wound so that they have lower kV? I kinda wanted the slightly higher kV to get up there in speed.
supafastsupra2
11-09-2010, 09:03 PM
D winds are terminated differently to a Y which results in a given D wind having 1.7 times the RPM and less torque of a given Y wind (i.e. a 1521 1D and 1521 1D).
Left is delta terminated and right is wye
http://upload.wikimedia.org/wikipedia/commons/thumb/6/68/Wye-delta.svg/241px-Wye-delta.svg.png
Borrowed from Wiki:
There are also two electrical configurations having to do with how the wires from the windings are connected to each other (not their physical shape or location). The delta configuration connects the three windings to each other (series circuits) in a triangle-like circuit, and power is applied at each of the connections. The wye ("Y"-shaped) configuration, sometimes called a star winding, connects all of the windings to a central point (parallel circuits) and power is applied to the remaining end of each winding.
A motor with windings in delta configuration gives low torque at low rpm, but can give higher top rpm. Wye configuration gives high torque at low rpm, but not as high top rpm. [1]
Although efficiency is greatly affected by the motor's construction, the wye winding is normally more efficient. In delta-connected windings, half voltage is applied across the windings adjacent to the undriven lead (compared to the winding directly between the driven leads), increasing resistive losses. In addition, windings can allow high-frequency parasitic electrical currents to circulate entirely within the motor. A wye-connected winding does not contain a closed loop in which parasitic currents can flow, preventing such losses.
From a controller standpoint, the two styles of windings are treated exactly the same, although some less expensive controllers are designed to read voltage from the common center of the wye winding.
oscarel
11-09-2010, 09:06 PM
Here's an alternative, but would probably have to go at least 8s2p. I've got one of the smaller 700-68 motors that I've run on 8s1p and it's held up pretty well. I don't see these much here, but they are used for r/c jets. I believe they are also the same size as the Neu.
http://shop.turbofanelectrics.com/product.sc?productId=252&categoryId=33
supafastsupra2
11-09-2010, 09:09 PM
I'd like to stay 6s due to the high cost of an HV setup. I have a CC 110hv but am not sure if i could use this reliably with anything? Maybe a low kv outrunner on 12s?
hyrulejedi86
11-09-2010, 09:35 PM
I would too like to stay at or below 6s if possible.
That was a good explanation and quote though!
supafastsupra2
11-09-2010, 10:33 PM
Yes fiberglass.
.187 flex.
Rumdog I sent you a PM, dunno if your inbox is full?
